Question about Brother CS-100-T Computerized Sewing Machine
Put a new needle in?? How??
The needle popped out while I was sewing, it hasn't broken, but I can't figure out how to put it back...
    Problem Solver:
  • 9 Answers
Also make sure the flat side of the needle is not facing you when you put it in.
Posted on Jan 06, 2009
There is a small screwdriver that comes with the sewing machine accessories. You need that to loosen the screw on the side of where the needle goes. once the screw is loose you can slide the needle up and then tighten the screw. Just make sure that the needle isn't bent at all because it will get stuck!
Posted on Jan 05, 2009
THREAD POPS
Is it perhaps poor quality thread? Avoid old or bargain bin threads,. Also, might try a brand new needle of the type suitable for your thread and fabric. Have you verified the needle eye is the correct size for the thread?
Understanding Thread Tension Threads
All About Needles SCHMETZ Needles
Jan 31, 2018 | Brother SE-270D Computerized Sewing...
My needle broke and a piece of metal fell out of machine
just adjust to needle in fix to strait in needle clamp hole it operate to needle strait to hole so needle do nt break but needle is best buy qualtity
Aug 31, 2008 | Brother XR-65t Mechanical Sewing Machine
How to put a thread cutter in husqvarna viking desinger se sewing machine
I believe the plastic cover (gray?) toward the end of the arm (left of the needle plate) is removable by prying (gently) on the front edge and sliding toward you. Unless the cutter is broken, you should be able to figure out how itall fits back together.
Dec 21, 2012 | Husqvarna Sewing Machines
I need to change a needle in a Simplicity Serger SL370 but can't figure out how to do it....
for the two upper needles you use the "L" shaped tool that came with the serger. All you do is stick it in the hole for the needle you need to change. Upper leftish one is for the one on the left, lower rightish one is for the right side needle. That loosens the neelde and it slides down. Put new needle in, slide it up, put the L tool back in the hole and tighten.
Dec 04, 2010 | Simplicity SL370 Mechanical Sewing Machine
Makes too much noise
Check that your needle is fully up into the needle housing, and is in flat shank to the back.
Also change the needle if it has been in the machine for more than 6 hours of sewing as the needle will go blunt and this can make squeaking or popping sounds as you stitch.
Lastly, are you sure that the bobbin case is in correctly and hasn't been put in incorrectly. It should have a stitch finger which locks up into the top of the rotary hook if its a vertical bobbin case and bobbin design which I'm pretty sure your machine is.
Jul 27, 2010 | Elna 2005 Mechanical Sewing Machine
METAL PLATE COVERING BOBBIN WON'T STAY DOWN
Take it apart again and compare the original screw with the one you substituted. If they are not the same size, you will need to get one that matches the original.
Re-place the needle plate and when firmly in place, put the screws back in.
Mar 03, 2010 | Sewing Machines
W3300 hook and needle
I had many broken needles before I put my thread on a thread stand behind my machine. I found that the thread was winding around the thread post and causing a jam and thus, breaking my needles. This solution worked!
Oct 30, 2008 | White Sewing W3300 Computerized Sewing...
Bobbin help please!
Take out the raceway and check for broken threads/lint. Unthread the machine and put in a new needle taking care to insert it correctly. It may be that the needle is slightly bent. Put everything back carefully and check it is running smoothly with NO THREAD first(no bobbin thread either-use an empty bobbin). This will prove there is nothing catching. If it catches when you thread it then you are having a problem with incorrect threading.
Mar 24, 2007 | Kenmore 15212 Mechanical Sewing Machine
Brother CS-100-T Computerized Sewing Machine Logo
69 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
