Question about Samsung HLN567W 56" Rear Projection HDTV
Samsung HLN567W has as lound hissing sound while on. Picture is fine and sound is fine other then the over ridding hissing sound coming from the back.
  • 42 Answers
That is the color wheel needing to be replaced. Very common for this mode.
Posted on Feb 12, 2009
Have Samsung HLN567W and recently started having
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 12, 2010 | Samsung HLN567W 56" Rear Projection HDTV
Hissing sound
Do you mean audio hissing sound or is there smoke coming out the back?
Audio hiss with the FM tuner selected would mean it's between stations or you don't have an antenna. Try tuning around the band with an antenna.
Close what?
Connect what to what tuner? It has an internal tuner.
Apr 04, 2009 | Audio Players & Recorders
Samsung HLN567W rear projection picture flickering
Your color wheel must be replaced. They are about $100 including shipping
Jan 23, 2009 | Samsung HLN567W 56" Rear Projection HDTV
Fuzzy connection on my samsung DLP HLN567W
Try the DVD player on another component connection on the TV. If the picture is still distorted try another DVD player or something with component output. If thre picture is normal with another input device then the issue is the DVD player,
Nov 28, 2008 | Samsung HLN567W 56" Rear Projection HDTV
Samsung hln567w Gray horizontal lines
have you tried a system restore to get your resolution back?
You may then try to take a different path in fixing your problem.
if you cant system restore try installing the previous driver you had.
could you post up what your "computer problems" were exactly?
the more info the better*
We may know another solution for it other than updating your driver and losing you resolution options
Aug 23, 2008 | Samsung HLN567W 56" Rear Projection HDTV
My TV pictures turns black afetr a few hours but I still can hear sound perfectly!!!
It sounds like your rptv lamp is going out. If this is an older DLP this is most likely the cause. You can get a replacement at www.laptopsforless.com part number BP96-00224J for $151. If the tv is still under warranty, I would have them do it, otherwise replace it yourself. If so here is a link to give you step by step instruction. Please give me a good rating. ;-)
Dec 18, 2007 | Samsung HLN567W 56" Rear Projection HDTV
Hissing Sound
A hissing sound that comes from the back of the set (not from the speaker) usually indicates a high voltage leak, most likely around the "suction cup" at the top of the picture tube or around the flyback transformer. Remove the back of the set and turn it on, and when you hear the hissing sound, shut off all the lights in the room and you should be able to see a purple-ish or white-ish glow from the spot that is hissing. Shut the set off, discharge the high voltage and clean and seal the problem area. Of course this should be done by someone experienced with stopping high voltage leaks.
Jun 22, 2007 | Durabrand DU1901 TV
Samsung HLN567W 56" Rear Projection HDTV Logo
124 people viewed this question
Henry  Thomas
Henry Thomas
