Question about Intel Motherboard
When turning on computer it doesn't power on just the power light
Ms7207 motherboard when the computer is turned on, only the power light comes on and there is a single flash. How can this be fixed
Check the power supply,batery @ maybe u should by new motherboard
Posted on Jan 02, 2009
My hp v75 monitor doesn't come on. All the lights
Make sure the VGA cable is properly inserted to your pc and monitor
Jun 29, 2012 | Computers & Internet
Green light on. computer wont turn on
Unfortunately, if the light is on, but the computer won't power on, it means one of two things. Either the power cord is broken in some way and no long sufficient to power the computer, OR the motherboard is dead. You can try to purchase a universal cable from Best Buy for instance, and then return it if it doesn't solve your problem. A motherboard repair would be best done through Acer themselves, although, it can cost over $300.
Aug 23, 2011 | Acer Aspire 5735 Notebook
Hello. We were hoping that you can help. We have a Toshiba LCD, 40G300U3. When we turn the power on, the green power light turns on and we can hear sound coming from the speakers ... however the screen...
Take a flash light into a dark room with your laptop, and shine it into the screen when it is on. If you can see the screen then more than likely your back light is out.
If you do not see an image with the flash light, then more than likely your motherboard or LCD is going bad, this needs to be tested by a computer profession to see which is going bad.
Jul 17, 2011 | Toshiba Televison & Video
I have a Gateway Desktop computer, and I have had it for a couple years, and it just wouldn't turn on. So I need to know if that means that computer is dead?
Check for any lights. Usually a computer would have a flea light on the motherboard as soon as you plug it in. If it doesn't have a flea light, start with the power supply. Swap the power cord of the monitor with the power supply of your desktop. If it still would not show power, try replacing the power supply. Worse case, you may need to replace the motherboard of your computer which would cost a lot.
Jun 27, 2011 | Gateway Computers & Internet
The LED in my motherboard is on, but if i turn on the switch, their is no response. the power connection is correct. but it doesn't work
Try swapping the power button connection with the reset button connection. Then to turn on your computer you will need to press the reset button. If that works you have a faulty power button. Otherwise try using a different PSU. One that you know works. If that doesn't help the motherboard will have to be replaced.
Jun 18, 2011 | ASUS P5VD2-VM SE - Motherboard - micro ATX...
MY COMPUTER IS NOT COMING UP
when you say not coming up meaning not turning on?
>If its not turning on and no lights even on power button but monitor is powered up try swapping power cable of monitor to your tower to check if its just power cable issue
> if still not turning on and no lights at all then you have problem on power supply
> please advise me if the computer gets light because youre problem might be caused by a different thing if the system is turning on but its not booting to windows so please provide complete details of the problem
Jun 05, 2010 | Intel Desktop Board D845GLVA...
My tower has power but won't come on
first guess is the motherboard is bad
a few things you can try:
unhook the monitor from the computer and test it on another computer. If the monitor works then its most likely the motherboard.
leave the computer unplugged for a few hours then plug it back up and give it another try just in case it overheated.
have the computers power supply tested as a bad power supply can cause all sorts of issues.
other than that you are down to a new motherboard and or a new computer.
Sep 09, 2009 | Compaq Computers & Internet
Replacing bad motherboard, but now sure where some of the connectors go
They all have some letters on them (as well as on mobo) indicating where to connect
Feb 02, 2018 | Intel Motherboard
Hooking up the wires correctly??
may be the RAM of the computer is decreased during transfer withput ur knowledge . u know what was the previous amount of RAM ur computer had and check in system properties if the same squantity of ram is available . this may have slow don the sytem , try to remove unwanted starup options also
Dec 14, 2007 | Intel Motherboard
Intel Motherboard Logo
77 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
