Question about HP Media Center m1170n Photosmart PC Desktop
Power My computer will not turn on. light on power pack blinks when plugged in but goes off when unplugged. Can you help me?
  • 1 more comment
  • tresa2 Jan 01, 2009
    No beep and no fan
  • gordy282 Mar 05, 2009
    I SHUT THE COMPUTER DOWN AND OPEN THE SIDE AND WAS CLEANING THE DUST OFF THE FANS INSIDE AND PUT IT ALL BACK TOGETHER AND WHEN I WENT TO RESTART IT THE BLUE LIGHT ON THE FRONT DOES NOT COME ON AND NO POWER IS COMING ON AT ALL...... THE LIGHT ON THE BACK OF THE COMPUTER NEXT TO THE POWER CORD IS FLASHING ON AND OFF... WHATS IT SOUND LIKE TO YOU!!!!!!!!!!!!!!!!!!!!
  • junior_f May 11, 2010
    Do you hear a beep when you turn it on and do you hear the fans start?
    Problem Solver:
  • 13 Answers
No beep and no fan can be a dead circuit in the powerpack, however if you have quiet fans like i do (virtually silent) then it maybe the bios or a dead motherboard. I recommend opening the computer case, discharge your body from any static (usually you can do this by touching the metal side of the computer) look for the CMOS or BIOS battery (which looks like an oversized watch battery) take it out and leave it out for 1-3 hours. After that you will have to program you BIOS ( date and time mainly) if it turns on..if not, then more than likely you have a dead motherboard and/or you might want to take it to a qualified computer expert asap.
Posted on Jan 01, 2009
  • junior_f Jan 01, 2009
    oh be sure to put the battery back in...and also make sure you uplug the computer before you open it as it could cause a deadly shock
Power supply in HP slimline s7310n
It sounds like the CPU is over heating. It probably has poor ventilation. Unplug the unit and open the side panel. Carefully vacuum all the dust inside. Be careful not to damage any electronics. You can use a small brush to loosen the dust before vacuuming. Good luck!
Apr 11, 2017 | Computers & Internet
Hp pavilion slimline power supply
you bringing a marginal part or connection back up a working state. when it cools or voltage drops it goes to the non working state. hp power supplies are not good to begin with. replacing it will fix it till that one also fails
May 23, 2017 | Computers & Internet
I have a Mitsubishi WS-55515 that was unplugged, when It's plugged back in there is power but no picture and green light flashes then the power goes off. For reading other posts I believe it is th
if set has been unplugged plug it in and try to turn on===when power light goes off in seconds:
on the front of the set press and hold both the menu and input buttons for five seconds and release both.
power light will blink a two digit error code like 2 blinks, 2 blinks pause and repeat it several times.
what error code do you find?
Apr 11, 2012 | Televison & Video
Power was turned off to the house. When power came back the router is blinking blue lights and can't see the modem. Disconnected the computer from the wireless and plugged directly into modem and it's...
just as a guess try unplugging power to both modem and router, then plug only modem in first until connection light stops blinking and goes solid. then plug in router.
Dec 23, 2010 | Linksys WRT160N Wireless Router
My 42" Phillips Tv will no longer turn on. The power light continues to blink in red and when unplugged and plugged back in it almost acts as though it will turn on again but goes back into turn off mode...
you have a bad power supply, and the tv goes to protect mode, undo the back and look for any bulged or open cap, and replace it.
Fosg2000, please rate me
Mar 17, 2010 | HP LC3760N 37 in. LCD HDTV
I have an Acer AL1912 that when you plug in the ac, the green power light will blink for about a minute and a half then go solid. The backlight will come on and you can see a faint ghost of vertical lines...
If it is still in warranty call the manufacturer.
if not give more info elah4@zoominternet.net. May be somthing simple like a cable
shutdown computer unplug then disconnect the video cable on the computer from the monitor, plug monitor back in and turn it on, there should be a display that says no video source within a few seconds, if unit is working properly. shutdown and connect video again and then reboot computer. sometimes it just takes a compleat power disconect to reset things,
Jan 30, 2010 | Acer AL1912B 19" LCD Monitor
Dell E173FP Monitor requires unplugging/plugging back in to wake
Perhaps your computer is hibernating instead of going into standby which takes a little longer to wake up from. While you are playing plugs and cables it give it enough time to come out of hibernation.
When the computer is in this mode the USB ports turn off which disables keyboard and mouse so the only way to wake up the computer is to press the power button on the computer itself.
One tell tale sign a computer is in hibernation is that the power light on the computer will slowly blink.
I hope this helps.
Aug 08, 2009 | Dell Computers & Internet
Dell pc dimensio 5150 wont boot up
If the power light is blinking amber - The computer is receiving electrical power, but an internal power problem might exist.
Ensure that the voltage selection switch is set to match the AC power at your location (where power cord goes into unit).
Also try simply unplugging the unit from the wall outlet for a minute then plug it back in and boot it up.
Feb 14, 2009 | Dell Dimension 8400 PC Desktop
Turning on i guess
It should work OK once you plug it back in. Note there are three places to check the power connection.
- The power pack has to be inserted firmly
- the cord that goes into the power pack
- the cord into the wall - be sure to check the wall outlet with a lamp or something to make sure it's not an overall power problem/breaker, etc.
Steve
Sep 11, 2008 | Lexmark X5470 All-In-One InkJet Printer
Won't turn on - lights appear for a second then nothing
Probably a poor power connection either where the AC pack goes in to the wall (probably powerbar!) or where the plug from the power pack goes into the unit. Wiggle the various connectors to see which one solves the problem. As a last resort you may have a faulty power pack (try ask a dealer or friend to test your system on their power pack).
Apr 14, 2007 | JBL CREATUREIIWHITE Computer Speakers
HP Media Center m1170n Photosmart PC Desktop Logo
116 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
