Question about GE WSKS2060WWH Top Load Washer
GE Spacemaker WSKS2060WWH has loud clicking sound on spin
My washer works fine except that on the spin cycle. It spins up just fine but, at higher spin speeds, when the motor cuts out, I hear what I assume is the splutch kind of grinding. It is like the splutch should disengage completely but does not, or it should stay in contact but is slipping. It was working fine until I replaced the main seal in the tub, after putting it back together I have this new problem. Apart and back together many times. New drive spring, clean and re-grease splutch. I had a hard time getting the tub off of the shaft, really had to work on that. Maybe I did some damage at that time? Any ideas?
  • Chuck Oct 21, 2012
    Can anyone help me with this?
  • Chuck Feb 12, 2013
    Anyone?
3 Suggested Answers
SOURCE:
  • 3 Answers
SOURCE: GE washer WJSR4160G0WW agitation is way too fast & hard
check the 4 rubber cords at the top of the tub. If the washer has been moved they may need to be adjusted, you can see them by looking between the top of the tub and the top cover. You can turn them with your hand, and you may need to tighten them after.
Posted on Sep 21, 2009
SOURCE: GE Washer Spin Cycle Problem
I have a GE washer and my problem is that do the washing just fine. but when it goes for the rinsing won't take water. I have to pur water manually with a hose so it can go then to the spinning..
Posted on Nov 04, 2009
Washer does not "click" to drain and spin cycle
Hi, Check the lid switch. Most models will not drain or spin when the lid switch is bad.
If I can get the model#, I wil try and asist you further.
Vic
Jun 21, 2009 | GE Spacemaker Washer and Dryer Electric...
GE Spacemaker No Spin
Most washers use a lid switch that closes the contacts when the lid is closed, look for a "probe" on the lid that pushes a "pad" that closes the switch, it's possible the switch pad or linkage is bent causing erratic contact closing, any way that is the first place to start. THIS IS A SAFETY DEVICE, DO NOT BI-PASS IT. Good Luck
May 21, 2009 | GE Spacemaker WSLP1100D Top Load Washer
Washer won't spin
Check the washer motor. Make sure that the motor is getting correct voltage and is working and spinning when you turn it on. It sounds like the motor is bad. You can remove the back cover to get to the motor to check it out
Feb 13, 2009 | GE Spacemaker Washer and Dryer Electric...
GE Washer Knocking During Spin Cycle
remove the agitator and inspect the main shaft on the gear box.and check the belt underneath.if the shaft is bend you will need a new gearbox. hope this helps.
Feb 09, 2009 | GE Spacemaker Washer and Dryer Electric...
Spacemaker spin cycle problem
you may have something stuck in the drain pump......
first try using a wet/dry vacuum attach it to the drain hose and try to **** out what ever you have stuck in there... if that works you are good... if not you will have to get open the cabinet to get to the drain pump
Dec 23, 2008 | GE WSM2480DWW Unitized Spacemaker Washer...
Washer won't spin
Kenmore HD top load Elite Pak II will not spin on cycle but pumps water out. Loud buzzing/clicking sound while on spin cycle.
Dec 11, 2008 | Washing Machines
Everything is working except the spin cycle
Sounds like the spin coil/brake solenoid is burnt out or broken. This is a coil situated on the motor plate under the machine with a lever attatched to it. When the machine goes into spin cycle, this solenoid pulls the brake away from the outer drum to allow the drum and agitator to spin together. The shaft that goes into this coil should move in and out freely. If tight, replace spin coil/brake solenoid.
Oct 31, 2007 | GE WSKS2060WWH Top Load Washer
Loud screaming sound during spin cycle
The screaming noise is probably from a dry bearing in the motor, it will probably come and go and shouldnt cause to much problem, they are supposed to be self lubricating but sometime they run dry.
Oct 18, 2007 | GE Spacemaker WSLP1100D Top Load Washer
G.E. spacemaker washer will not spin
possible faulty motor. Regards Advisor
Aug 22, 2007 | GE WSKS2060WWH Top Load Washer
the washer has carbon brushes on the motor if these are low the drum will not spin it needs these carbons to make contact with the motor
Aug 12, 2007 | GE WSKS2060WWH Top Load Washer
GE WSKS2060WWH Top Load Washer Logo
74 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
jimorris77
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
