Question about Garden
Stihl strimmer will not start
No start condition. Good spark, new plug, gap set at .030. fresh fuel/oil, cleaned carb, getting fuel to plug. Plug gets wet after a few pulls.Tried choke, no choke, throttle and no throttle starting. The most I can get it to do, is spit out of the carb throat.
  • russjennings Jan 02, 2009
    hmm, that's what it acts like, all right. Excuse my ignorance, but how do you set the timing on something like this?
    Sergeant:
    Champion:
  • 239 Answers
Timing
Posted on Jan 02, 2009
Carb settings for Stihl FS160
Here's a link to your owner's manual,look at page 26 for carburetor adjustments,I have 3 stihl's,a blower,weedeater and chain saw,had them a long time,never had to adjust the carb.What problems are you having?Clean your air filter or replace it if's real dirty and can't get clean,use 50;1 regular unleaded gas and oil mixture,put a new plug in it,same as you were using,Autozone has them cheaper than the Stihl dealer.Are you using your choke and throttle correctly when starting?On mine,I set the throttle,lock it in,put choke on close,pull a few times,no more than 5,then open choke and pull,it should start,is your spark plug getting oil-gas on it,if so then your flooding it at start up,use fresh gas mixture.I wouldn't adjust the carb. https://www.stihlusa.com/WebContent/CMSFileLibrary/instructionmanuals/FS160_180_Manual.pdf
Jun 14, 2017 | Stihl Garden
Saw would not start so I bought a new carb and it still won't start. Fresh gas, new plug, etc. How do I determine if I am getting spark to the plug and is it difficult to check the magneto or device that...
I would suggest finding an inline checker so you can visualize the spark without getting shocked for damaging the plug boot.
If your carb is working then when you take out your spark plug it should be covered with fuel. This could be a sign of no spark or it might be a sign of a dirty air filter causing an extreme rich condition. Try starting the saw with a clean plug and no air filter in place to rule this out. If it is dry you either have a fuel line issue or a blocked exhaust. Chain saws have spark arresting screens on them that can load up with unburnt fuel and oil *(from a bad carb or blocked air filter) be safe and good luck!
Mar 07, 2015 | Stihl Genuine Ms 210, 230, & 250 Chainsaw...
My stihl fs56 strimmer will not start,i have a spark & fuel new plug cleaned carb help please
if you have spark and fuel then id be looking at lack of compression.. damaged piston ring or damaged crank seal/gasket
Apr 15, 2014 | Stihl Garden
Mac 335 chainsaw won't start /run
Start with basic stuff first, drain the fuel tank and re fill with clean fuel oil mix, press the purge bulb ten or so times to pull the fresh fuel into the carb, now try again, if no better remove the spark plug and check for a spark ( make sure the ignition switch is on ) no spark try a new plug, still no spark check for wires shorting out, if ok replace the ignition unit, if it has a good spark is the plug getting wet with fuel, if not it may have a blockage in the carb, this will require a carb re build, if the plug is wet remove the muffler and check the condition of the piston through the exhaust port, any damage here and the saw will require a re build and possible new cylinder and or piston.
Jan 22, 2011 | McCulloch Garden
AH520 Tecumseh engine will not start; no spark to plug. Checked for spark to plug; no spark Cleaned fuel line from tank to carb. Used fresh fuel. Snowblower has not been used for about 15 years.
I would recommend a serious carburetor cleaning or even installing a new rebuild kit after the machine setting up for so long. The spark problem must be checked for either the (magneto to flywheel air gap) or the condition of the electrical points and condensor on it (if this older model has them)
Sep 19, 2010 | Husqvarna Garden
I have never been able to start my homelite mighty lkite 26cs weed eater.......
check that fule is getting into the engine and you have a good clean spark plug with a good spark on it and the air filter is clean
try tipping a cap full of fult (2 stroke mix) into the carb throte right into the engine then try to start it up,,if it spluters into life and stops the carb jets are blocked up or no fule is getting to the card
Jun 27, 2010 | Homelite Mighty Lite Lawn Trimmer
MTD Yard Machine 22'', 4.5HP, 190cc push lawn mower won't start
The primer bulb might be damaged, or the carburator diaphram could have been damaged if carburater cleaner was used.
Jun 14, 2009 | Garden
Garden Logo
307 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
