Question about Mitsubishi WS-65513 65" Rear Projection HDTV
Wont turn on
Hello I have a Mitsubishi 65" if you turn it off it takes hours of babysitting it before it will come back on. when you press the power button the light over the word timer just flashes and will not come on. do you know what this may be or do you have any suggestions. Thank You
  • 3 Answers
65" 1080 mitsubishi tv model# WD-65733 wont turn on
It is probably the wiring. Try buying a new power cord.
If not than it is just malfunctioned.
Contact Mistubish
http://www.mitsubishi-tv.com/contact
Nov 25, 2012 | Mitsubishi WD-65733 65" HDTV
Have a Mitsubishi Medallion HD 1080 Model WS-48413 which won't turn on. When I push the power button on the remote or on the tv itself, a green light comes on for a moment and a clicking sound is heard to...
~ Check the lamp hours ~ Normally it is 200-400 hours lamp life ~ BASIC USAGE: 8 hours/day ~ Reseat the lamp~ Consider replacing the lamp or it could be an Internal Problem
Jul 06, 2010 | Mitsubishi WS-65413 65" Rear Projection...
I have a Mitsubishi medallion 65 and it keeps turning off,
Dear Sir,
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times.
1 - 2 = no error detected
2 - 1 = X-ray protect (high voltage or beam current)
2 - 2 = Short protect (short protect monitors low voltage supplies)
2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection)
2 - 4 = Vertical protect (usually loss of vertical from the source)
1. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR OPEN FUSES F9A04 PART # 283P044020 AND F9A05 PART # 283P043090 ON THE +24 AND -24 VOLT LINES. IF THE FUSES ARE OPEN THE CONVERGENCE OUTPUT CIRCUIT WOULD BE SUSPECT. I hope this helped.
Good Luck, big IRISH.
Dec 08, 2009 | Mitsubishi WS-65411 65" Rear Projection...
Mitsubishi 65807 won't power on
hello it's possible the glass fuse may blown inside the tv take the back off and check but make sure the power's off
shaun
Oct 12, 2009 | Mitsubishi WS-65807 65" Rear Projection...
Car shut off @ 65 mph and wont start again.
you may have a broken alternator belt or timing belt.
Sep 25, 2009 | 2003 Mitsubishi Lancer
Same Exact Problem Mitsubishi WD-57731
YOU CAN TRY TO REINITIALIZE THE SET HOWEVER, YOU WILL HAVE TO REPROGRAM YOUR CHANNELS BACK IN WHEN YOU DO. ON YOUR REMOTE PRESS MENU, 2,1,7,0 IN SEQUENCE TO SELECT (OPTIONS MENU )DISPLAY, PRESS ADJUST BUTTON TO SELECT INITIAL, PRESS ENTER. NOTE, AT THIS TIME CHANNEL 3 IS AUTOMATICALLY SELECTED
Sep 18, 2009 | Mitsubishi WS-65711 65" Rear Projection...
Mitsubishi Big Screen Digital 65 inch
you have a short in power supply the light should stay on check all power supply parts
diodes,power transisters
you need to test all parts, i could fix this in
30 mins
need help call 0403960527 jeff......
Feb 16, 2009 | Mitsubishi WS-55807 TV
MITSUBISHI 65 INCH HDTV, GREEN LIGHT BLINKING, WILL NOT POWER UP
There are four (4) caps on the 'DM' board that need to replaced. Parts: 680ufd 16 volts, orig are rated at 1,000 ufd.
Nov 01, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi WS-65513 65" Rear Projection HDTV Logo
32 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
