Question about Philips Universal PH301S Remote Control
Need Sv2000 Wv20d5 Tv Dvd Combo code for comcast remote
I need a remote code for Sv2000 Wv20d5 Tv Dvd Combo to use with a Comcast remote... I tried the search method and each time i do it 30-45 minutes and nothing happens
Thanks
3 Suggested Answers
SOURCE: REMOTE CODE
The code your looking for is 0247. It will be listed as a Sylvania. It controlled both tv and dvd for me.
Posted on May 11, 2009
  • 3 Answers
SOURCE: Need code for SV2000 tv/dvd combo & Comcast remote,
Any remote supporting Sylvania TV/DVD combos will work for these tvs. I had a Zenith universal remote working with this TV.
Posted on Feb 23, 2011
NEED CODES 4 TWO COMCAST REMOTES 4 EMERSON COMBO DVD TV MODEL LD195EMX
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts.
http://electro-medical.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Oct 30, 2015 | RCA Televison & Video
Need a remote code for comcast dta to work with my GPX TDE1380 tv dvd combo
There is no setup codes for GPX with Comcast DTA remote control.
Apr 23, 2012 | GPX TV6000 9 in. TV/DVD Combo
I have a philips universal remote and i need the code for my tv which is a sv2000 with the dvd player built in
Hello crystal and welcome to FixYa. I think you were searching for the remote codes for a SV2000 TV/DVD Combo. Generally speaking TV/DVD Combos do not have a traditional codeset but instead use a DVD one instead. Follow these steps below.
Search the TV codes Using AV1 or AV2
Press and hold Mute and Select for two blinks
Enter 9 11
Enter 2
Press and release Volume Up
Press and release Channel Up until you hear the volume change
Next after hearing the volume change press Select to lock in the code
You should be all set. I hope this solution works out for you and good luck.
Apr 22, 2011 | Televison & Video
Need Comcast DTA remote to control Panasonic TV/VCR combo
Try website 1-800-Remotes Factory original.To buy an exact remote or very close to the original.
Apr 25, 2010 | Broksonic CTSGT8118T 13 in. TV/VCR Combo
Can't get my Phillips universal remote to program my tv controls on my sv2000 t.v/dvd combo.
If you already tried the tv codes for your make of tv, the manufacturer suggests using the dvd codes for your same tv make sometimes they use the dvd codes to activate or control the tv on some of those tv/dvd combos. If all this fails you can always use the code search procedure described in your remote's manual, but you need to be patient because this procedure will scan thru all the programmed codes(vcr,dvd,sat,cabl etc.) one at the time.
Jan 16, 2010 | Philips Universal PH301S Remote Control
Nov 26, 2009 | One For All URC-4021 Remote Control
Comcast remote code or an generic code that might work
CLICK HERE to select the style remote you have and view the manual - including code lists.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Apr 26, 2009 | Televison & Video
No code available to program my SV2000 tv/dvd combo
The manufacturer for this television is Sylvania, the standard codes for TV/DVD combos will work just fine.
Apr 02, 2009 | Televison & Video
Need remote control code for Panasonic PV-DF2703
I found a newer Comcast PDF file that shows a 5 digit number for tv with vcr ( no mention of DVD) but the code worked to turn on the tv and cable box together. My problem is it won't work the volume, yet
https://www.comcast.com/MediaLibrary/1/1/Customers/Customer_Support/Digital_Cable_with_OD/Digital_Cable/remotes/Remote_M1067BX3.pdf
Dec 24, 2008 | Panasonic PV-DF2703 Triple Play 27 in....
Televison & Video Logo
372 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
