Question about Panasonic DMR-ES40VS DVD Recorder/VCR
My dmr-es4ovs only flashes 12:00a and rc1 when i push on
I cannot get a setup screen on the tv but it will play tapes or dvd using the tv remote. when i push the on button on dvd remote it flashea 12:00A and when i push different buttons it switches to RC1.i have tried standby and disconnecting the ac powercord and it does not help. i would greatly appreciate any help.thank you
  • 84 Answers
SOURCE: DMR-EZ47V
RCA: NUMBER: RC1, TITLE: Compatibility..... This code is for REGION CODE 1, meaning the DVD player is thinking that your region is different from that of your disk. Have you tried other disks? Still the same error?
I recommend you do a reset on your system to clear any user settings then try again with a disk you know to be from our region and let us now if you get the same error.
Notice that one of the SETUP options is RESTORE DEFAULT SETTINGS. You may or may not wish to use that option and start over.
Mean while I will see if I can find the service manual for your product.
Posted on Feb 13, 2008
SOURCE: remote control
turn on the dvd player
press and hold the 'enter' key and the '1' key at the same time
remote will start to work again
Posted on Oct 17, 2008
  • 5 Answers
SOURCE: when I try to fw a dvd it says RC1 ?
mine did this yesterday too - solution is not in manual -
press "enter" or "OK" on remote while holding number "1" for several seconds
Posted on Jun 16, 2009
SOURCE: my remote wont work
Try holding enter and 1 together for more than 3secs
Posted on Oct 27, 2009
SOURCE: Panasonic DMR-EZ47V DVD Recorder /
http://www2.panasonic.com/consumer-electronics/support/Video/DVD-Recorders-Players/DVD-Recorders/model.DMR-EZ47VK
http://www.retrevo.com/support/Panasonic-DMR-EZ47-DVD-Players-manual/id/2811ag420/t/2/
To get into Service Mode, first put the machine in STANDBY mode, then press the buttons ChUp OPEN/CLOSE and REC all at the same time on the front panel (Ch Up is hidden inside the AV3 input flap). Eventually the front panel display will show "SERV" (after its "HELLO" messages). Anyway, pressing [6] then [5] on the Remote Control tells me that I have an Error Code of "04" which is a Digital PCB or Communication Error (whereas an Error code of "02" means a "Defect of RAM drive"). (To exit from Service Mode, press [0] then [0] which should get you back to "SERV" and then POWER-OFF the machine).
Hopefully, your manual will display your error codes.
Perhaps the remote control is not set to the same control code as your DMR-ES40V. Codes may be set to 1, 2, or 3 on the remote by holding down the enter button and one of those number buttons for several seconds at the same time. The factory default is code 1. Try 1 first. If that doesn't work try 2. If that doesn't work try 3. If one of those codes doesn't work you may have a bad remote or a bad sensor on your machine. On DMR-ES35V models the sensor is located just to the right of center behind the black window
Posted on Jun 23, 2010
My DVD player recorder stopped recognizing the remote other than to let me turn it on manually play tapes, dvd's, and record manually. All the display shows is RC2. I can change this to C3, Int1, Int2
Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician.
Dec 02, 2014 | Panasonic DMR-EZ47V DVD Recorder/VCR
DMR-EZ47V
Feb 13, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
My Panasonic DMR-EZ17 DVD Recorder keeps saying
You have to use the remote for this unit or a remote for a similar dvd recorder, when you have it hold the enter/ok button and the number 1 or which ever number your stuck on 2 or 3 for 5 second and then go into setup and change it to the one you want RC1 ,2 or 3 !
Jun 26, 2010 | Panasonic DMR-EZ17 DVD Recorder
My remote wont work
Oct 27, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
Panasonic DMR EZ48V will not go into Functions
HI I WILL LIKE TO DO A FACTORY RESET ON MY panasonic dmr-ez48v, WHAT DO I HAVE TO DO?
May 03, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
REMOTE PX-RC1 CANNOT GET CODES FOR A PHILLIPS DVD PLAYER
SEARCHING FOR YOUR CODE
If your device does not respond to the remote after
trying all codes listed for your brand, or if your
brand is not listed, try searching for your code. For
example, to search for a code for your TV:
1. Press TV once.
2. Press and hold P until the red LED blinks
twice, then release.
3. Enter 9 9 1. The LED blinks twice.
4. Aim the remote at the TV and press Power.
The remote sends IR codes from its library to
the selected device, starting with the most
popular code first.
5. If the TV responds, go to step 6. If the TV
does not respond, press CH+. The remote will
try the next code. Continue until the TV
responds.
NOTE: Press CH- to try the previous code.
6. To lock in the code, press P once. The LED
blinks twice.
7. To search for other device codes, repeat steps
1 to 6, substituting the appropriate device
key.
Mar 08, 2009 | Radio Shack 15-2142 Remote Control
Panasonic DMR-ES35V
I have a dmr-ez25eb DVD recorder and it has stopped Recording and playing back , the screen on the TV says that its a none recordable disc but I have been useing them from the time I purchased the DVD
Aug 31, 2008 | Panasonic DMR-ES10 DVD Recorder
DMR--EZ48V
Your DMR is telling you that it is set to listen for RC2 but your remote is transmitting RC1.
Two choices for a fix:
1. Put the remote back into RC2 mode by simply holding both the ENTER and 2 button for at least 5 seconds.
OR
2. Reconfigure the DMR to listen for RC1 by going into the function menus and selecting SETUP. Look for the remote control option. Change it to 1, it will currently display the value 2.
Enjoy.
Mar 19, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Panasonic DMR-ES40VS DVD Recorder/VCR Logo
37 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
