I would like to purchase a manual for my gate way computer
  • 741 Answers
Go to www.gateway.com, find the support page. Type in your model number and it will allow you to download the manual for free.
Posted on Jan 01, 2009
What is the u shaped component on the rev.counter card called? Where can i purchase this component?
  1. Mighty Mule Parts - Gate Opener Parts & Accessories‎
    Adwww.mightymule.com/Accessories‎Cable Gate Lock
  2. Driveway Alarms
  3. Gate Opener Kits
  4. Where to Purchase
Search Results
    Mighty Mule Store ' Genuine Mighty Mule replacement parts
    www.mightymulestore.com/Mighty-Mule-Gate-Opener...Parts-s/21.htm
    Genuine Mighty Mule Replacement Parts. Choose a Product Category. Mighty MuleFM200 Automatic Gate Openers · Mighty Mule FM350 and FM352 Gate ...‎Mighty Mule 500 Parts - ‎FM350 or FM352 - ‎MM600
    Mighty Mule 500 Parts ' Shop Accessories and parts for the ...
Jan 01, 2016 | GTO Mighty Mule Automatic Gate Opener For...
We purchase 5 unsynced transmitters Monarch 318LIPW1K which are the same model as we are currently using on our gate. Does anybody know how to program these transmitters to our gate? Our installers ar
The manual says the installer or retailer will provide you with programming instructions. Here is the link to the manual. http://lib.store.yahoo.net/lib/yhst-16416632405890/TS-Monarch-318LIPW1K.pdf
Feb 05, 2015 | Linear Monarch 318lipw1k Compatible Linear...
We purchase 5 unsynced transmitters Monarch 318LIPW1K which are the same model as we are currently using on our gate. Does anybody know how to program these transmitters to our gate or have programmin
You need to start looking at the gate and program the gate to recognize additional transmitters, is what I conclude of this situation of yours.
Feb 05, 2015 | Miscellaneous
I lost my remote for my Viking R-6 gate opener. the store sold me a liftmaster 890Max remote for it but how do I program it. I can not find the learn button on the viking R-6 gate opener????
The Liftmaster remote you purchased should have come with instructions for programming unless it is preprogrammed to work with your Viking gate opener. You may have to return to the point of purchase for clarification.
Oct 19, 2014 | Building Materials
Open electric gate manually
if no power to gate opener..unbolt the gate from the chain and open it manually..may have a power outage..
Jan 11, 2014 | Home Security
I want to retrofit my moultrie atv spreader manual feed gate with an electric feed gate. They did not offer the electric feed gate when I purchased my current model. Both models are identical except for...
I am also looking to retro fit my manual gate spreader with the electric gate. I emailed Moultrie with the question about it and they emailed back about two weeks later that I needed to contact customer support. I call customer support but hung up after being on hold for 15 minutes. I have not found the electric gate anywhere else so I guess I will have to call them back. At this point it appears that is the only way to get one. I have been told the retro fit works with no problem.
Moultrie Customer service: 1-800-653-3334
Jan 14, 2013 | Moultrie ATV Spreader With Electric...
Espresso swing gate
Hi
If you have a problem with your Safety 1st Wooden Swing Gate we recommend you return to your retailer with your proof of purchase to discuss assistance, exchange or refund.
Apr 22, 2012 | Safety 1st Wooden Swing Gate Espresso
How do I purchase new hinges for the baby gate?
Looks like you have to call the company.
I need to replace hinges for the safety 1st Perfect Fit gate and will do soon. If I remember, I'll provide an update.
Dec 27, 2010 | Safety 1st Perfect Fit Gate Fits 30" 42"...
Liftgate won't open automatically
To open the lift gate manually, use the door unlock switch located on the drivers door. This should unlock the lift gate as well. Go to the lift gate and lift the handle to open the rear gate.
Your power lift gate is computer controlled. Sometimes there will be a faulty input sensor or part that will show the incorrect data to the computer, therefore the computer will not go through its normal functions.
In most cases its the problem of lift gate latch assembly.
To get it tested and confirmed there is a troubleshoot guide provided by the service center. To perform this troubleshooting guide you will require a scan tool to diagnose the exact problem.
the troubleshooting procedure is as follows:---
Please use the following information below when diagnosing an inoperative lift gate. Disconnect the connector at the lift gate latch assembly. With the lift gate latch connector disconnected, the 3 signals for the ratchet, pawl, and the sector should be inactive on the scan tool.
Install a 3A fused jumper wire between each signal circuit terminal (for the pawl, sector, and ratchet) and the ground circuit terminal 2. Monitor the scan tool as each individual circuit is jumped to ground, the scan tool should read "active".
If either tests above fails, check the wiring for the signal circuits, low reference circuit, or try a power lift gate control module from a known good vehicle. If both tests above pass, monitor the internal switch inputs in the lift gate latch assembly for proper operation.
3. A) with the lift gate in the open position, the ratchet and the pawl should read "active" and the sector should read "inactive"
B) With the lift gate in the secondary latched position, the pawl should read "Inactive" and the ratchet and sector should read "active"
C) With the lift gate fully closed, the pawl, ratchet, and the sector should all read "inactive".
4.If one of the internal lift gate latch assembly switch inputs are not reading correctly in one of the positions above and the vehicles passes test 1 and 2 above. Replace the lift gate latch assembly.
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
This should help you.Thanks.Helpmech.
Dec 04, 2010 | 2006 Cadillac SRX
Evenflo model 10502 baby gate
Here is a link to Evenflo's website.
http://safety.evenflo.com/cs/sc/cssc_RD.phtml/
You can register your product, order instruction manuals and replacement parts. They also offer instructional videos, checklists and suggestions for keeping your baby safe. The site asks for the Model #10502, also the manufacture date (show example of where to locate.) I believe the instructions are free.
I order replacements parts in advance for items I can not live without. Living all over the world makes it difficult to get assistance in a timely manner. Also for gates that have permanently mounted hardware, I buy extra sets of mounting hardware. This allows me to move the gate, saving money by not having to purchase multiple gates.
This is not one of those times to "wing-it." Safety gates need to be installed per manufacturer specifications.
I hope this helps, good luck.
Kym McC
Oct 01, 2008 | Baby Gear
Computers & Internet Logo
David Payne
David Payne
