SOURCE: Kenmore Elite Oasis TL washer, stubborn Sd code
Found the problem. After removing the back panel, found some garments in the bottom of the surrounding clear plastic tub. These must have been periodically blocking the outflow area and triggering the Sd error code. Fixed it by opening the top components of the washer so I could see down into the surrounding tub from above. Fished out the garments with clothes hangar. Put everything back together and have done six loads with zero problems.
SOURCE: Kenmore elite washer problem
you can use a shop wet vac on the drain hose to **** the rest of the water out then you can remove the hoses to check to see if anything is suct in hoses or pump-,mike
SOURCE: Kenmore Elite Oasis HE washer error code F2
The error code must be cleared first to make the machine back into operation. You have to press the PAUSE/CANCEL button twice to clear the error on the display.
The only filter the machine has is the one you removed to clean the pump. When the error is cleared, you can check the pump whether it is operating properly or not by running the diagnostic test.
Diagnostic Test Mode Procedure
Please inform me about the result of the diagnostic test and if you still need any assistance regarding this problem.
SOURCE: Kenmore Elite Oasis HE 27072. Keep getting UL
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
SOURCE: My kenmore elite oasis washer model # 110.2703 shows code F-50
The F50 error code indicates that the RPS (rotor position sensor) detects no motor rotation. Check to see if the basket spins freely. If not, you could have an item caught between the outer tub and the inner spin basket. A toy or other item underneath the washer could also prevent the basket from spinning and would result in this F50 code.
If the basket spins freely, you could have a wiring failure that would prevent the motor from spinning.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
