Question about Electric Jazzy 1115 Power Wheelchair
The chair just died and the key lock symbol is blinking and it wont turn on
  • Barry Nixon May 11, 2010
    How many times is it blinking?
  • 103 Answers
How many times is the key flashing?
christianmobilityrepairs@yahoo.com
Posted on Jul 23, 2009
  • 32 Answers
Sounds like the joystick is locked out. try pushing and holding the on/off switch for 5 seconds
Posted on Jul 13, 2009
Push power button wont go but all the adjustments legs back tilt works
quantum 600 wheelchair troubleshooting Questions ... - Fixya
www.fixya.com > Forum > Tags
quantum 600 wheelchair troubleshooting chair won't go all i get form joystick is a picture of a ... around in a square there should be a rest button on the rear of the chair ,push ... Question about 600 E Electric Wheelchair - Used Power Chair.
[PDF]Pride Quantum 600 Owners's Manual - Scootaround
www.scootaround.com/.../Pride%20Quantum%20600%20Owner's%20M...
Quantum 600 .... The symbols below are used on the power chair to identify warnings, mandatory actions ... Pride will not be held responsible for injuries and/or property ...complete stop by releasing the joystick, then push the joystick forward slightly to .....breaker button, turn on the controller, and continue normal operation.
[PDF]Quantum 600E Owners Manual - Scootaround
www.scootaround.com/.../Pride%20Quantum%20600E%20Owner's%20...
Quantum 600E .... The symbols below are used on the power chair to identify warnings, mandatory ... chair. Pride will not be held responsible for injuries and/or property ... complete stop by releasing the joystick, then push the joystick forward slightly to ..... breaker button, turn on the controller, and continue normal operation.
[PDF]Quantum 600 Series - Pride Mobility Products
Dec 30, 2015 | Quantum 600 E Electric Wheelchair - Used...
Kenmore elite washer not starts just blinking lights.
What light(s) blink? How many times to they blink? Do they blink all the time, or just when you press a key? If it's just 1 light that blinks 3 times whenever you press a key, then you have the child-lock (or control-lock) function turned on. If you look at your control console closely, you should see some key near the lock symbol (frequently the Heated Dry key), with the notation "hold 3 seconds". Press and hold that key for 3 to 4 seconds to de-activate the child-lock.
Sep 13, 2014 | Kenmore Elite Stainless Steel 24" BuiltIn...
Cranking but not starting...
If the pass lock sign is flashing (pad lock symbol) then you have no gas to start, you have to turn the key off, wait ten minutes then see if your pass lock symbol light goes out, it will blink then go out if it is reset, then you can start your engine.
Dec 20, 2012 | 2005 Chevrolet Colorado
Unlock scooter seat
Try some lock cleaner\ lubricant, use liberally, press down gently on the seat locking latch. If that doesn't work try shocking the mechanism with my favorite tool, a rubber mallet. If the key turns that part of the mechanism works. Put the key in to the release position. Go to where the latch is, use a bright light, see if the latch is engaged, Usually this kind of lock uses a hook latch. The hook is literally apart of the key barrel so if the barrel moves the latch hast to be moving too. Check the chair itself that its not stuck. WARNING Lubricate with pure silicon spray only it wont stain your chair. Lub all rotating joints and see if you can move it.
Hope this helps
Jun 21, 2012 | Health & Beauty
I have a hoveround teknique wheelchair brakes are locked up the key symbol light blinks 7 times what should i do
Regarding your Hoveround Teknique?..You should contact Hoveround directly. They made the chair. They will probably service it for you, and you might get it serviced for free--maybe. Go their website (http://www.hoveround.com) and see the Contact Us page.
Jun 26, 2011 | Health & Beauty
Battery indicator seems fine. Wrench symbol is lit. Chair won't respond to joystick control. Any suggestions? It worked when I put it away a few months ago and now, nothing.
The wrench symbol being lit indicates a problem. Does the wrench symbol blink? when you try to engage the joystick the brakes should try to engage and you would hear them click and the symbol will flash. The number of flashes telling you what is wrong. If the symbol is not flashing and staying on then that also a probem but you can't tell what it is. Either way the chair will have to be checked by a tech that has a programmer to plug into the chair and read the error codes to determine the problem. Check with your provider that sold you the chair to see if they can troubleshoot the chair for you or contact Invacare Tech Support @ 1-800-333-6900 and explain your problem. Sorry I can't give you a definite answer Hope this helps
Mar 07, 2011 | Invacare Supply Group Invacare Pronto M91...
Not sure witch jazzy chair i got but the joy stick blink and keeps blinking i have tried pushing horn button twice and also turning it on and pushing joy stick forward waiting for it to beep but no beep....
LOCKING/UNLOCKING THE VSI
The VSI has a feature that enables you to lock your power chair to prevent
unauthorized use.
To lock the VSI:
1. With the VSI powered on, press and hold the on/off key. After one (1)
second, the VSI should beep.
2. Release the on/off key.
3. Push the joystick to the full forward position until the VSI beeps.
4. Pull the joystick to the full rearward position until the VSI beeps.
5. Release the joystick. There should be a long beep.
6. The VSI is now locked.
To unlock the VSI:
1. Press the on/off key and power on the VSI. The maximum speed/profile
indicator should ripple side to side.
Good Luck
mimobility
Feb 17, 2011 | Pride Jazzy 1103 Ultra Standard Power...
Turns over wont start theifed light blinking ran fine nite before did start for a couple of seconds about three times and thats about it keeped turning over till battery died
Either the little "chip" has fallen out of your key (usually in the end of the key next to where the keyring hole is) or the transponder on the ignition lock cylinder has failed.
Nov 08, 2009 | 1998 Ford Expedition
Blinking blue box with lock symbol on screen
hold down the menu button for 20 seconds until the lock symbol turns into an unlock symbol.
Oct 03, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
Electric Jazzy 1115 Power Wheelchair Logo
236 people viewed this question
Top Electric Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you an Electric Health and Beauty Expert? Answer questions, earn points and help others
