Question about Canon PowerShot A70 Digital Camera
Camera dropped in water, flash broken
I acidentally dropped my friends camera down the toilet on New Years Eve. I took the battery out straight away and put it in the airing cupboard for about 24 hours. It is working pretty much as normal, except the flash isn't working. Any ideas how much it would cost to fix the flash, or if it would simply be cheaper to buy a new camera?
  • CameraR
    CameraR May 11, 2010
    Water is a killer of cameras. It's kind of working now, but trust me it will get progressively worse and eventually totally fail as corrosion sets in. It's doomed. Yes it's time to consider a new camera. The A70 was nice, but have you seen the new Canon A590 IS? Check it out on Amazon, think you'll be pleasantly surprized at its price and what it can do.
    President:
  • 570 Answers
Http://www.fixya.com/support/r3771170-phone_water_damage
Posted on Jan 08, 2010
Camera won't stay on
If you don't hear any abnormal noises and the camera simply shuts off, make sure you are using fresh batteries. Some older camera models are sensitive to voltage and amperage drops from batteries that are getting too old. Duracell Quantum batteries should do the trick, and are a good price for the value.
If this does not work, you may have to do some surgery. Inside of the DSC-S40 is a very tiny button cell lithium battery. I'm not sure the exact size and rating, but you may want to try removing this tiny battery and replacing it with a similar or better one. It is soldered on with metal tab power leads. You might want to use a 40 watt soldering iron with a very tiny pin head sized tip when you place the new one in. Do not allow it to heat for more than 3 seconds. when you add your own solder to the new battery, it should only take 1 - 3 seconds for it to bond to the battery halves.
I remember having a friend donate his broken one to me and his did not work. It turned off as soon as you put power through it. What I did was take 2 small 30 gauge wires and temporarily lead them to the broken camera, directly on this button cell battery's terminal. And it worked!
The last thing I could recommend for you is to disassemble the camera more completely and make sure the lens system is not jammed. Although there usually is an on-screen error flashing if any part of the lens system malfunctions.
Good luck! But seriously, look into a new camera. This one is pretty dated. But I do commend you for trying to save it. This is a rare camera to an extent. It uses a pretty decent CCD based image sensor and the sharpness is good in various lighting environments. The video bitrate and resolution are outdated, but the color accuracy seems to be better compared to more modern cheaper cmos based point and shoot cameras.
Feb 10, 2014 | Sony Cyber-Shot DSC-S40 Digital Camera
I dropped my camera in a shallow bowl of water, and took the battery and card out straight away and left it to dry out overnight. I've tried it again today, and its taking photos again, and the lcd...
1. The best thing to do is to factory reset the camera to be sure everything
is in the default setting. Look in the manual or menu to RESET the camera.
2. If this does not work, you can try is to remove the battery and wait a day,
then put the battery into the camera again and recheck.
3. If that does not help either, your camera might need repair/maintenance.
Sep 03, 2011 | Olympus EVOLT E-410 Digital Camera
TOILET WONT FLUSH AWAY PROPERLY
I believe what your plumber was referring to are the flushing orifices. Yes they have changed through the years. Unless you have a pressure assisted toilet, the orifices are what makes it flush, by breaking the trap seal and creating a vacuum. Now that being said you can check to see if this is the problem by filling up a bucket with aprox. 2 gallons of water and dumping it straight into the bowl. It should flush right down with out hesitation. If it does then your orifices are not working properly. If this is a new stool, it is possible it is just a bad mold and should be replaced. I hope this helps. Your new toilet should flush for you.
May 08, 2010 | Home
I acidentally dropped my camera memory card and stepped on it. Now the metal piece (the reader) is missing and the card won't read.
Compare the damaged memory-card with a non-damaged memory-card.
If you've broken-off the gold-coloured contacts from the edge of the memory-card, then your memory-card is broken beyond repair.
Tough luck.
Jan 04, 2010 | SanDisk 2GB microSD Memory Card
How to install a toilet trip lever
Ok eve, Here is the concept of the workings. The "ball" is hollow, cone shaped and open on tje bottom. On its side there is a hole.
When you lift the Flapper ball, the water drains outand as it does the flapper fills with air so it won't close until the water level drops. The hole in the side bleeds out the air so the flapper will stay down once it is seated in the drain hol. Tank fills and the water pressuer og the filling water increasrs the pressure to hold the flapper seal and covering that vent hole. When you press the lever it has to be held long enough for the water lrvel to drop below the raise flapper so air can get under it or it will immediately drop because the draining water pulls it with the current. So, the adjusting chain mus be short enough to raise the flapper about 45 degreees and held till the water level drops below it. One thing that dictates the amount of time you have to hold it is the water level in the tank. It should be about 5/8 inch from the top of thr frain tube. If water level is correct the flapper will surface enough to grab air in a much shorter time. So the water level is important. Cycle it and you will see what I mean. Good Luck _Ned_
Let me know if your problem persists Eve. I have one doing the same thing . Make sure the lever is lifting the flapper straight up as possible
Nov 01, 2009 | Dmm Mansfield 106 Barrett Toilet Tank and...
Drop GE A1230 digital camera in water. Let dry and now wont power
Unfortunately, there are several parts that may be damaged with water. It doesn't matter if it's already dry. Water contains lots of minerals and other material that are conductive. Once the water evaporated, the conductive materials stays in the electronics.
As you have a broken camera anyway, you can try:
* Using a hair dryer, blow some hot air (no the hottest level) inside the camera. protect display away from the heat.
* Get a new camera to replace the damaged one.
Sorry Ricky, I don't think it can be fixed.
Aug 29, 2009 | Canon PowerShot SD850 IS Digital Camera
Camera will not work
Using the wrong cable can certainly damage a camera.
You don't say what "inoperable" means. I have sold and serviced many digital camera over the years. Dropping a camera will often result in damage to the lens assembly causing blurry/distorted pictures or the lens will not extend or close.
If the camera is completely dead or fails to boot then you probably used the wrong cable or connected it incorrectly and fried the internal electronics. This particular Gateway/Samsung camera can be fried if you connect or disconnect the USB cable while the camera is power on.
Sounds like you owe your friend a new camera.
Jan 03, 2009 | Gateway DC-M40 Digital Camera
Camera won't work after being dropped in toilet
http://www.fixya.com/support/r3771170-phone_water_damage
Oct 07, 2008 | Kodak EasyShare Z730 Digital Camera
Camera dropped in a bucket of water
I very much doubt it. If you had removed the batteries straight away, stripped the complete camera and let warm air waft over it for a day and then put it all back together and tried it, you may have been lucky. But wet circuit boards and electricity is asking for major problems. Even leaving a closed camera for 2 days wouldn't have given it a good drying out.
Jun 13, 2006 | Panasonic Lumix DMC-FZ5 Digital Camera
Canon PowerShot A70 Digital Camera Logo
134 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
