Question about Whirlpool Dryers
Fins fell off tumbler on Whirlpool Ultimate II dryer
2 of the 3 fins on the inside tumbler unscrewed and fell off. How do I get access to the outside of the tumbler to rescrew in the fins?
  • Whirlpool Master
  • 3,463 Answers
Remove 2 screws under the lint filter cover, then using a spatula or similar, prize apart the top cover from the cabinet, lift top cover and support it.Turn drum by hand until the drum baffles are at the top, and refasten the baffles one at a time.
Then lower cover down and press until it is closed, replace 2 screwa under lint cover.
Job done.
Plz rate this soution.Thanks.
Posted on Jan 02, 2009
One of three fins inside of dryer melted
Did this occur from one dry session to the next? What articles were being dried when this happened. Depending on your answer I would call the manufacturer. This is not supposed to happen (recall?).
Apr 09, 2014 | Whirlpool Dryers
Fins fell off tumbler on whirlpool gas dryer. can i use it with only 2 left
you can still use it but the fins can be screwed in unless the plastic is broke
Feb 17, 2013 | Whirlpool Dryers
Fin that tumbles clothing inside dryer coming loose, how can I tighten it?
These fins are usually screwed on from the outside of the drum. If you're up to it this is a simple but time consuming fix. Take the cabinet off the front of the dryer, the top will come off as well. be careful of the wires from the control console, they will stay attached to the dryer. Tighten the tumbler fins on the drum and then re-assemble the cabinet. Typically the screws you need to access are the same used for the door latch and hinges. They go back together easy ........
Feb 14, 2011 | Maytag Neptune MDE7500AY Electric Dryer
The plastic piece inside the dryer (about 18"
If you are referring to the "fins", there are 3 of them that tumble the clothes, you can refer to some previous questions. You will need to remove the top first and then tighten them up. I have to replace one of my "fins" because it broke off inside of the dryer.
Jan 07, 2011 | Maytag Neptune MDE5500AY Electric Dryer
I have a Kenmore dryer. The fins are real loose, make alot of noise, catch socks, etc. How can I fix it.?
If the first three digits of the model number are "110." remove the lint filter from the top and remove the two exposed screws. Then you can insert a putty knife or similar tool into the gap between the front panel and top, about 2-1/2 inches in from the sides, and push in on the retaining clips. While pushing on a clip, simultaneously lift on that corresponding top corner, and the top will release to swing up.
This will expose the outside of the tumbler. As you spin the tumbler, each spot where a baffle is attached will come into view. After making sure there are no items inside the baffles (coins, pins, etc.), tighten the holding screws.
Dec 30, 2010 | Kenmore Dryers
One of the tumbler fins inside the dryer has come loose and fallen out. How do I repair it
gotta open it. usually screws are inside dryer. 3 screw hold it. make sure u unplug unit b4 putting hand inside
Feb 12, 2010 | KitchenAid Dryers
Lint has built up inside the 3 plastic fins of Whirlpool Duet
What is the model Number. Does your lint screen go thru the top or is it in the door.
Jan 31, 2010 | Whirlpool Dryers
Remove and replace fins in drum
ok
1. take off the door hinge screws,
2 take off the two opposite the hinge
3. lift the door up and out
4. graqb the slim side walls on either side of the door way
turn them in and pull the whole panal tword you
5. once you have the door cowel off, you should see two top dogs screwed down with 2 5/16
romove those and the dogs
6. with the top dogs off you should be able to lift the top, like the hood of your car
7. once the top is up , you will have access to the tumbler top and the screws for the fins should be right on top
Oct 17, 2009 | Maytag Neptune MDG6800 Gas Dryer
A tumbler fin
This isn't much help, but those fins will break off. I have had them break off. I am ordering some new ones, called "baffles" and will be installing them. I hope I can the top open on the machine.
Jun 16, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Dryers Logo
168 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De GO PATS
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
