Question about Cameras
Megxon C480 Digital View Camera - Zoom does not work
When I turn the camera on, the zoom just "rattles inside" but does not come out or allow me to focus. Details below. Please advise.
Megxon C480- Digital View Camera
8x zoom Optical
4.0 Mega pixel
4x digital zoom
When I turn the camera on, the zoom does not function. It sounds like it is trying to work, but all I hear is a rattle inside.
Display reads Zoom Home! Errow SW1
Please advise.
Janet
  • 10,594 Answers
Camera lens mechanism got problem with loading gears. Rattle sound shows gear is worn out and afraid that you need to replace complete lens assembly. Please ask an estimate from local camera repair shop. It will cost you more then camera worth.
Posted on Jan 01, 2009
  • Cameras Master
  • 19,396 Answers
I quote from you :
" the zoom just "rattles inside" but does not come out"
That means that there is a mechanical problem with lens assembly, and camera is on lens error.
The camera must be taken apart to fix this.
  • Ginko
    Ginko Jan 01, 2009
    If the lens makes noise but the lens assembly does not extend , that means that there is an internal problem.
    If this is an humming noise, it can be a faulty lens motor, in this case the technician access the motor and test it by energising it.
    More likely the problem is due to a mechanical fault concerning the lens assembly.
    Try hitting the back of the camera (gently not to damage it) with the palm of your hand while you start the camera at the same time.
    Try also spraying canned air on the lens cylinder in case there is dust or sand locking up the lens.
    If that did not work, it will be necessary to take apart the camera to fix the problem.
    In this case it is better to take the camera to arepair shop, if you do not want to risk causing more damage to the camera.
View finder usage
There's a small button next to the LCD screen that allows you to switch between LCD & viewfinder.
Feb 03, 2009 | Olympus Camedia C-740 Ultra Zoom Digital...
Zoom does not work on Megxon C480 does not allow focus
what is the screen say is happening
Jan 02, 2009 | Cameras
I regret that there is no repair option in general for this type of thing.
Replacement is the only option
Jan 01, 2009 | Cameras
Optical zoom problem in movie mode
Your camera is not broken. That's by design. Canon cameras do not allow optical zoom use while in movie mode. Canon claims that using the optical zoom in movie mode would cause excessive noise in the movie. However, you can use digital zoom in movie mode. You'll need to go into the menus (press the menu button) and turn digital zoom "on" if it's currently off.
Oct 11, 2008 | Canon PowerShot SX100 IS Digital Camera
Zoom
Hey bello205,
This camera does not allow the user to actually turn off the optical zoom, but does allow the user to shut off the digital zoom. If you are talking about the digital zoom make sure it is turned on in through the menu system. As far as the optical zoom goes make sure you are not in playback mode. If this doesn't work you can try having the camera reset to the original settings every time you shut off the camera by choosing this option under the setup menu in playback mode. If none of this works have the camera looked at by an authorized service technician.
Sincerely,
Allan
Go Ahead. Use Us.
May 01, 2008 | Olympus Camedia C-720 Ultra Zoom Digital...
Megxon c480
I hit mine with a hammer It works well again now.
Apr 08, 2008 | Cameras
Optical vs. digital zoom
It's important to understand this difference, as you could be disappointed with the results if you use one rather than the other. Optical zoom works like the zoom on a traditional film camera. When you push the button to zoom in or out, physical lens elements move inside the camera, reducing the field of view and making the object you're shooting appear closer. Digital zoom, on the other hand, has no moving parts. The camera interpolates a small portion of an image to artificially restore the file to its original size. Using its electronic brain, the digital camera analyzes what it sees and digitally zooms in, usually two or three times closer. Unfortunately, digital zoom also reduces the resolution of an image, so your picture will tend to be more pixilated than the same image taken with an optical zoom camera. If you're just snapping an image to e-mail to a friend, this loss of resolution won't be so noticeable. But in situations where the highest quality counts, skip the digital zoom and use your PC's image-editing tools to zero in on your subject.
Sep 08, 2005 | HP Photosmart 120 Digital Camera
Cameras Logo
47 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
