Question about Maytag Appliances Over-the-Range Microwave Oven
VENT FAN DOES NOT WORK
MAYTAG OVER TH RANGE MICROWAVE OVEN MODEL MMV4184 THE OVEN WORKS FINE BUT THE VENT FAN DOES NOT WORK. WHAT WOULD THE LIKELY CAUSE BE AND HOW DO YOU ACCESS THE FAN?
I THANK YOU KINDLY FOR ANY INFO YOU MAY HAVE,
ORV OLSON
  • omo7 Jan 01, 2009
    I THANK YOU KINDLY, YOU HAVE BEEN A BIG HELP.
  • Maytag Master
  • 19,396 Answers
That means that either the fan assembly must be replaced, otr there is a wiring problem.
You find assembly diagrams and parts here.
Posted on Jan 01, 2009
  • Ginko
    Ginko Jan 01, 2009
    Enter model number here to find assembly diagrams and parts.
    On parts search fan, then the oven must be taken apart, and wiring to the fan and connection from control assembly tested with a multimeter.
    If the wirings are ok, test the fan motor, and eventually replace the fan assembly.
    If the fan motor works, and wirings are OK (there is continuity) then test the control assembly and eventually replace it.
My microwave oven model 721.85033111 vent fan stays on
You probably have a bad fan thermostat. This thermostat is supposed to turn on the vent fan if the microwave oven gets too hot (caused by cooking too much or having too many burners turned on on the range beneath the microwave oven). It should shut off in about 15 minutes after your turn off the range burners. But if it comes on for no reason, or won't turn off, then You probably have a bad fan thermostat.
Aug 10, 2014 | Kenmore Microwave Ovens
Mmv5165bas vent fan will not stop running
Check to see if there's a relay providing power to the fan. If there is, the contacts might be sticking in the closed position. Assuming that this is an over-the-range unit, disconnecting the vent fan completely might not be a good idea as heat/steam from foods cooking on the range would more likely damage the microwave.
Apr 29, 2014 | Microwave Ovens
Maytag over range rattling and vibrating noise
Make sure you tighten all the attachment screws that may have loosened during long term usage. Make sure the fan is running properly and not causing undue vibrations. Use WD 40 on the fan.
Mar 15, 2014 | Maytag Appliances Over-the-Range Microwave...
Kenmore over the range microwave oven model 721.80413500 keypad just stopped working. No response when pressing any button, even the light and fan button. Microwave was working fine minutes before.
80% of power problems are caused by ceramic fuse locted under microwave cabnet.Use a tester to see if you have continuity.You may just need a fuse.
Jan 29, 2011 | Kenmore Microwave Ovens
Maytag Microwave apprears to work but does not cook
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101-==-
May 17, 2010 | Maytag MMV4205 Microwave Oven
Exhaust fan is running constantly, without even
It could be that the fan button is sticking or a contact has welded itself closed therefore its getting power all the time.
Mar 08, 2010 | Maytag Appliances Over-the-Range Microwave...
I dont have a vent for above range microwave oven
It doesn't have to vent outside. These are designed to recirculate the filtered air back into the room. If you cook without a range hood now it will work fine for you.
Eric
Oct 29, 2009 | Whirlpool MH7140XF Microwave Oven
No door lights, vent fan or microwave
That's what I thought.
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Dec 14, 2008 | Whirlpool GH4155XP Microwave Oven
Exhaust fan
The fan pulls from the range top and either out those vents on top unless there is a vent in your upper cupboard. Then it is vented outside. Hope this helps.
Jan 07, 2008 | Maytag MMV1153A Microwave Oven
Maytag Appliances Over-the-Range Microwave Oven Logo
81 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
