Question about Braun Syncro 7526 Electric Shaver
Braun 7526, how to clean without holder?
As said, my dad misplaced the cleaning holder, so we have the charger, the liquid cleaning packs, but not the cleaning stand. Can I clean the shaver without the stand just using the solution?
    Novelist:
  • 124 Answers
Yes, you can easily clean the shaver without the stand, as Russ described. However, you can obtain a replacement base for $18.99 at Shaver Outlet as of this writing. The link is HERE.
Posted on May 23, 2009
  • Gary
    Gary Oct 22, 2009
    I'm sorry, the link I provided was for fixing a broken cleaning station. A complete new one will cost more. Your best bet is to probably locate one on "that auction site". I'd try not to spend more than $30 for this, as you'll start nearing the cost of buying a very good condition used razor that includes a cleaning station (which you might want to consider, as you'd have two shavers to use the one cleaning station).
This is covered in the owner's manual. You can't use the solution, but you can clean the razor without it.
For a quick clean, press the buttons on the sides of the head to release the foil-- but don't remove it. The foil pops up just enough to create openings at the ends of the cutter block. Turn the shaver sideways, hold it over the sink or trash can, and run it for a few seconds. Click the foil back down into place.
For a thorough cleaning, remove the foil and clean the block and foil with a brush (such as the one included with the shaver), then reinstall the foil.
Good luck finding the the base. If you give up the search, I do see that they're available separately for far less than the entire package.
Posted on Nov 05, 2007
Braun 7526 not pumping solution
The pump is no longer working. You will need to replace the unit. Replacement can be found at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/cords-chargers-and-stands/braun/braun-7000-series-syncro-clean-charge-base-p-122.html
Mar 10, 2013 | Health & Beauty
Charger arm will not stay locked in place to charge the razor
This is a common problem for older cleaning bases. The part is worn out. You will need to replace the upper housing of the cleaning base. You will find this item available at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/braun-7000-series-syncro-clean-charge-base-replacement-part-p-118.html
If repairing the unit is not your thing, you can replace the entire unit instead. See item linked below
http://shaveroutlet.com/shaver-replacement-parts/braun-7000-series-syncro-clean-charge-base-p-122.html
Jul 08, 2011 | Braun Syncro 7526 Electric Shaver
Blades need sharpening or replaced. Where do I go in JHB area
Braun syncro 7526 foil and cutter blades is Braun Series 3 combi 30B foil and cutter replacement pack.
Apr 18, 2011 | Braun Syncro 7526 Electric Shaver
My Braun 7526 will no longer clip into the razor for cleaning and charging.
If the arm on the charging stand no longer locks down into place to charge the shaver, you will need to replace the arm or you can replace the entire charging unit. You will find both items at shaveroutlet.com. See links below<br /> <br /> arm only<br /> <a href="http://shaveroutlet.com/braun-7000-series-syncro-clean-charge-base-replacement-part-p-118.html">http://shaveroutlet.com/braun-7000-series-syncro-clean-charge-base-replacement-part-p-118.html</a><br /> <br /> <br /> complete base<br /> <a href="http://shaveroutlet.com/braun-7000-series-syncro-clean-charge-base-p-122.html">http://shaveroutlet.com/braun-7000-series-syncro-clean-charge-base-p-122.html</a>
Aug 27, 2010 | Braun Syncro 7526 Electric Shaver
My power cord is lost, what is the alternative
Braun Syncro 7526 power cord is Braun 7030458 charger cord replacement.
Jul 15, 2010 | Braun Syncro 7526 Electric Shaver
My 7526 won't clean cycle
It is probably plugged up at the base. Take the cartridge out and turn it upside down> next clean the openings with a cotton swab< it make take a while as it can get gummy> That should fix the problem
Oct 30, 2009 | Braun Syncro 7526 Electric Shaver
Braun latch
I had the same problem.  Press the blue button to make the "head" of the charging mechanism pop up (probably already stuck this way), then pull it up slowly but firmly.  It should pop out with little difficulty.  Keep pulling it up until you've removed the entire head from the charger, but make sure you don't pull far enough to yank out the wire that attaches the head to the charger base.
You will expose a spring housed in a white tube on the base of the charger.  Pull out the spring, then reassemble.  The head won't pop up automatically anymore, but you'll be able to pop it up by hand--an easy tradeoff for a working clean and charge!
Sep 05, 2007 | Braun Syncro 7526 Electric Shaver
Braun Syncro 7526 Electric Shaver Logo
414 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Gary
Gary
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
