Question about Yamaha RX-V563 Receiver
Yamaha RX-V563 Reciever - OSD (On Screen Display) not working . . .manual says OSD will not work with HDMI connections to the TV. Are you aware of any updates or fixes considering most of the features and XM/Sirius features require this OSD? Thank you!
  • 336 Answers
SOURCE: rx-v563 backround music much louder than people when watching tv
I would check your center speaker wiring and setting. Then switch to a different audio setting (pro logic, theater...)
Posted on Jan 12, 2009
dunnbiker
  • 8546 Answers
SOURCE: Is the Yamaha RX-V596 capable of using HDMI in
Nope. Use S-Video or composite video In and digital audio in from the Cable Box, S- or composite-video out to the TV/Monitor.
OR (what I do) skip the receiver as a video middleman and take the HDMI video right to the TV; and run the Cable Box digital audio to the Receiver.
Posted on Feb 19, 2010
  • 127 Answers
SOURCE: Yamaha reciever doesnt recognise hdmi from Mac laptop
Max does recognize receiver over HDMI-CEC.
The problem is that DVI output is for video only. Macbook won't (and can't) output audio via DVI. So yamaha receives only video signal via the HDMI connector. You can check that by pressing Option button on yamaha remote and choosing Signal Info - you will see info about video, but no audio signal present.
Posted on Mar 02, 2010
  • 127 Answers
SOURCE: I plugged in my cable HDMI into my RX - V365
RX-V365 doesn't support HDMI audio. You need to connect the cable box also via spdif cable for audio to work. Look at the box if it uses optical spdif or coax spdif. If optical, you see that optical input on receiver is named DTV/CATV, so use also DTV HDMI for video. Coax spdif is named DVD, so in this case you will need to use DVD HDMI input.
Also you need to configure the inputs accordingly.
dunnbiker
  • 8546 Answers
SOURCE: yamaha reciever model rx-v563 power cord
It's just a power cable. Get something like this
http://www.radioshack.com/product/index.jsp?productId=3875430
and lop off the end that doesn't fit, strip them and either splice it to the remnants or go inside and connect it to where the original goes.
Posted on May 06, 2010
No OSD menu on Panasonic ST50 plasma TV
My guess is that the OSD function can only be enabled directly at the Panasonic TV.
Nov 18, 2013 | Yamaha Audio Players & Recorders
Set up Wii with my yamaha rx-v563. Sound but no video using hdmi out to tv and component into receiver
I had the same problem and found you have to connect the yellow video cable directly to the TV. Am finding that the component cables plugged into the receiver are not delivering video through the HDMI out to the TV.
I have the same problem with plugging in a video camera to the V-Aux on the front of the receiver and still havent figured out how get the video to show up on the TV, so if you find something else out please post.
Dec 27, 2010 | Yamaha RX-V563 Receiver
The Yamaha Reciever RX-V465 is connected to my digital TV by fibre optic cabel. I have sound when I connect my MP3 to the V-Aux and the speakers are displayed on the display window of the Reciever same as...
Please check your TV settings and the optical cable.
The speaker icons disapper from LCD display when the receiver does not detect any input signal throught the optical/coax/hdmi cable.
Dec 13, 2010 | Yamaha Rx-v465/rxv465 Home Theater...
Yamaha reciever model rx-v563 power cord
May 05, 2010 | Yamaha RX-V563 Receiver
I can't get the OSD display to appear on my monitor.
it's in the manual footenotes. osd will not work with an hdmi connection to monitor. it will work with s-video or component. just switch input when osd is desired.
Jan 28, 2010 | Yamaha RX-V661 Receiver
May 22, 2009 | Yamaha RX-V563 Receiver
Rx-v563 backround music much louder than people when watching tv
Jan 12, 2009 | Yamaha RX-V563 Receiver
No sound
Check the settings on the receiver. You may need to switch the dvd from analog to digital or hdmi.
Jan 04, 2009 | Yamaha RX-V563 Receiver
Yamaha RX-V663 - HDMI doesn't work.
Hi and welcome to FixYa,
Initially, a workaround:
  • as you posted, audio out of the DVD goes to the receiver;
  • HDMI out of the DVD goes to the Schaub Lorenz LCD.
Even if it were a compatibility issue or HDMI processor issue on the receiver, the above should get you going.
Good luck and Thank you for using FixYa. Happy Holidays.
Dec 19, 2008 | Yamaha RX-V663 Receiver
Audio but no video from Sony Blu-Ray w/ HDMI hookup to RX-V663
Okay...my first contribution to any forum but I have the same problem (Yamaha RX-V663 and Samsung Blu Ray) and found the solution. The problem is you probably have your HDMI cables from your DVD player and reciever connected to a DVI input on your TV. The DVI may have problems communicating--not HDCP compliant. My system was working great then I hit a button on my remote...just playing around. I think it was the pure audio and I turned off the receiver. After that, the audio worked but there was no video. After many frustrating hours, the fix was to unplug the HDMI and DVI cable then turn the power off, cycle the power again, and plug the HDMI and DVI cables back in (the DVI was the last cable plugged in, not sure if that matters). By unplugging everthing you've reset the communication between the HDMI components and the DVI TV.
See page 18 of the yamaha owners manual, second to last note on bottom right of the page. It says there may be a problem...
I also noticed that the yamaha reciever was sending 1080p (my older tv is 1080I) and that is why the video wouldn't display on the TV. You can see this in the video signal info screen, unfortunately there is no setting to switch it back, just recycle the cables and power and it should reset.
Uncredibly frustrating but I got my picture back!
Jason
Dec 01, 2008 | Yamaha RX-V663 Receiver
Yamaha RX-V563 Receiver Logo
822 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
