Question about Canon Rebel XT / EOS 350D Digital Camera
Built-in flash auto pop-up problem
Hi , I got my Canon Rebel XTi and when I attempt to take a photo that activates the flash I hear a click and get an error 05 code. This has happened while the camera is set to Full Auto or Portrait. Error says "The built-in flash auto pop-up obstructed". I tried reset camera by turning it off/on. But I can't get the flash to work. purshi
Http://www.flickr.com/groups/canondslr/discuss/72157607437347513/
Posted on Oct 24, 2012
    Genius:
  • 2,985 Answers
Does the 'pop up' pop up? If it does and still says obstructed- closes it and pop it again If it still persists Canon customer support will advise the next move. If a repair price seems high you could perhaps get a separate flash if the camera accepts them.
Posted on Jul 22, 2007
Error 05 flash doesn't pop up
spray a very very small amount of WD40 on the hings of pop up flash (use the thin RED spray tube)
Nov 17, 2012 | Canon EOS 400D / Rebel XTi Digital Camera
When taking pic an "err 05" (the built in flash was obstructed). On this camera eos Digital Rebel xti 400D. How do fix this?
The obstruction is often caused by the interior latch which refuses to move. If the flash cover ever opens, move the latch back and forward a few times which "sort of" re-engages it to its normal position.
Jul 03, 2010 | Cameras
Canon rebel xti flash pops up but says it was obstructed
This is a problem known by Canon, you will have to have it serviced.
Oct 30, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Canon xti and canon 420ex flash giving
Make sure the 420EX is set to E-TTL and set the camera to "P". If is need of more light, increase flash exposure to +1 or 1.5.
Oct 20, 2009 | Canon EOS 400D / Rebel XTi Digital Camera...
I have a canon rebel xti, I partially blocked the pop-up flash while taking a picture. There is an error message on the screen - flash error 05, turn camera off and on again to clear. It is not working....
You can reset all your settings and clear errors by removing the battery pack and also under the camera is an access screw to get to a button battery or two. The type of screw you use a dime or quarter to open. With the battery pack out, remove the button batteries and leave all those out for several minutes and then with the batteries still out, activate the On switch for your camera and leave it in the full on position for 30 seconds. That should drain off all residual power from the circuit board inside. You will have to reset everything, such as your personal settings in Tools and the time and date setting. All of those user set items, but your error message should clear too. If you get the error message again, right away, after reinstalling the batteries and battery pack, then you have damaged the Flash Unit... but I doubt that. Canon makes a good camera and I don't think what you describe would cause that problem.
Regards,
Worldvet
Jan 18, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
The flash on my Canon EOS 400D won't work
Can you pull it up manually, Be careful when doing this but try opening it manually, it is possible that the catch for the flash is just stuck temporarily.
Jan 05, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Canon Camera Rebel XTi reads error 05 and the flash will not pop up
Err 05 means: Something obstructed the built-in flash's pop-up operation. Turn off the main switch and turn it on again.
Prepare to press the flash request button with your left hand. With your right hand, position your thumb and finger to gently pry up the flash head, perhaps using fingernails. Push the button and pry. With that help, it should pop up.
Dec 20, 2008 | Cameras
Canon rebel xti focus issues
I think it might be a lens issue.
make sure you change the macro option. the macro must be activated if you are taking a picture of something which is close to the camera. if it's not activated, the picture will not be focused.
The same will happen if the item is far and the macro is ON.
Aug 14, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Missing Photos Canon Rebel XTi
You can actually still keep taking photos with your camera without loosing the images. The XTi will never delete the images off a card unless you press the trashcan key and tell it to "delete all".
It's always good practice in these situations to have a memory card reader handy. You can pick up a compact flash reader for your XTi for about $14 at BestBuy or many other retaillers.
But to answer your question: Use the ZoomBrowser EX software that came with the camera. If your Picasa is set to automatically connect and download every time the camera is connected - temporarily disable it. That way it wont inturrupt Canon's software (which I prefer).
Mar 14, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Err 05
In my case, I borrowed a camera and when I got it back, err 05 appears. I've located a bit of old orange juice which sticked one of the sensors - you can see the sensors when flash is popped out.
Feb 19, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Canon Rebel XT / EOS 350D Digital Camera Logo
1,066 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
