Question about Zanussi ZBQ365 Electric Single Oven
Broken glass door
The inside of my ovens glass door cracked! would like to fix it myself, having trouble finding the part. Can I replace just the glass or the whole door?
  • Zanussi Master
  • 19,396 Answers
Depends on the model, check the link below to see if the glass alone is available, if it is not , that means that this is sealend inside the door.
In that case replace the whole door, or the oven wont bake evenly anymore.
See : Enter model number here to find assembly diagrams and parts.
Posted on Jan 01, 2009
The inside glass on the oven door just cracked and pieces of glass fell in behind. Not sure why. Can this be easily replaced?
yes but easily? maybe not to easy? removing the door can be a hassle. if u can find the glass rather cheaply it may be worth it
Mar 05, 2015 | Ovens
Range/Stove/ Oven Door Glass Replacement
I see many questions come up at about oven door glass that has broken and how to replace the glass. For many ovens it is a relatively simple task. It will take about an hour for most people, depending on the skill level, and the type of door.
To do this job you should have handy a screwdriver, usually a Philips head medium sized, a plastic tarp, especially if your glass in the door is already broken, and of course the new glass. It is also a good idea to measure the new piece of glass to make sure that it is close in size before taking the door apart.
For your safety, make sure that the power is turned off to the oven before starting this job also. The open the oven door and remove the screws on the inside face of the door. If the door can be remove easily you can remove it, but it is not necessary to do that. Make sure that you place the pieces of the door as they come off and the screws in a place to keep them organized for when you put everything back together.
For most ovens you will find the oven glass held in by tabs, similar to a picture frame. Pull the tabs back to release the glass. Carefully remove the old glass from the frame. If it is broken, be very careful not to cut yourself. Also contain the glass on the trap to make cleanup easier. For many newer ovens, you will have three layers of glass. Do the same process for each layer.
When the old glass is removed, then simply replace each layer of glass and press the tabs back in place for each one. Then replace the brackets or inside pieces of the door, and secure with the screws.
This is how easy it is to replace the glass for many of the ovens.
Another word about broken glass in ovens…..
Many of the people that have broken glass state that it broke after running the self-clean feature of their oven. For many of you this warning will be too late…but for those of you that see this before, be warned!
on Mar 22, 2010 | Ovens
Inside glass on door cracked how do I take door abort and put in glass.
Here is a tip that I wrote about the oven door glass replacement...
It is not that hard...
Jan 22, 2011 | Thermador C301U Electric Single Oven
The oven door inside glass has shattered and I was wondering if and how could I replace the inside glass pannel?
Yes it is normally possible to replace broken door glass.
Try the following site for some very helpful information
In the search box enter--REPLACING OVEN DOOR GLASS.
Ther are several videos on how to repair oven doors.
Jan 03, 2011 | Ovens
Reassembling thermador Thermatronic II lower oven door cmt21
you can use some of the glass of the old oven just need the size of the glass if you order from the manufacturing it very exp
Jan 03, 2010 | Thermador SMW272 Electric Double Oven
The inside glass on the door is broken ..can i replace it myself?
In most cases, it is possible to replace the glass panel, you will have possibly have to take the door apart to do this, but not in every case, it depends on how the panel is fitted.
Please rate my solution.
Aug 29, 2009 | Whirlpool RBS305PDS Electric Single Oven
Cracked see through glass -Frigidaire Gas Self Cleaning Wall Oven
Hi, You can replace the glass piece. You will need the whole model # when you call for the part.
Good luck. Please let me know if I can assist you further.
May 30, 2009 | GE JTP86 Electric Double Oven
How do I remove the glass on the inside of the oven door to clean between the two pieces of glass
We just replaced the inner glass last night. The door needs to be removed, then take the screws out that holds the inside panel on. I suggest writing notes of the steps that you take when you remove the panel and glass. Our model had three pieces of glass. Be careful replacing the door, we knocked the lock loose which in turn knocked the sensor for the light to come on. We had to take that part of the oven apart also to fix it. Hope this helps. I may not have done this if it wasn't for the broken glass.
Dec 30, 2008 | Whirlpool RBS305PDS Electric Single Oven
RBS305PDS Broken Glass on Oven Door
inner door glass part number 4449259.. youll need to remoe the door from the unit and lay it on the table, thats the hardest part, theres a few different ways the door releases, so refer to your manual if available, then its just a matter of removing the screws form the door until you get to the broken panel, might thake a little time but as long as your patient no need to call service man. probly save $150
Nov 23, 2008 | Whirlpool RBS305PDS Electric Single Oven
Zanussi ZBQ365 Electric Single Oven Logo
306 people viewed this question
Top Zanussi Ovens Experts
Charles T Nevin
Charles T Nevin
Are you a Zanussi Oven Expert? Answer questions, earn points and help others
