Question about Dell 966 All-In-One InkJet Printer
Hello I have a dell 966 all in one printer scanner copier and fax. Well I connected my fax, have the phone line connected properly, tried both the fax slot on the 966 and the phone slot on the 966, I receive an error message of problem with phone line. I've notified verizon and nothing is wrong with the phone line. Is there anything I need to do special to receive and send message on this 966.
  • 1 more comment
  • Anonymous Feb 28, 2009
    I have the dell 966 all in one printer When attempting to send a fax I receive a phone line err message. I have tried numerous times but receive the same message.
  • Anonymous Mar 18, 2014
    Dell Printer 966 scanning red line
    Dell printer 966 will scan a red line on top of my paper
    Genius:
  • 2,120 Answers
Do you have a DIGITAL phone line? Fax machines only work on ANALOG phone lines.
Posted on Jan 02, 2009
My printer has worked with many computers. But my HP Probook 64 won't drive it. Can you help me find a driver for this printer, mfd in 2007? Thank you / John
PDF]Dell Photo All-in-One 966
www.dell.com/downloads/emea/products/printer/966_en.pdf
DellPrint/Copy/Scan/Fax ... minute (ppm) mono and 23ppm colour, Dell's fastest All-in-One inkjet is designed for maximum ... drivers purchased with the AIO 966.
Dell Photo All-in-One Printer 966, v.G16-EN-x64, A02 ' Dell ...
www.dell.com/support/home/us/.../Drivers/DriversDetails?driverId...
DellNov 3, 2011 - This package contains Dell All-In-One Printer 966 drivers for Windows XP 64-bit and Vista 64-bit. Once downloaded and executed the driver ...
966 Personal All-in-One Printer Driver Downloads, Set ... - Dell
www.dell.com/support/Article/us/en/19/266187/EN
DellJump to Printing using a Bluetooth Connection - Once the user guide is open, click the plus <+> sign next to Dell Photo All-In-One Printer 966 User's Guide ...
Dell 966 All in One Color Printer Scanner Fax Copier
Dec 30, 2015 | Dell Photo 966 All In One Print Copy Fax
I need help how to connect my fax
1. Connect the fax line provided by the telecom provider..
2. And install the required software provided to you in the CD along with the printer.
Mar 24, 2013 | Dell 966 All-In-One InkJet Printer
I have a Dell 966 AIO printer. All of the functions of the printer are working correctly, however, many of the phones in my home have ceased ringing. All are live and calls can be placed and received,...
Setup should look like...
Wall > ISP Modem/Router > Wireless router(if any) > Wired/wireless
If using DSL, a DSL Filter MUST be on ALL devices, phone, answering machine, faxes, etc..., everything EXCEPT the DSL Modem/Router.
You may share a DSL Filter.
Wall > DSL Filter > Splitter > Multiple Devices
RFick
Jun 11, 2011 | Dell 966 All-In-One InkJet Printer
Where to plug in the phone line for the fax
You don't plug a phone line into this printer. It's not a fax machine itself. According to the user's guide (which you can download here), "To send a fax using this printer, you need to have the printer attached to a computer that is equipped with a modem and has Microsoft Fax installed."
What this means is that the printer is just serving as the input (scanner) and output (printer) parts of a stand-alone scanner, but you need your computer to connect to the phone line. Without the computer modem and Microsoft Fax software, your printer is, well, just a printer, with scanning capability.
Sorry! Thanks for using Fixya.
Nov 19, 2010 | Dell 944 All-In-One InkJet Printer
Faxes are being received however they are not printing out.
Please check the fax circuit cable connected properly or restore from its contol pannel setting
Jul 26, 2010 | Dell 966 All-In-One InkJet Printer
On lexmark 7170 printer-when trying to fax-always get ''phone line error''-- connection is good from directline--phone works- Can't fax even without using pc I am using a Lexmark7170 printer with windows...
Hello. The "phone line error" usually comes up when the printer/fax is not connected properly to the fax line. Try to check behind the printer. There are two phone ports - Ext. and Line. The telephone cable should be plugged in to the Line port of the printer and the other end should go straight to the phone jack in the wall. If it is, try to use a different phone cable. Also, make sure that you assigned the correct fax number in your printer. Hope this helps.
Mar 20, 2010 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Every time I send a fax from my Dell 966, a black stripe appears down the middle. All photocopying/printing is operating normally, its just the fax that won't work! How do I fix this?
its quite possible the area that scans the paper(s) you are sending is dirty.
If the machine is one of those phone/fax/scanner/copier jobs, simply open the top panel, and with a damp cloth, wipe the runners that feed the paper through from left to right or right to left (just make sure any dirt you're wiping goes off to one side)
its also possible that a paper (that white-out was used on) that has been recently faxed, left some white out on the feeders
Aug 16, 2009 | Dell 966 All-In-One InkJet Printer
When scanning in documents
Open up the document feeder and clean the small scanner glass.
Dec 29, 2008 | Dell 966 All-In-One InkJet Printer
Dell photo 966
check the properties of fax may be it need some updation..
and other point is that u should reinstall fax drivers from the disk which is given with printer.
hope it will help u..if need help ask me...
chirag
Apr 01, 2008 | Dell 966 All-In-One InkJet Printer
Dell 966 All-In-One InkJet Printer Logo
233 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
