Question about SanDisk Sansa e200 MP3 Player
My sandisk e200 wont add songs
One moring i woke up and said " I think i'll listen to my mp3 player," so i got my sandisk e200 and turned it on first it made me pick a language as soon as it came on (which it never did before) and then when i picked english i went to Music then into the song catageory and all my song were gone !!!! i couldn't believe it they were there right before i went to sleep. so i went onto my computer to put my songs back on and when i thought i had put my songs back on i turned it on and they still weren't THERE!!! what happened???? i tried windows media player 11 and juke box but no program would put songs on HELP!!!please
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 26, 2008
SOURCE:
All music from SanDisk e250 disappeared and it's not working well
When the message "no songs" appears in the player, next Sandisk instructions might help you to restore the player:
http://kb.sandisk.com/app/answers/detail/a_id/3/kw/no%20songs/p/555%2C662%2C618%2C622/r_id/101834
If you don't have the music on the computer any more, be sure to make a backup first as told in this link.
All support for the e200 series players:
http://kb.sandisk.com/app/answers/detail/a_id/4487/session/L3NpZC9kRUQ0SVlaag%3D%3D/sno/0#e200
For more help just add a comment.
Apr 21, 2010 | SanDisk Sansa e250 MP3 Player
My songs wont add onto my sandisk sansa mp3 player
What format are the songs you're not able to hear? It's possible that the songs are not in a format the Sansa can play.
Also, you can navigate your Sansa like a removable drive. Try going to "My Computer" and looking to see what's actually on the drive.
Nov 27, 2008 | SanDisk Sansa e250 MP3 Player
Can't listen to songs
turn up volume or push play
Mar 06, 2008 | SanDisk Sansa e200 MP3 Player
Songs and radio skips like a scratched cd
Your mp3 player works like a hard disk, make sure that it was not moving when you are listening to your music. If the problem is the same try to use a new headset/earphone on it. Loose connections on your headset/earphone makes you think that your mp3 player skips.
A Simple Thank you is Good enough
Jan 16, 2008 | SanDisk Sansa e200 MP3 Player
Sansa e200 froze
hold the menu button for about 15 sec. and it'll turn off
Dec 28, 2007 | SanDisk Sansa e200 MP3 Player
I NEED HELP !
Songs are in the wrong format
Dec 12, 2007 | SanDisk Sansa e200 MP3 Player
"unknown" songs taking up memory in my sansa e200
Renew music svc sub, convert to Mp3, or update/remove DRM licensing
Nov 25, 2007 | SanDisk Sansa e200 MP3 Player
Sansa e200 wont load music
Check if the player is in Autodetect/MTP then try retransferring the songs on the player. And before unplugging the player from the computer check if the files are transferred to the player click on the sansa e200 player on the left window to check if it had really transfferred the songs to the player. If it still wont work, try trasnferring songs using windows media player.
Jul 21, 2007 | SanDisk Sansa e200 MP3 Player
Sandisk e200
its just startup issue remove all the songs and u might see reset ... and see
Jun 26, 2007 | SanDisk Sansa e200 MP3 Player
SanDisk e260R 4.0G - Getting rid of Rhapsody
I had the same problem. In the end I reformatted the e200. To reformat hook up to your pc and there should be a reformat option on the e200 icon.
Feb 07, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e200 MP3 Player Logo
52 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Gyula Lacz
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
