Question about Polaroid PDV-0701A Portable DVD Player
Input to 3.5mm jacks
I need to send a audio visual from a camera with those yellow / white TV jacks to 3.5mm jacks on a portable DVD player. Can I just find cables that fit each or do I need an RF modulator?
Thanks for the time.
    Problem Solver:
  • 4 Answers
This unit should work great for that...it has an A/V in/out switch so you can use it as a monitor...I plug output from a cable tv box into and we use it to watch tv
Posted on Jan 04, 2009
Connect DVD player to TV red white and yellow wires
1. Connect the audio cables to the AUDIO OUT L (left - white) and R (right - red) jacks on the back of
your DVD Player, and to the corresponding Audio Input jacks on your TV.
2. Connect the video cable.
• Basic video connection
- Connect the video cable (yellow) to the VIDEO OUT jack on the back of
your DVD Player, and to the Video Input jack on your TV.
OR
S-Video
(optional) - If your TV has an S-Video Input jack, connect the S-Video cable to the
S-VIDEO OUT jack on the back of your DVD Player and to the S-Video jack on your TV. If your
TV doesn't have S-Video, use the basic video connection listed above.
Mar 18, 2014 | RCA RC5240P DVD Player
I am trying to hook up a Memorex DVD player (MVD 2022), and I am not getting it to work. I need to see how to connect the cords or what cords I need. I can't seem to find how to download a manual.
Connect a yellow RCA cable from the yellow video jack on the DVD player to the yellow video input jack on the TV. This will give you the picture. For sound, connect a white RCA cable from the white audio jack on the DVD player to the white audio input jack on the TV. This will give you sound. Use the TV remote to select the input you connected the DVD player to, just press INPUT SELECT or VIDEO or the like until you see the DVD player's output.
Power on the TV and the DVD player. Place a DVD in the disc tray of the player and press PLAY.
If your TV has only a RF coax input, then you will need to buy an RF Modulator.
Mar 15, 2011 | Televison & Video
What channel do I set the TV on so that the dvd will play
Hook audio/ video cable from dvd player to AV input of tv and select that AV input in tv to watch dvd playback picture.
You will see yellow jack (for video signal output) and red-white jacks (for audio left-right output signal) at rear of dvd player, plug AV Cable and hook it in AV input of tv, make sure yellow pin connected in yellow jacks of dvd and tv.
Thanks.
Feb 18, 2011 | Sony DVP-SR200P DVD Player
How do I connect DVD to TV please
on rear of tv you will have video and audio input jacks red and white are audio yellow is video , make sure they are input jacks the jack will be labled and and on back of dvd player will be red white and yellow jacks that are labled output using the cables supplied with the dvd use the red and white insert them on dvd out corresponding colors and the yellow into the video out, now on the tv take the other end of the cables and insert them into the audio and video inputs again with the corresponding colors audio red and white and video yellow ,,,I hope this helped
Nov 10, 2010 | TruTech Televison & Video
I need to connect my Panasonic DMR-E85H DVD to an old HMV TV. I need to know what the frequency of the out pout would be for the A1, A2, A3 output channels from the DVD and what the input frequencies...
It doesn't use TV channels, it uses AV, Audio Visual, input. That means you hook up, to the, whats called the EXTERNAL Inputs, A1, A2, A3, these are the external inputs that relate to the Jacks on the rear/side of the unit. You use the output from the DVD, and hook it up to the AV input on TV. Press Play on DVD and Select, correct external input on TV. Usually it;s Yellow to Yellow Red to Red and White to White.
Mar 02, 2010 | Panasonic DMR-E85H DVD Recorder
I am wanting to connect my portable wharfdale dvd player to a tv. where can i get the right connection cable. thanks
Usually somewhere like radio Shack will have those cables, they are called AV, Audio Visual Cables, You need 3 Cables, with "Male Jacks" at both ends, usually Red & White, (The Audio), & Yellow, (Video). They connect color to color at each end, and on the TV you select "Aux", "Extern", but NOT a channel. If you have "Component Video, then you will need a set of 3 & 2 cables, (5 all together) Blue, Red, Green, ALL Video, & White & Red, Audio. you select the "Input" on the TV the same as for AV. So with AV, you use 3 cables, with Component, you use 5. If HDMI you need a single HDMI cable. cables.
Feb 21, 2010 | Televison & Video
Coby DVD player set up
Brenna,
Here are some things to remember when messing with cables TO and FROM electronic audio/visual
devices. YELLOW connectors are for what you SEE on the screen of your TV or other viewing device.
The RED/WHITE connectors are for what your ears will hear, LEFT/RIGHT in stereo or mono.
Now all you need to do is connect the YELLOW output jack of your Coby to the YELLOW video
input jack on TV. You must remember forever and ever that the YELLOW jacks and plugs never
contain or transmit or move TV channels or CABLE channels or DISH channels. The YELLOW cable
which has plugs at both ends goes to jacks (output to input) and carries/transmits BASEBAND VIDEO signals only. Now all you need to do is make the TV stop listening to it's antenna in, and to
start listening to the YELLOW/RED/WHITE jacks on the back of the TV. You will need find out how
to put TV into MONITOR mode, or AUX mode, or VIDEO INPUT 1. Basically just match colors and
OUTPUTS to INPUTS. Hope this helps you out.
louie12fix @ fixya
Dec 17, 2008 | Coby DVD-224 DVD Player
Sony CD/DVD Player DVP-NS501P
There are several ways to connect the TV to the DVD player but you can only take advantage of the progressive scan option on your player if you use component cable. Component cable has three input jacks on it and they are colored Green, Blue, and Red. Your TV/amplifer must have component input jacks on the back of it to use this cable. If it does, then the input jacks on the back of the TV are usually labled Y, Pa, and Pr. The Y input is for the Green input jack, the Pa input is for the Blue input jack and the Pr is for the Red input jack. Once you have these plugged in you will next need to hookup the audio/vidoe cable that came with your DVD player that has a Yellow, White, and Red input jacks on it. The Yellow input jack is for Video and the White and Red are for audio. Both your TV and DVD player will have inputs for these so just match them up. If you do not have component inputs on your TV then just hook up the audio/video cable and it will work.
Nov 07, 2008 | Sony DVP-NS501P Progressive-Scan DVD/CD...
Tv connection
connect the composite video output of the player to the composite video input of your TV. The jack should be marked in yellow. Then connect your Audio input of the tv to the Audio out of the player.
Oct 09, 2007 | Philips PET710 Portable DVD Player
Connection to a portable tv
The RCA set on a tv [Red /White /Yellow] are INPUT[ VCR/DVD player] not out put. Hook the speakers up the the 3,5mm earphone jack though you will need a conveerter plug like this
Jun 30, 2007 | JBL CREATURE II Computer Speakers
Polaroid PDV-0701A Portable DVD Player Logo
62 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
