Question about Whirlpool Calypso GVW9959K Top Load Washer
2000 Calypso Kenmore Elite (wash motion) it has a slight leak, we have no clue where it is coming from, my husband has it laying on down to see, all the hoses look good, we cant tell if its the clamps, could it be something else.. I dont know our model number, but it was bought in 2001 and they told it was a year old model
  • 640 Answers
Dont lay it down,,,,stand it up and lean it back than fill with water,,be careful use a prop..another way is to slide news paper under unit,,than we can tell what area its leaking from..unit make only leak in drain,,so we have to test unit in drain to ckeck that system,,onthejob
Posted on Jan 09, 2009
Both the coupler and the lid switch have been replaced yet unless you lift and close the lid it won't engage the spin cycle
Search Results
    Why am I getting an FL error code on a Kenmore Calypso ...
    www.shopyourway.com > Manage My Life > Questions
    I have a Kenmore Calypso washer model 11022062100 and there is water in ... Why am I getting an FL error code on a Kenmore Calypso washing Machine?
    fl error code on calypso washer-need help!! - Home Forumsths.gardenweb.com > Home Forums > Laundry RoomJul 22, 2006 - An FL error code keeps flashing on my Calypso Washing Machine. I can't do laundry. Could someone please tell me what I need to do to ..."F dl" light come on - Kenmore Elite HE3 Washing Machinehttps://www.ifixit.com/.../Why+is+the+%22F+dl%22+light+come+o...iFixitThese are the errors for error code F/dL Door Lock Error Condition A Door Lock Error... The Kenmore Elite HE3 is a washing machine by Kenmore. ... On Amazon I was able to get the CCU (Kenmore CCU Central Control Unit .... and a dose of WD40 on those contacts should keep that from misbehaving in the future as well.Kenmore Elite Calypso FL error code - ApplianceBlog
Jan 27, 2016 | Washing Machines
Kenmore elite calypso doesn't respond to buttons except cancel
I've had a similiar problem on my calypso. In my case the key pad would go dead after washing or pushing stop after a few minutes. If I unpluged the unit for a few minutes it would work again. This would appear to be in the controller board. I removed the board and inspected it finding no problems. After re-installing the board the washer appears to be working again. My conclusion is that there is a loose connector/connection. I'd suggest you remove and re-install all the connectors on the controller board. This is the board closest to the power chord.
Good Luck, George S.
Sep 10, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Where is the reset switch located on the Calypso
There is no reset.
Simply unplug for 40 minutes to reset the ECU.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 19, 2009 | Kenmore Elite 45986 Front Load Washer
Found broken part in my kenmore calypso washer
sorry any problem is a common problem on calypsos, its a techs nightmare. sounds like your better with new machine.
Mar 14, 2009 | Kenmore Elite 45986 Front Load Washer
I have kenmore elite calypso wash motion washer and there is a flashing light the reads FL what does this mean.
flood lock you need to drain all water from machine and clean out pump somethimg cloggimg pump
Dec 08, 2008 | Kenmore 24032\24036 Top Load Washer
Plastic in drum
REMEMBER IN 4- 6 -8 MINUTES IS YOUR DRAIN AND SPIN CYCLE, PLZ INSPECT PUMP,,, AND SUMP THAT WILL RESOLVE YOUR PROBLEM
Nov 25, 2008 | Kenmore Elite 45986 Front Load Washer
How to Open up a Kenmore Elite Calypso Wash Motion Washer
If this is a Calypso, there are retaining clips holding the top down in the front of the washer. You will need to look along the seam where the top meets the front panel the washer about 2 inches in from each side. Using a putty knife, insert into the seam and push straight in while lifting on the top. The retaining clips will release and the top lifts up. It may take a second set of hands to make this a little easier. When you get the top lifted up, there will be a couple of screws holding the front panel in place. Remove them and you have access to the interior of the washer. If this is not a Calypso, please post back so I can give you correct advice. I hope this helps you.
Apr 06, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Washer leaking
On the front of the machine there is a oval shaped medallion that says 'whirlpool' - pop that out and remove the screw. Next, on the sides about two inches back from the front there are two posts that help hold the top on - use a wide screw driver or putty knife to pry the top up. Once the post disengage it's a easy sailing, sort of.
Apr 04, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
111 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
