Question about Panasonic PT-56WXF95 56" Rear Projection Television
Fuzzy picture, oval shaped, scrolling up slowly
RCA 19" TV, made in 1985. I know its old and not worth fixing, but i hoped somebody could point me to what circuits might be causing this. I have some experience troubleshooting electronics. The picture used to be perfect, now on any channel, even with no antenna hooked up, the screen is squished into 2 oval-shaped windows that constantly scroll upwards. The picture itself stays centered on the screen, you can still see it through the oval-shaped "windows". It takes about 30 seconds for the windows to go from the bottom of the screen to the top and then wrap around back to the bottom. I can take a picture if it would help. Thanks.
    President:
  • 2,992 Answers
I would start by checking the large filter capacitors in the power supply. I can't be sure since I'm not seeing the set, but it sounds like you're describing AC ripple. In a 20-year-old set, some of those electrolytics will be drying out. A few replacements may take care of the trouble for you.
Posted on Jun 19, 2009
OLD Hitachi 50EX13K rear projection TV now has bow shaped picture
Your convergence ic's have to be replaced along with checking all the bias resistors for exact value. Easy for me! I don't know what your electronics background is?
Oct 30, 2009 | Hitachi Televison & Video
Front panel blocked or locked
RCA Entertainment Series 32" Plus Gold, GEMSTAR, xbox ready has been in the shop twice so far. Transformer replaced and 6 months later the picture suddenly had horizontal white lines that gradually spaced apart more from top to bottom and it had a gray hue and fuzzy, but I still watched it for 3 months that way. Today I turned it on and about a minute later I heard a loud crackling sound coming from the back and the picture disappeared, screen went black. Is it worth fixing again? Please contact me at ninalashua@yahoo.com
Jul 09, 2009 | RCA 32F531T 32" TV
RCA model P60812BL 10 years old picture goes fuzzy once on
Your convergence amplifiers are begining to malfunction. This is not expensive However I would advise that you get a qualified TV technician to work on the set due to a chance of damaging you TV if you install the amplifiers incorrectly.
I hope this helps
thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
May 24, 2009 | RCA D52W19 52" Rear Projection Television
RCA model P60820BL picture changes to bow tie shape
Just click below for convergence repair kit;
http://servicemanuals.vstore.ca/
Double images and colors are blurry .Blue,red and yellow wave coming up from the bottom of the screen on the lower left and fuzzy images this is a symptom is for busted convergence IC,you must replaced this IC in order that will works better again.STK 392-xxx ICs and it's associated resistor,this resistor automatically change value,can caused truoble even though you change the ICs.If you bring this to a service center they cost you $600 to $700,but if you buy the repair kit you can save more,don't wory it is very easy because there is intallation guide including in the repair kit. Feel free to ask whatever the result... click the link for sample picture guide step by step installation;
Hope this may help;
Regards,
VOTIT
Jan 29, 2009 | Samsung HC-R4755W 47" HDTV
Picture went out on my 36'' RCA television, still have sound.
do you have and big sound system if you do the move them away from youur tv. or you sould just bring it to a shop it must be the picture tube
Jan 26, 2009 | RCA 36V430T 36" TV
Bad color
If it is a glass crt then you need to have the set demagnatized with a demagnatizing coil. All tv shops have one. This is worth fixing and usually at the price of a service call.
Mar 15, 2008 | Panasonic CT-32SX12 32" TV
RCA Home Theatre Projection TV
Your ICs are bad that control the Convergence. I would quess that the ICs that they have used before have been the cheaper versions. Sanyo are the best the cheap ones only last for a while then need replacing. The sanyo chips cost considerably more than the imitation ones but are worth it in the long run.
Mar 12, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Oval shaped picture problem with Mitsubishi WS55807
Self test: Turn on and Press the input and menu buttons on front panel together and hold for 5 sec. after 5 sec the power LED will blink a 2 digit seq. This will let you know what error code. Count the first blinks then a short pause then the second blinks. Example 2-3, 3-4, 4-1. Let us know what it is
Nov 21, 2007 | Mitsubishi WS-55807 TV
Picture fuzzy and flickers (like tracking)
The flicker could be caused by a bad solder connection arcing or even a bad picture tube. If you notice the screen getting drawed in from the sides as well as top and bottom it may be in the power supply regulation circuits, but the focustat around the area of the high voltage transformer could also be breaking down. If it's over about 8 years old, I would replace it with a HDTV set. Check out the latest issue of Consumer reports for ideas. (No I don't work for them-I've just seen so many people just walk into a *Mart and pick out a TV like they were choosing a box of cerial without doing a bit of research to find one that would suit them best, that I'm trying to put out a word to the wise among us).
Feb 04, 2007 | RCA F35673MB 35" TV
RCA F27667 No Picture / Chirping sound
I will bet you 10 to 1 that the flyback transformer and the horizontal output transistor is bad. an no at this point the set is not worth fixing.
Sep 28, 2006 | RCA F27667 27" TV
Panasonic PT-56WXF95 56" Rear Projection Television Logo
82 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
