HI.... First you need to check the audio propertities. Go to Start->Right click on My Computer->Properties->Hardware->Device Manager->Under sound,video tab check if anything is disabled or if it is showing an yeloow sign... then you need to install the audio drivers again from motherboard CD....
Go to Control Panel and check the Sound and Audio device properties, if it is muted then adjust it properly.... If need some more help plz contact..
Thank you....
Is the speaker system set up in Windows as a 5.1 speaker system? If so, the problem with the sound is the program used to play the audio. For example if you are watching a movie and the player used does not support 5.1 then it will not play the audio properly. If the sound works correctly playing a game in 5.1 you should be able to figure it out from there.
<br />If your laptop has a line-in jack, follow the instructions above for connecting a music player to a desktop computer. But to connect a music player or other audio device to most laptops, you'll have to plug it into a microphone jack. To do so, follow these steps:<br /><br />Click to open Sound. <br /><br />Click the Recording tab, click Microphone, and then click Properties.<br /><br />Click the Listen tab, click the Listen to this device check box, and then click Apply.<br /><br />Click the Levels tab and make sure the Mute button looks like this . If the button looks like this , click it to turn on sound for this connection, and then click Apply.<br /><br />Play some music or other sounds on your device to test the volume coming through your computer speakers. Select the slider under Microphone, drag it right or left to increase or decrease the volume of your audio device, and then click OK. You might also want to adjust the volume on your device.<br /><br />Note<br />If you hear noise coming out of your speakers, try reducing the volume on both the music player and in the Levels tab. The microphone jack is designed to receive sound from a microphone, which is different than sound coming from a music player
Most of the sounds you are hearing good are background sounds. If you are running a surround system, you might want to try adjusting the output of your primary speakers, checking for the correct setting on your receiver, and verifying that your central audio is in the correct section ( receiver output ).
If you are not using surround sound, Check the in-game menu (Pause) for an audio section, some games allow you to turn the character voices up and the music down. If you don't have that option, try using a new output cord from your xbox to Tv.
I installed my soundcard which is the sound blaster SE audigy but when i try to test the sound i see that it does not sound separately.What i have to do to make them sound saperately when i'm testing it ?
there is one way to try in order to check if your speakers are working for those gaming sites. try to uninstall and re-install the audio driver for your computer.
First things First!
1) check on other speakers to see if your iPod work fine
2) check connector for loosing electric connectivity.
3) check with your headphones to see if your iPod play music well.
4) Check, power on the computer spk. you got. or the input that is working right.
Good Luck
Suggest that some sound in the game set up is at low or on muit.
the speakers ar dumb thay willonly play sounds from the pc the speakers do not decide not play some sounds and not others.
