Question about Honeywell Heating & Cooling
Thermostat problems! i have a honeywell radio controlled thermostat but the temperature controller is out of sync with the main unit on the boiler, i've tried re-setting both but still no joy, also tried new batteries in the remote, again no joy!
You can turn off the 'Optimum Start'. See MoneySavingExpert website for instructions posted there by Honeywell as to how to do it.
Posted on Jan 22, 2009
Honeywell visionpro
Um...., you changed the controller and it worked, then put the old one back and it doesn't work >> replace controller!
Oct 16, 2013 | Honeywell Electronic Programmable...
Where do i adjust boiler temp on a gas fired boiler
difficult to say just where the temperature control is on your system. it will likely be an immersion type control located some on or near the boiler. it should have a temperature range scale on it.
Jan 25, 2013 | Heating & Cooling
Heating not working and Honeywell Thermostat Heater states that the temperature is 45 degrees celsius.
without seeing it its hard to say, the thermostat controls the boiler and/or diverter valve depending how its been wired, the diverter valve shunts the water to were its needed ie from one circuit to another if you have two therostats there is a conflict somewere, best bet to have an engineer sort the wireing out
Dec 28, 2011 | Honeywell Programmable Thermostat Heater
I have a honeywell cm927 control unit, and the red light on the receiver keeps flashing. i can manually turn the boiler on and off at the HC6ONG receiver. i've tried the faqs in the manual but to no joy....
The red flashing light means that there is an issues with the RF comms between control unit and receiver. You can reset by switching the boiler off and back on and then re-sending the temperature signal. You need to check batteries in you thermostat and also the position as the signal could be interfered with or it may be too far away from the receiver.
Sep 25, 2010 | Honeywell Programmable Thermostat Heater
Boiler is a baxi control for heating is honeywell.
this will be your diaphram inside your divertor valve.
the one that looks like a spaceship.
it will e split.
Oct 05, 2009 | Honeywell Programmable Thermostat Heater
When i turn heating or hot water on fuse board trips
it was a faulty heating pump. replaced, all ok now.
Jan 03, 2009 | Honeywell Electronic Programmable...
HONEYWELL CM921 ROOM THERMOSTAT
Remember the is a time and temperature controller if you want to use as an ON/OFF controller please ensure you OFF times are set to LOW temperatures for example at 8:00am I want the boiler firing to 21°C at 10:00 I want the boiler to go OFF at 5°C so ensure all so called OFF times are set to LOW temperatures.
Oct 26, 2008 | Honeywell Programmable Thermostat Heater
My central heating system comprises a worcester bosch system boiler and honeywell smartfit controls. The problem I am having is that the central heating doesn't seem to knock off at the preset temperature...
You could possibly have an ignition problem. The controller will go into a lock-out condition if flame is not established. Turning the temperature control down and then back up may be serving to reset the control system so it tries again.
May 21, 2008 | Honeywell Heating & Cooling
Boiler will not shut off
boiler does not shut off when thermostat reaches temp, i already replaced aquastat but condition still exists
Nov 14, 2007 | Heating & Cooling
Heating & Cooling Logo
198 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
