Question about Frigidaire FDE336RE Dryer
Do i use 30 amp double pole breaker - Frigidaire FDE336RE Dryer
  • 706 Answers
Hello manofpeace,
Many standard electric dryers run off a 30A double pole breaker. You need to make sure the wiring to your receptacle is sized accordingly and the pigtail power cord from your dryer is of the correct size ( meaning rated for 30Amps or more)...
Regards,
Rick
Posted on Jan 04, 2009
Can 40mp dryer and 40 mp range be computable
Hi - I'm an electrician an would like to help you with your question.
But - Umm.. huh?
By "40mp" Do you mean 40 amp? They are both "computable" but I suspect that you meant compatible. If so, yes, 40 amps is 40 amps regardless of what it supplys, as long as the wire is the right type and size. I haven't seen a 40 amp residential dryer though. Residential electric ranges and electric dryers are both 240 volts - but the dryer is usually a 30 amp circuit (#10 copper) and protected by a double pole 30 amp circuit breaker. The range is a 40 amp circuit (#6 aluminum) and protected by a double pole 40 amp circuit breaker.
If this doesn't answer your question, please explain in greater detail.
Feb 07, 2013 | Connecticut Electric Electrical Supplies
I have a Square D QO panel. I am trying to install a couple of 2 pole thin line breakers. I bought 2 QOT2020 breakers at Home Depot and they will not fit. I am aware of Square D's Homeline series...
im going off memerory right now but i seem to recall that you may only be able to instal that breaker in the lower part of the panel maybe check to see if the buss bar is a little short to acomadate the 2 pole breakers i will check it out in the am sorry if im mistaken
Jul 23, 2011 | Square QO 30 Amp Double Pole Circuit...
I have a Maytag dryer model MED5740TQ0 that won't start. Dryer was recently moved to a new location. House was being remodeled so plug and breaker had to be installed. Plug is a 3 prong and dryer had 4...
If you are only getting 120v to the dryer, you still have a breaker tripped. It should be right next to the single pole 30. It takes 2 breakers to get the 240v you need to run the dryer. Try resetting another breaker expecially the ones marked 30amp. You do need to get a double pole breaker installed even for safety reasons.
Apr 12, 2011 | Maytag PYE2300AY Electric Dryer
There is the liquid seeping out of the breakers, it is not water the box is dry and it feels like an oil of some kind. breakers are working and are not hot. i have not seen this before. what is it and what...
It is oil. It's used to extinguish the arc.
When a circuit breaker trips, there is an Arc of electricity made inside the breaker, due to the contacts.
The contacts are instantly brought away from each other.
There are three methods employed to extinguish that arc.
[Extinguish the arc. Non-technical explanation. With out some medium to extinguish the arc produced inside, it would go Z-z-z-z-z-z-z-z-z-z-z-z-zap, instead of z-zap]
Oil, Air, and Sulfur Hexafluoride.
So yes, as long as the circuit breaker doesn't have to trip, and produce the arc inside, it is a working circuit breaker.
Is it a safe unit?
NO
The method employed to extinguish the arc if the breaker trips is leaking out.
Replace all breakers that are doing this.
Average cost for a GE single-pole 15, or 20 Amp is around $11 here. A few dollars more for 30 and 40 Amp, but usually double-pole breakers are used for 30, and 40 Amp.
Nov 18, 2010 | GE Circuit Breaker THQB BoltOn 1 Pole 15...
Bryant brd 30-30-30-30 quad replacement
You could get em here :
http://www.baybreakers.com/catalog/search.html
Why anyone would use a twin 2pole 30am breaker I'll never understand.
There is no way this size breaker could match up in quality to two full size 2-pole 30 amp breakers. If one wants to double up, do it with the 15-20 amp sizes.
Jul 16, 2010 | Bryant Westinghouse Bqc Quad Circuit...
Double breaker will not shut all the way off to reset to on
The breaker is bad and needs to be replaced when they do that.
Jun 29, 2009 | Square QO 30 Amp Double Pole Circuit...
Installing 30 amp square d breaker
if you have another breaker, try installing another one.(i have gotten bad ones from new all ready). if you dont have another breaker, disconnect or unplug what ever is controlled by that breaker. if it still does it while everything is unplugged/disconnected, there is a short in the line.
Jun 26, 2009 | Square QO 30 Amp Double Pole Circuit...
My double pole 30 amp sqaure D breaker gets a little warm...
There is loose connection somewhere.Might want to look at the wires coming to the panel.
Mar 15, 2009 | Square QO 30 Amp Double Pole Circuit...
Fridgeidaire clothes dryer
I will try this again i don't think i posted it properly.
On the power cord where it connectes to the dryer make sure the red and black wire goes to the outside screws (L1& L2) the white goes in the middle and the green goes to the dryer cabinet.
If you have the red or black going to the middle one it will trip the breaker.
Oct 06, 2008 | Whirlpool LER5636P Electric Dryer
Dryers Logo
57 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
