Question about Sony KP-53HS30 53" Rear Projection HDTV-Ready Television
The dark colos have a lil' green on them...why?
I have a sony kp-53hs30 53 in. and the dark colors and the black shadows have a lil' green on them and if u change the temperature color the only one good is "vivid" cuz the other ones are greenish.....what makes me use the bright all the way in order to watch tv...what can i do? is worth it to fix it? and like about how much we are talking about? Thank u....
    Scholar:
  • 150 Answers
How old is this set? Sounds like a CRT issue, might be able to adjust the G2 control (SCREEN), you will have to pull the bottom pannel off the front and there should be another little 1/4" thick board that comes off with a few screws and then a 6 knob control, turn your color all the way off in the menu and adjust your screen controlls up till you get some overcolor with lines in it and then back down just before the lines (MAKE SURE YOU DEFAULT ALL YOUR USER MENUS) check that you have a black and white picture after adjusting all 3 screen controls like before with the menu color off. If you have a bad CRT it will go again, the CRT may no longer be available, if the set is not too old i.e. 5-8 years old it may be a defect with multiple CRTs.
Posted on Jul 06, 2007
1. picture is getting darker 2. there is a green outline when the brightness is turned up
Hello ksolovy, i understood your Problem with the Sony KP-53V90 53 in. Rear Projection Television,In fact i encountered already that kind of problem you have it now. Check first the color wheel im sure that the blue section of your color wheel was burned and the blue color turn to dark; That's why you have seen dark picture, Re-place color wheel.
Dec 21, 2010 | Sony KP-53V90 53" Rear Projection...
Our 7 year old Sony TV KP-51W5510 has the following problem. Picture has 2 colors, writting has 2 colors the skin tone has 2 colors, writting on the screen will show 2 colors black and red in shadows pls...
a ladha,
You have lost the convergence circuitry. I have a tip at http://www.fixya.com/support/r4220499-change_projection_tv_convergence_ics which will explain the problem, tell you where to get parts and explain how to do the repair.
Thanks for using FixYa and for the great rating!!
hardrocko
Sep 12, 2010 | Sony KP-51WS510 51" Rear Projection...
Three pictures red green & blue and it looks concave
Install the Sony type 1 convergence repair kit available from www.tvrepairworld.com the kit includes the components and the cd with instructions.
Jun 30, 2010 | Sony KP-51HW40 51" Rear Projection...
Arched lines in dark screens whether it's Cable or DVD playing Model number: KP-57WV600 Sony 57inch rear projection TV
Ur convergence it dead.Do u know how to solders? Tries these websites. Tv repair World.com or Tvrepairkits.com have it.Buy a convergence kit used what in that kit ur tv well get back to normal.The shop will cost u $300 for parts and labors.
Jan 01, 2010 | Sony KP-57WV600 57" Rear Projection...
Colors on the left side of the screen are shadowed with duplicate
Your set has a convergence problem which is a common issue.
Take a look at this solution posted earlier on Fixya. It worked for me.
http://www.fixya.com/support/t2703612-double_red_image
Aug 20, 2009 | Sony KP-51WS500 51" Rear Projection...
Sony KP-511HW40 fleshing with green color and shuts off
this is a common fault adjust the little black box in front behind the small wooden cover. you will see 6 controls don't adjust any of the top 3 only the bottom knobs 1 for each color. slowly back the control counterclockwise turn the set on and wait untill it shows a picture, slowly adjust the control for the color in question utill the color balance is correct- black and white with the color setting turned down all the way with the user menu when balance is ok you are all set.. turn the color back up with user control. rtepeat process if needed.
Dec 26, 2008 | Sony KP-51HW40 51" Rear Projection...
Sony KP-51WS500
the tv needs to have a convergence done on it to realign the picture..the colors have to be set a certain way or it will show shadows and it will only get worse
Jul 11, 2008 | Sony KP-51WS500 51" Rear Projection...
White arched lines appearing on dark/black screens.
it sounds like you are seeing the vertical retrace for all three colors together (white). Its possible that all three screen adjustments (red, green, blue) are off, but I suspect a problem with the screen power supply.
there is also a recall on this set
http://esupport.sony.com/perl/news-item.pl?mdl=KP51HW40&news_id=24
Jan 23, 2008 | Sony KP-65WV700 65" Rear Projection HDTV
Blue shadows
Sony Too green,red or blue
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Nov 25, 2007 | Sony KP-53HS10 TV
Sony tv KP-57XBR10W
Correct ! One set is for RGB focus and the other set is for
RGB screen voltage............................T.
Oct 05, 2007 | Sony KP-57HW40 57" Rear Projection...
Sony KP-53HS30 53" Rear Projection HDTV-Ready Television Logo
55 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
