I have i-mobile 309 cell phone and i want to know if there is problem with my battery before i buy new one or in my cell phone bec. when i insert the charger and i switch on it's work properly but when i remove it my cellphone die. and when i press & hold the power button without charger it' s work but when i release holding the power button it's die too. can you help me to solve my problem. thanks.
SOURCE: Charging problem!!! PLEASE READ!
What if the motorola razor charger voltage is a bit too high? Does the phone reject the voltage or charge anyway?
SOURCE: I've bought cell phone Samsung
This is the duration of the factory battery from Samsung:
Battery Duration
Talk time
Standby time
Slim
up to 2.5h
up to 35h
Standard
up to 3.5h
up to 65h
Extended
up to 6h
up to 105h
You should be able to purchase a battery at any major retailer.
SOURCE: 6233 won't power on and i need help how to switch it on without the power button
you change the power button
SOURCE: samsung omnia problem trying to charge battery
It looks like battery is damaged... When plugged in to charger phone shouldn't power on. Try put it on charger when on and see if charging icon appear. (top right corner-battery status icon should change -insted of battery to charging.) Battery is fully charged after cca 4 hours, 80% after 2 hours.
SOURCE: inverted screen of my cellphone
unfortunately, there is no simple answer to this, the only solution is to take apart the phone, and reverse the wiring... which will usually be in a bracket... if it is, you should just be able to flip it, if not, you are gonna need a solder gun to create a hard bypass from the wire to the screen, either way, you have to reverse the wiring and this should fix the problem! hope this helps!
