Question about Acer Aspire 5500 5570-2609 Laptop
Hardware malfunction my laptop dell Inspiron 6400 is experiencing problems right now. It stop and hang and a big blue screen is showing these message: HARDWARE MALFUNCTION CALL YOUR HARDWARE VENDOR FOR SUPPORT NMI : PARITY CHECK / MEMORY PARITY ERROR THE SYSTEM HAS HALTED I left it on hibernate on the bed ( shouldnt do that it obstructs cooling vents) and when I booted It showed me the same thing. I started in safe mode then in normal. The laptop is 3 months old. I haven't had any problems so far. . .I hope it was a simple heating problem from obstructed vents and that it won;t occur again. Did it ever occur a second time for you guys?
  • razgorath Jan 02, 2009
    well i rebooted and its all working without me doing nothing . ..I even played a game of dawn of war and rebooted again . .It still works. . .Could the incident have been linked with the fact that I let it sit on Hibernate on a bed with the cooling vents obstructed?
    Problem Solver:
  • 13 Answers
More than likely it is new software or hardware (or their updates) malfunctioning or being corrupted. best thing to do is to restore to factory default or reinstall your OS orif it was purchased new, then it should still be in warranty by Acer and you can send it in for service/repair
Posted on Jan 01, 2009
    Scholar:
  • 155 Answers
Remove the battery from the bottom of the computer. disconnect the ac adapter, then push the power button and hold it in for ten seconds. reconnect the power sources then try again.
If it still doesnt work, try to reseat the memory cards. Repeat the steps above and remove the screw from the 'M' memory door at the bottom of the computer. Remove each of the cards by spreading the clips on the sides of the card. Then slide it out at an angle. Install them again the same way you took them out. Slide it in at an angle until the the card is all the way into the slot. Then push down the card on the sides. You will know it's in place if you hear the card click. Try to turn the computer on then see if it works.
If you still get the blue screen, see if one of your memory cards is damaged. remove one at a time. and test each memory card on each memory slot to find the culprit. If you only have one card, move the card to the other slot. Just post back what happens.
  • 36 Answers
Greetings
That kind of error usually comes up with Ram/memory issues. try going into the BIOS and disable memory checking. However this issue is almost exclusive to dell :)
The culprits for this is GPU, RAM among others and fix from dell does not guarantee solving the issue. It usually triggers when you use graphics intensive operations.
Hope that info is useful.
I HAVE INSPIRON 6400 LAPTOP. ON SWITCHING ON SCREEN SHOWS BLUE & ORANGE WORDING OF DELL LOGO AND THEN GOES BLANK. IT WORKS WHEN USING AN EXTERNAL MONITOR.
Run the LCD BIST Test
http://support.dell.com/support/topics/global.aspx/support/dsn/document?c=us&cs=04&l=en&s=bsd&dn=1092705
If it passes, replace the motherboard, fails replace the LCD
May 17, 2010 | Dell Inspiron 6400 Notebook
Giving blue screen with error message & getting stucked.
the blue screen also appears when there is a hardware malfunction. use ur BIOS to check whether all ur hardware are working fine
Feb 12, 2010 | Dell Inspiron 6400 Notebook
Dell inspiron 6400 freeze after startup
do a system restore before it started doing it.
Nov 08, 2009 | Dell Inspiron 6400 Notebook
Dell Inspiron 1520 laptop. Blue Screen
Dear, Requested data was not in memory. An invalid system memory address was referenced. Defective memory (including main memory, L2 RAM cache, video RAM) or incompatible software (including remote control and antivirus software) might cause this Stop message, as may other hardware problems. What you can do is if you have more than one memory modules, you can boot the system with single and see. If this is due to memory leakage issue, you can find it here
Oct 16, 2009 | Dell Inspiron 1520 Motherboard
Dell inspiron 6400 problem in switching on
hi there so once you see the dell logo keep on tapping f8 and check if you can enter the safe mode, if not tell me the lights because that means thats its a no post issue and we might need to reseat your memory.
Jun 02, 2009 | Dell Inspiron 6400 Notebook
Microphone doesn't work
My microphone in Dell inspiron 6400 doesn't work
Sep 25, 2008 | Dell Inspiron 6400 Notebook
From the error report, it sounds like you have a bad memory chip (RAM).
If it's under warranty, contact Dell for a replacement.
If it is out of warranty, go to a vendor that sells RAM and replace it (such as www.crucial.com)
Jul 28, 2008 | Computers & Internet
Dell Inspiron 6400 Screen turns black Problem
Could you please run the diagonistics on the computer?
Turn on the computer. When the DELL logo appears, press <F12> immediately. Select Diagnostics from the boot menu and press <Enter>.
NOTE: If you wait too long and the operating system logo appears, continue to wait until you see the
Microsoft Windows desktop. Then shut down your computer and try again.
b Press and hold the <Fn> key while powering the system on.
Make a note of any errors that you get after running the diagnositcs on the computer.
Mar 08, 2008 | Dell Inspiron 6400 Notebook
Dec 07, 2007 | Dell Inspiron 6400 Notebook
Acer Aspire 5500 5570-2609 Laptop Logo
233 people viewed this question
Brian Sullivan
Brian Sullivan
Mohammed Ebrahim M
Mohammed Ebrahim M
