Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
Need to clearn front bottom of refrigerator
We have a Whirlpool Gold, Model Gs6shexms00. Does the plastic panel come off at the bottum in the front, directly below the doors. I would like to vacccum as it is now very dusty.
If so, how do I take it off w/o breaking it?
Thanks
  • 306 Answers
That cover does come off it is held on by two clips one at each end. Take a flash light and you will have to lay on the floor to see the clips after you take it off and on a few times you can just fell the clips give way when you pull it off. And if you have a bottle brush about 18" long would be very helpful also. You will see a bunch of dust around the coils and when you clean them your frig will get much colder. Good thing to do every 6 months or so. ken
Posted on Jan 12, 2009
Water leaking and freezing in bottom of freezer and leaking on the floor it is a whirlpool gold series model #GI6SARXXF04
sounds like your defrost drain is clogged up. it can be cleaned by taking off the metal or plastic panel and cleaning out the defrost drain hole. a steamer works best.
Dec 20, 2016 | Whirlpool Refrigerators
Whirlpool side by side refrigerator laeking form
Hello
In the freezer section. Behind the lower rear wall is the coils and just below that is a drain. If you will remove any ice and use a coat hanger or screw driver to push down through that hole you should be able to get it unclogged. Take a small cup of water to verify that you have it unstopped and your done.
#225 in the drawing.
I hope this helps.
May 29, 2010 | Whirlpool GS5SHGXKQ 25.3 Cu. Ft. Gold Side...
Ice Dispenser not dispensing ice
Remove the top freezer door hinge cover and disconnect the plug there . This will remove power to the dispensor . Remove the dispensor grill , and also the 2 screws at the bottom of the dispensor front . Lift the front up and out , and remove the plug on the front . You should now see the white switch bracket . On the left side , is the ice dispensor motor switch , when usually , one of the spears holding the switch breaks off , not allowing the ice dispensor to work . If this is the case , the part number is 2180226 . Only held on by 2 screws . When/if replaceing , be sure to put the plastic spacers in the correct position next to both switches , and be careful not to break one of the spears , holding the switches .
Oct 31, 2009 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
Fan Noise
There should be 4-6 screws holding it on. They may be covered with plastic plugs. just pop those out.
Jun 19, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Freezing water in bottom of Whirlpool Gold
remove back panel inside freezer. you will see a tray at the bottom with a drain hole in the middle and this is blocked with ice. melt ice off with a hairdryer and follow up with hot water till water flows away freely
Nov 26, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Door handles loose
i have a whirlpool conquest side by side and had loose handles,couldn't figure out.but then i grabbed handle and push in and up,handles slide off you can then tighten bolts then slide it back on.hope this helps.n
Oct 14, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool gold
Your drain was clogged. look for the drain funnel then remove the dirt.
Jun 07, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
67 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
