Question about SanDisk Sansa e200 MP3 Player
Every time i turn on my sandisk e200 the language menu comes
I turn on my sandisk e200 and it atomatically go to the language menu . so then i pick a language and it worked fine . WHY DO I HAVE TO KEEP PICKING A LANGUAGE WHEN I TURN IT ON IT GETS SOOOOO ANNOYING !!!!! wtf is wrong with it!!!???
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 26, 2008
How can i change the language on my e200
Press the MENU button. Select Settings (four vertical slider controls). Select the second item on the menu. Select the desired language.
Oct 07, 2011 | SanDisk Sansa e200 MP3 Player
SanDisk Sansa Clip manual MP3 Player - Red how to get english on this, my player only shows some Asian font?
From main menu, select Settings (4 bars picture), find out FM..., you go up ONE (this is language), and select it, you can go up or down to select English.
Good luck
Jan 13, 2010 | SanDisk Sansa e200 MP3 Player
Why won't my computer recognize my sandisk player.....i just plugged in the usb cable directly in the computer....but it's not being recognized.
For the Sans e260, see the e200 series support site on "not recognized":
http://kb.sandisk.com/app/answers/detail/a_id/266/kw/recognize/r_id/101834
Solution 1 RESETTING THE DEVICE
1. Press and hold the Power/Menu button for approximately 20 seconds.
2. Release the Power/Menu button.
3. Press the Power/Menu button again to turn on the player.
NOTE: Resetting will turn the player off while it is frozen.
When RESETTING the player did NOT help
Solution 2
GOING TO MSC or RECOVERY MODE and next UPDATE FIRMWARE
STEP 1 GOING TO MSC MODE or RECOVERY MODE
For e200v1/e200R (Recovery mode only): Connecting in Recovery mode
For e200v2 (Force MSC mode only): Enabling MSC mode
Check your firmware, see the differences on next link:
http://kb.sandisk.com/app/answers/detail/a_id/193/related/1/session/L2F2LzEvc2lkL0NqNGJpNVBq
STEP 2 FIRMWARE REINSTALLATION OR UPDATE
ALL DATA ON THE PLAYER will be ERASED !
Method 1: Automatic, using the Sansa Firmware Updater
Method 2: Manual, downloading firmware from the Sansa Forum
For e200 series version 1 and 2 to the Forum e200 thread
For e200 series version Rhapsody to the Forum e200R thread
Need more help ? Just post a comment.
Dec 10, 2009 | SanDisk Sansa e260 MP3 Player
My Sansa e200 will turn on, thumbwheel is blue and SanDisk screen comes on, but menu won't come on. I have pressed and held the power/menu button down for app. 15 seconds several times to no avail. It is...
sandisk sansa e250 starts but then says refresh database. Menu is in back ground. Maybe frozen, and have tried to reset, but still come up with Refresh database.
Sep 27, 2009 | SanDisk Sansa e250 MP3 Player
I connected my SanDisk Sansa e260 Mp3 player and says connected
You can copy the music from the computer to the Player My Computer\Sansa e200...\music or to a micro sd-card.
Download user manual SanDisk e200 series.
Just pick the language you need.
Jun 13, 2009 | SanDisk Sansa e260 MP3 Player
The screen is dim and goes black everytime i touch the wheel
Here is the link to the user manual - in the Settings Menu, there is a way to change the frequency with which it dims:
http://www.sandisk.com/Assets/File/pdf/guides/e200/e200_userguide_en.pdf
Mar 24, 2009 | SanDisk Sansa e200 MP3 Player
My sansa e200 wont come on
try geting a new charger that what i did and it work
Mar 07, 2008 | SanDisk Sansa e200 MP3 Player
Refresh database
Sansa e200 provides a RESET function for unresponsive units. Press and hold the MENU button for 15 seconds, and this should work to regain normal funtionality. Please note: settings and adjustments from the last operation WILL BE LOST. The files however should remain.
Sep 19, 2007 | SanDisk Sansa e200 MP3 Player
Sandisk e200
its just startup issue remove all the songs and u might see reset ... and see
Jun 26, 2007 | SanDisk Sansa e200 MP3 Player
SanDisk Sansa e200 MP3 Player Logo
59 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
