Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Door will not open
I have a Liftmaster 1265LM, my problem is the door will not open but closes fine until it hits the floor then it opens about 6", this is a problem that has progressed it would open after using the remotes we have 3 after about 10 times and it would raise 1/2 way now nothing
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 98 Answers
Sounds like you might have a broke spring. Put the door all the way down and release the manual release. Now try to lift the door. If the door is heavy you might have to call a door company in your area to add tension to your springs or if they are broken both springs should be replaced.
Posted on Jan 02, 2009
My liftmaster 1265LM will not close with the remotes, but will close only if I hold the wall button. Please advise.
Sounds like a door sensor problem. Make sure the sensors are pointed at one another and the small light on each one is lit and not flickering. Tweak them a little. If you cannot get both lights to come on you have bad sensors.
May 08, 2011 | Sears Craftsman LiftMaster Chamberlain...
Product Lift Master Professional Line 1/2 HP Security + Model # 1265LM Door goes down intermittently. Door will go down approx. 8 - 10 inches, stop and then retract. Remote in hand, I press the...
Check alignment of the obstruction sensors .... they shoot a light beam across the doorway about 6 inches above the floor. One is mounted on each side of the door track near the floor.
Aug 29, 2017 | liftmaster Chamberlain Garage Door Opener...
My Craftsman garage door opener opens fine. It
It could be closing too far or the sensitivity could be set too sensitive.
Lube the springs, wd-40 rust may be the whole problem.
If the door hits and the opener continues to move until the rail flexes upward and then reverses - probably the travel adjustment.
Does the door close and stay closed if you hold the wall button down constant until it closes? - this would indicate a safety eye problem.
If the door reverses before it hits the floor or just as it hits the floor it could be the sensitivity or if the safety eyes are mounted to the track they could be flexing enough to move the eyes out of alignment.
Hope this helps.
Jul 11, 2010 | Sears Craftsman LiftMaster Chamberlain...
The sensor lights are steady. The opener cycles fine withouit the garage door connected. Everything worked fine until yesterday. I hit the open remote and the garage door did not open. I hit close and it...
Remove the cover from the motor unit and check the drive gear. It is a white nylon gear just in front of the motor. Also check the door springs. One of them could be broken.
May 31, 2010 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster 1265LM garage door opener control wiring diagram
If you are looking for a schematic diagram they are not available.
Mar 04, 2010 | Sears Craftsman LiftMaster Chamberlain...
Door opens after closing
If the main light flashes 10 times when the door reverses it is a door sensor problem but if the door is hitting the floor and reversing and the main light is not flashing then the door is closing too far and the safety thinks it has hit something. On the side of the motor unit you will find 2 controls. One of these is the 'down limit'. Turn this in the opposite direction of the arrow printed on the cover until the door closes but does not reverse.
Jul 17, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener does not reverse after hitting obstruction
release the door from the opener and see if door moves freely the check proper torsion by moving door up to 3-4 ft if it stays in this area torsion is properly set if not call technician to adjust torsion
if door does not move freely all the way up and down check for binding track alighnment and roller condition. the adjust closing pressure.
Jan 07, 2009 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster 1265LM 1/2 HP does not open or close with remotes
is chain moving. if not, gears are shot. if moving, is trolley connected.
Dec 10, 2008 | Sears Craftsman LiftMaster Chamberlain...
IF IT HITS THE FLOOR AND GOES BACK UP. YOU NEED TO ADJUST THE DOWN LIMIT.
IF IT GOES BACK UP BEFORE HITTING THE FLOOR YOU NEED TO ADJUST THE SENSITIVITY OR THE SAFETY EYES.
TRY THE DOOR MANUALLY AND MAKE SURE IT WORKS SMOOTHLY.
Sep 30, 2008 | Sears Craftsman LiftMaster Chamberlain...
Lift master 1265lm 1993
check and see if a spring is broke on either side above the door in the middle. (big springs) that's my problem.
Aug 30, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
134 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
