Question about SanDisk Sansa e250 MP3 Player
Blank screen I just downloaded music to my sansa and now the screen is just a light and I can not shut it off or do anything with it
Press and hold the power button until it turns off. If it does not then you will have to take the battery out and put it back in, which is very easy.
Posted on Jan 02, 2009
My mp3 player's screen doesn't work
You may need to now reset the player, that may have been a bit much for it. To reset your Sansa Mp3 player. Slide and hold the Power switch up for approximately 20 seconds. Release the Power switch. To turn the player on, slide the Power switch up then release instantly. If that does not get your player working again, try and Format to clear any corrupt files that may be present.
Sansa Mp3 player frozen? How to reset and...
Mar 18, 2010 | SanDisk Sansa e260 MP3 Player
Blank screen
Typically this is an indication that your battery is dead. If the music is still playing but the screen is blank I would say a hardware failure and replacement would be the best option.
Jan 06, 2009 | SanDisk Sansa m240 MP3 Player
Sansa clip is stuck on Refresh Database Screen.
1ST: Just try to 'reset' by holding down the main center button AND pushing UP on the lock/off-on button, for about 8-9 seconds,
It will then 'refresh' the database, shouldn't lose anything,
OR:
MANY problems can be fixed ultimately by the following;
REFORMAT the SansaDisk Clip by finding it in My Computer and right click then just 'format' the thing. THEN drag and drop new music into it (or books), DRAG and DROP, you apparently erase the thing with a 'FORMAT' ....BUT - it's .sys files remain and it is like new {as in empty}
This usually fixes almost anything, should even erase a virus (I'm guessing) but shouldn't hurt it.
Good Luck!
-simple 'drag and drop' from my MUSIC folder seems to work just fine for me...
Jan 02, 2009 | SanDisk Sansa Clip MP3 Player
Screen Blank- can't even reset
thats what happened to my ipod there really isnt anything you can do. i really know how you feel sorry!
Dec 30, 2008 | SanDisk Sansa e260 MP3 Player
Sansa e280
i think i had a similar problem with my e250, if you get your music from anything like "limewire" your sansa may have been infected with a virus :(
sadly, if this is the case, there is no solution
Apr 02, 2008 | SanDisk Sansa e250 MP3 Player
Sansa MP3 Screen is white - display not working
1. Try resetting the player if it has a reset button
2. Drain the battery by leaving it on for an extended period until the screen in blank and no sound comes out of your ear buds. Then connect to AC adapter or computer and charge.
Feb 27, 2008 | SanDisk Sansa e260 MP3 Player
Sansa e260 problems : Music files freezes the sansa and restarts it.
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
or
http://www.sandisk.com/DriverDownload/driverList.asp
-Tha Mp3 Doctor
Dec 05, 2007 | SanDisk Sansa e260 MP3 Player
My Sandisk e260
press and hold the menu/power button until the player shuts off then wait for 10 seconds then turn the player on. This is usually cause by bad files in the device.
Dec 03, 2007 | SanDisk Sansa e250 MP3 Player
Sandisk Sansa e260
u have to wait till the screen will be black. I had the same problem with my sansa. it can lasts 1 or 2 days. after screen is black and then do following: 2. change lock switch to orange position 3. Press and hold rec button (at left side) 4. while pressing the rec button, turn the player on 5. it will appear the boot menu. connect the USB cable and try to continue the firmware 6. if it doesn't work, do a firmware downgrade. download this file: http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe 7. execute the application while in boot mode good luck darek
Apr 03, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
