Question about Whirlpool LER2614JQ Electric Dryer
Dryet My dryer will not cut off, it doesn't matter whether I use automatic dry or timed dry, the dryer continues to run until you open the door, and then the cool down cycle is skipped.
  • niko58 Apr 02, 2008
    timing knob just keeps going through all the cycles until dryer is unplugged. is this a bad timer?
    President:
  • 878 Answers
Shelly on some of the older models they used a inline resistor on the dryers timer. It looks like a inline fuse comming off the timer. If it goes bad the timer will not stop. Check the attachment. Cost around 17.00, Catriver, post back. Part number 3401076
Posted on May 09, 2007
Dryer continues to run when I open the dryer door.
The door lock is more than just a latch; it is an electrical interlock. From your description it is likely that the interlock has failed
Jun 02, 2013 | Maytag Neptune MCE8000AY Electric Dryer
Timer goes to 99 minutes and clothes note drying all the way
Hi cayjr1
Clogged Vent
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry.
But...if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Heating Element
Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace the heating element. You can check for an ohm reading but will need to refer to the service manual for proper reading. This sometimes on the tech sheet located somewhere on the dryer. Usually between 9-13 ohms.
Cycling thermostat
Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork . This thermostat usually has four wires going to it. Check the 2 terminals that are opposite each other and are the closer together of the 2. These 2 terminals should have continuity. If not replace the thermostat.
Please take time to rate me
Bud
Oct 09, 2012 | Maytag Neptune MDE5500AY Electric Dryer
Dryer only shuts off when door is open
test the push button for open and faulty .However see this causes too.
Clogged Vent
This cycle continues until the clothes are dry. But...if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Heating Element
Cycling thermostat
Sep 27, 2012 | Frigidaire Dryers
Maytag Neptune dryer was always drying on high heat, now won't turn on
see this causes and fix it. God bless you
Power From The House
Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Thermal Fuse / Thermal Cut out
On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel or behind the front panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing or is sometimes round and made of metal and plastic.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse this is the most common reason for blowing the fuse. (You can't re-set this type of fuse.)
Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Sep 27, 2012 | Maytag Dryers
Unit runs, not drying clothes completely
Door Switch
Wiring
Sep 24, 2012 | LG DLE0442 Electric Dryer
Taking a long time to dry.
Hi dawansd
Clogged Vent
Heating Element
Cycling thermostat
This is a Free answer, Please rate me.
May 25, 2011 | Dryers
Dryer will not turn off
  • The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
  • When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
  • The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
May 20, 2009 | Dryers
Maytag dryer timer keeps running
Your dryers timer contacts have fused to gether.
The only repair is to replace the timer.
Mar 25, 2009 | Dryers
Kenmoore 70 series Buzzer will not stop
buzzer is built -in the timer you all should replace it if you really want it solved they have done their work over the years. It's not something you can just go in and unplug or cut sorry. Good Luck. Post your make and model numbers next time please.
Dec 19, 2008 | Kenmore 60172 Electric Commercial Dryer
Whirlpool LER2614JQ Electric Dryer Logo
111 people viewed this question
Top Whirlpool Dryers Experts
Sal De
Craig Butler
Craig Butler
Marvin
Marvin
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
