Question about Bissell 5770 Healthy Home Bagless Upright Cyclonic Vacuum
How to change belt on bissell 5770
Bush will not rotate when button is pushed. Broken belt or bad switch?
  • 1 more comment
  • BiffVZW Mar 01, 2009
    The brush does not turn on. The belt looks ok and the handle is tight. It is one year old.
  • Anonymous Mar 22, 2009
    BEATER BAR NOT TURNING, HOW DO i CLEAN?
    Need to clean belt/bar area. Can't access!!!
reddevil6
  • 1673 Answers
SOURCE: Bissell Vacuum 5770 intermitent spinning brushes
Change the belt, they stretch after a short time and then it can't drive the brush roll under load. The part # is 2031329
Posted on Jun 03, 2008
  • 548 Answers
SOURCE: burning smell when vacuuming, not belt
Try turning the vacuum on and hold the base up so you can see if the roller is turning. Odds are it is not and what you smell is the belt burning (not literally). If the roller is not turning, look for anything that is binding it - after you have unplugged the power cord. Probably the roller head is not fully aligned with the retention lugs that hold it in place or the belt is not properly placed on the roller itself, or if it is a used model, hair and twine can get tangled in the roller and cause it to stop turning.
Posted on Dec 26, 2008
  • 65 Answers
SOURCE: can i get a manual for my bissell healthy home
yes, goto cnet.com and search for manual and download the pdf file
Posted on Aug 19, 2009
Vac Belts
  • 701 Answers
SOURCE: how do you change the belt on a bissell 5770
Here is the belt you need and a manual you can view:
Bissell Healthy Home Belt
Bissell Healthy Home User Guide (PDF)
Posted on Dec 08, 2009
wiringlunati
  • 576 Answers
SOURCE: bissell 5770 vacuum power won't stay on
It sounds like the power switch went bad mechanically (won't lock on)
Posted on Feb 28, 2010
The rotating brush won't turn
Hi henry lop525...
Replace the belt...its broken
Remove the bottom of the vacuum and remove the beater bar, while you have it out be sure to clean and oil it.
Please take time to rate me thumbs up
Sep 15, 2011 | Bissell 5770 Healthy Home Bagless Upright...
What kind of belt do I need to fix my vacuum?
Healthy Home Bagless upright vacuum cleaner replacement belt. Genuine Bissell part number 203-1329 or 2031329. Fits All Bissell Healthy Home, and Heavy Duty models including; 5770, 5770-5, 5770-8, 5770-P, 5990, 6100, 6405, 50C9. Belt contains the following code MS 3M-243-12 written on the outside.
Feb 16, 2011 | Bissell Upright Vacuum - The Pet Hair...
Brush will not rotate
You probably have a broken brush belt. Unplug the vacuum and turn it upside down. Remove the cover over the brush, sometimes with simple push clips or screws and find the belt. If the belt is there but broken or worn out, take it with you, and the model number of your vacuum to buy a replacement belt. While you have the brush out, clean the ends where it is held in place in the bottom. Many times a lot of dirt and hair gets trapped in there, preventing the brush from spinning.
Dec 19, 2010 | Bissell 5770 Healthy Home Bagless Upright...
Bissell 5770 vacuum power won't stay on. The power will only stay on if you hold down the button the whole time.
I just had this happen to me. I took the top part of the vacuum off, unscrewed all of the screws from the top piece and opened it just enough to pop off the plastic red power button. Then I pressed the switch mechanism up and down a few times to reset it and put it back together. Turns out it didn't actually go bad.
Feb 28, 2010 | Bissell 5770 Healthy Home Bagless Upright...
The motor for brush won't turn on for the bissell healthy home vacum
Is the grey "brush" button on the handle depressed? Brush won't turn unless the button is down
Jan 01, 2010 | Bissell 5770 Healthy Home Bagless Upright...
How do you change the belt on a bissell 5770
The Bissell 5770/Healthy Home vacuum is actually fairly easy to change the belt on. The main thing you will need is a T20 screwdriver with at least a 4 inch shaft and a Phillips-head screwdriver. Four of the six T20 screws on the bottom plate are easy to locate, the last two are set deeper into the vacuum near the wheels. Once you have taken all six T20 screws out you will have to release the lock preventing the vacuum from tilting back so you can easily remove the top plate and gain access to the brush assembly. With the top plate off you will notice four Phillips-head screws holding a cover plate over the brush, simply remove them and you have full access to the belt.
Dec 07, 2009 | Bissell 5770 Healthy Home Bagless Upright...
We have power but the front brush does not turn?
Your belt is probably broken, stretched or worn. You can get a replacement belt here:
Bissell Healthy Home Replacement Belt
Nov 25, 2009 | Bissell 5770 Healthy Home Bagless Upright...
How do i change the brush on my 5770 bissell
BISSELL model 5770 has a lifetime belt warranty. You can locate a BISSELL authorized service center at www.bissell.com and the belt should be replaced at no charge.
Oct 09, 2009 | Bissell Healthy Home HEPA Bagless Upright...
Jun 03, 2008 | Vacuums
Bissell 5770 Healthy Home Bagless Upright Cyclonic Vacuum Logo
371 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
