Question about Kitchen Ranges
I wanted to know how many Jennair downdraft electric ranges were out in 2000, with a sealed 2 unit burner and a grill and are there still replaceable plug in units for them?
  • 126 Answers
Modules are still available for some models but you need the model and serial numbers of the range to find out what is available to fit it. The customer service number for Jenn-air is
800-536-6847. You might call a local appliance store if they carry Jenn-air products.
Posted on Jan 02, 2009
Indicator light always on
It really looks like a welded contact point in one of the burner switches going to the indicator light circuit. If you can, open the panel and lookk for shorts going to the indicator light.
Nov 28, 2012 | Jenn-Air 703650 203650 Downdraft Cooktop...
Jennair model # JDS9865BDP Dual-Fuel Modular slide-in Range Pro Style Burners are too hot to do regular moderate cooking. Wife says the left side burners (where grill goes)can't be adjusted low enough to...
pull off your selector knob and shine a flashlight down the shaft, depending on your model, you may have the adjustable mmodel
at the bottom of the selector shaft, you may see a flat head screw adijudt it at ver small increments
i believ a 1/4 turn in should turn your flame down quite a bit
hope thsi helps
Nov 02, 2009 | Jenn-Air JDS9865BDP Stainless Steel Dual...
How do i replace my burner on my jenn air ceramic cook top . it has the down draft feature in the centre
1) turn off power at the breaker. 2) remove hold down screws 3) pop up cooktop out of counter top 4) remove knobs and downdraft grille 5) remove ceramic top (screws around outside and also in side grille opening) 6) unplug burners replace with new burner
Sep 17, 2009 | Jenn-Air JED8430 Electric Cooktop
CFM's pushed out by blower for jennair S176W range
hi there,
initially downdraft ranges from 6oo CFm to 1600 CFM within the pushbutton control.
CFM means (cubic feet of evacuated air per minute)
Hope this initial info/idea helps.
Let me know for further clarifications,
Jun 04, 2009 | Jenn-Air JES9860 Electric Kitchen Range
Downdraft
I would double check that the installer used the correct vent hood outside. The correct one has a spring that keeps the outdoor flap closed when not in use. Cleaning the outdoor flap area may also help it seal a little better. Even if the right hood was installed, you might check to see there is a spring present (or signs that there was one.
I have never had air blow out the downdraft, but I do feel cold travel to the fan unit which makes the floor cold in front of the range.
Jul 12, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Will not cook properly with downdraft vent on. JDS9860AAP Range
You can purchase a 2 burner cartridge. However, the problem I'm having with that is the gas is too high and is unable to cook anything on low.
Jan 03, 2008 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Installation of down-draft exhaust duct for Jenn-Aire cook top
We're buying a JES9900BAF for an island and found ducting instructions in the installation guide. Go to jennair.com and find the page for your range model. Then click on the "Specs/Literature" tab (it's about 2/3 down the page). The installation guide is a PDF document.
Nov 07, 2007 | Jenn-Air JGR8850 Gas Kitchen Range
JENNAIR DOWNDRAFT COOKTOP
bibman: Sounds like the control switch or possible loose wiring. Take the element out and test the slots for voltage. You should get 220 Volts when on high.
DMA Jennair The fan motor is bad and needs to be replaced.
I suggest a new cooktop as THIS IS THE WORST DESIGNED COOKTOP I HAVE EVER USED. Not enough power, very hard to clean,
Aug 20, 2007 | Jenn-Air 30 in. CCE3401 Electric Cooktop
Kitchen Ranges Logo
101 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
