Question about Sirius Satellite Radio Sirius Sportster SP-TK1 Satellite Radio Receiver
When i place my sirius radio into the base, driver side speaker goes off and on but most time i only hear the passanger side speaker working, I had my sirius sportster for 3 years. I think it is the base, what do you think?
    Problem Solver:
  • 18 Answers
When you listen to a cd or the normal radio does the drivers side speaker work? if it does then it is most likely the base is the problem. you might have a loose connection in your car. or the speaker is blow.
Posted on Jan 03, 2009
Need the pin positions of the wire harness
  • red is switched ignition 12 volts (only on with cars running)
  • yellow is constant power 12volts ( have voltage at all time even when car off this wire allows you to save station and clock so you are not allway resting the clock and stations)
  • black is ground ( connected to the frame of car or a good metal part that is connected the frame of car with out a good ground the circuit will not be completed and the radio will not power up )
  • white drive side front (+) speaker wire
  • white/black strip driver side front (-) speaker wire
  • gray passanger front (+) speaker wire
  • gray/black strip passanger front (-) speaker wire
  • green driver side rear (+) speaker wire
  • green driver side rear (-) speaker wire
  • purple passanger rear (+) speaker wire
  • purple/black strip passanger rear (-) speaker wire
  • blue or blue/white strip wire is (remote amp turn on or power antenna )
  • orange wire is (dimmer for light in car )99% of all cars these days don't use this wire
have any question email me at
Oct 27, 2013 | BOSS AUDIO SYSTEMS 636CA
probably a bad ground connection on the speaker. remove door penal and speeker and inspect.
Mar 24, 2013 | Cars & Trucks
Drivers side speaker not working
Remove the radio and locate the wires that run to the speaker, first check to see that the wires were connected to the big plug that goes in at the back of the radio unit.
if it is connected take the plug loose. carefully strip some of the wire leading to the speaker big enough to place a AA batttery terminals. hold one of the wires on one of the sides of the battery and then tap the other wire (expsed portion) on the other side of the battery, if the speaker makes a noise, then the wireing is fine and the issue is either a setting on the radio. or the radio is faulty. if the speaker does not make a noise, check to see that the speaker is properly connected. if the speaker is connected, do one last test on it before replacing it. remove the connections on the speaker and place small lead wires on it and do the battery test direct.
Jan 14, 2012 | Audio Players & Recorders
My speakers have stopped workin. first the drivers side and then passanger...then the drivers side came back on and randomly goes back off? can anyone help?
I would check the connections at the speaker, maybe they've gotten loose from the door opening and closing. Also check the wires from the door to the body frame. Less obvious would be the connections on the radio. A distinct possibility would be bad solder connection inside the radio itself. (I'm and electronics tech and this is a common occurence in intermittent problems) Good luck!
Apr 08, 2010 | 2002 Mitsubishi Galant
My sirius portable radio keeps displaying "no antenna detected" but it's plugged in.
Several possiblities: one: antenna really is bad - borrow a friends Sirius or XM antenna and plug it into the base and see if the message goes away -if it does, replace antenna; if not, then your 'dock' or base could be bad - try removing and reinstalling the radio or try another base. If another base and antenna don't solve it, then the radio is shot and it's time for a new one. Customer service will ususally give you a great deal on a new XM radio IF you agree to keep it for 1 year. Let me know how it goes.
Jan 12, 2010 | Audiovox SIRPNP2 SIRIUS Radio Receiver
My sirius radio sportster works sometimes and others doesn't
Buy radio shack electronic contact cleaner (in a can) and spray a small amount on the male connector from the antenna wire, and spray a small amount on the male connector in the base of the Sportster that the sportster interfaces with. Place the antenna connector onto the base unit and remove it several times and swirl it while connected. Place the sportster into and remove it from the base several times. This usually will fix the issue. Sat signals are extremely sensitive to the slightest oxidation or dirt or whaterver on that tiny antenna connection point.
Oct 01, 2009 | Sirius Satellite Radio Sirius Sportster...
Speakers on right side of car not working when satellite radio is
Try rewiring the system matey, you proberly need to daisy chain them together
Feb 16, 2009 | Sirius Satellite Radio Receiver
Need to disconnect XM Tuner
the xm receiver is in the left rear quarter of van looks like between wheel well and rear of vehicle this is drivers side
Jul 17, 2008 | 2007 Honda Odyssey
When the S50 is place overnight in the Home Base Unit or connected to the AC Adapter it will not charge battery completely.
The I have purchased two new batteries and both have not been properly charge by the units mentioned.
The charge provided to the Battery is of short duration 10 or 15 minutes maximum.
I have telephoned Sirius Company and their response was that they don’t have repair service for this unit any longer.
Nov 03, 2007 | Sirius Satellite Radio S50-TK1 Satellite...
Sirius Satellite Radio Sirius Sportster SP-TK1 Satellite Radio Receiver Logo
174 people viewed this question
Top Sirius Satellite Radio Audio Players & Recorders Experts
Colin Stickland
Colin Stickland
Tom Chichester
Are you a Sirius Satellite Radio Audio Player and Recorder Expert? Answer questions, earn points and help others
