Question about Mitsubishi WS-55511 55" Rear Projection Television
Blue and Green line thru center red shadow on both sides
TV comes on sound works but has solid blue line from top to bottom and red shadow on both sides
  • 1 more comment
  • wreid69 Jan 02, 2009
    There
    there is a solid green and blue line in the middle from top to bottom and the hole tv is shaded red on both sides not just lines.
  • T.l. Moore
    T.l. Moore May 11, 2010
    your saying you have a thin line going from top to bottom of screen and there is a red line on each side of this line
  • 273 Answers
Most likely if the line is top to bottom you have no horizontal deflection
this could be caused by a number of things
but if you continue to turn it on it will score a burn mark on the face of the three crts
id call a service ctr in your area or you might try replaceing the deflection bd and see if this will resolve the problem
the problem could be a open yoke return cap but if you dont have the tools or knowledge this woulld be one better left to sme one more experianced with this
please let me know il be happy to try and assist you further
Posted on Jan 02, 2009
Wiring coming out of motor doesnt match wiring harnesses that I have purchased
It is not the replacement you need! Go back and get the correct replacement item.
Sep 02, 2017 | Cars & Trucks
Projection HDTV Pansonic 47" Curving blue and green colors on top and bottom of screen.
You will need to replace your two convergence I.C.s.They are two large IC mounted on a large aluminum heat sink.Replace both,look for any burned resistors near them,replace those if needed,and readjust your convergence. Good Luck
Let me know if you need any further help
Mar 29, 2008 | Panasonic PT-47WX42 47" Rear Projection...
Our tv has red and green shadows on the picture when words come on at the bottom of screen they look like a shadow double Peoples faces will be outlined with red and green lines
your color engine is failing its also known as the optic block and they are very expensive to replace good luck google the optic block failure in these sets to better educate yourself with what your dealing with ok it most often blue that shows the failure but green and blue to and red
Dec 21, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
Philips 55P8288A tv has a dull color and a red hue.
This sounds Like the the coolant for your piture tube has become cloudy and needs replacement (usually blue or green tube - thats why the image seems ovrely red).It's a big job (labour wise) since completee dissassembly is required ($200-300). It can be done youreself - check out TVrepairkits.com to get the coolant and instructions.
You can confirm that this is the problem by dissassembling the unit to the point where you can view the face of the CRT's (red green and blue) directly.
Nov 28, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
3 year old rca rear projection just started going blurry. green blue and red line across the top of screen. objects have shadow.
Focus and screen control box / remove front bottom panel there you will find it / it has 3 controls on top 3 on bottom top are focus for RGB tubes bottom controls adjust screen drives for RGB.
Jan 25, 2009 | RCA D52W23 52" HDTV CRT TV
Blue shadows appear to be behind white objects
TV shows large red spot in middle of tv when dark show are on, you can see it more.  Now blue spots on upper right side too.  Spend way to much on this tv to have these kinds of problems only after 3 yrs.
Nov 16, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Picture problem
might need to get a tech to align it in what is called service mode
Jan 01, 2008 | Philips 60PP9202 60" Rear Projection...
Blue shadows
Sony Too green,red or blue
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Nov 25, 2007 | Sony KP-53HS10 TV
Mx-42vm10
Sounds like convergence are off. Go to menu and find tv convergence and reset. This deals with red, blue, and green.
Aug 16, 2007 | Maxent MX-42VM 42 in. Plasma HDTV
Picture then fades to blue.
Please post me on this as well. My Sony just turned 4 yrs this Jan and just last week it started having the same problem. -Thanks!
Mar 02, 2007 | Sony KP-65WS500 65" Rear Projection...
Mitsubishi WS-55511 55" Rear Projection Television Logo
73 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
