Question about Kenmore 3.5 cu. ft. Front Load Electric Washer
Washing machine suddenly stopped working during cycle
Our kenmore 3.5 cu. ft. super capacity front load washer stopped working. it is 3 years old. the clothes in the washer at the time were sopping wet, so it did not complete the spin cycle before dying. it would not let me reset it and would not run a cycle. a repairman tried putting in a new circuit board, but the machine still did not work. help!?!?
  • 1 more comment
  • Anonymous Jan 12, 2009
    i can not say it any better . mine did the same thing today. it is 2 yr old
  • inlandshores Apr 05, 2009
    if it is not washing or spinning, the belt may be off. I did have that happen.. now it won't spin but it will wash..belt appears to be on as it does slowly turn after cycle is done to loosen clothes but does not spin on any cycle now. Kenmore 3.5
  • kpnguyen96 Apr 12, 2009
    I have the exact same problem. It is also purchase three years ago. The last thing in is the washer is soak and would not rise, drain, or do anything. When I push start, there is a low buzzing sound but that's it no beeping. It sound like it trying to work but nothing happens.
    Please help.
  • 15,935 Answers
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
Posted on Sep 12, 2010
I have a Kenmore HE 2plus front load washer and during any wash cycle the drum won't spin and at end of cycle displays F01
Front-loading washer Kenmore HE2 plus - spinning not ...
www.shopyourway.com > Manage My Life > Questions
My Kenmore HE2 plus washer has problems with spin funciton. almost all of the ... or twins size blanket, it just won't spin, even with extra spin cycle only. ... Check to see if the washer will spin without any clothes at all in the basket. ... My HE2 will wash a very small load. ... Any bigger loads The drum will try and turn but wont.
Front Load Washer Won't Drain or Spin Video: Washing ...
? 1:54
https://www.youtube.com/watch?v=wlMoT9rgvAg
Jun 1, 2012 - Uploaded by searspartsdirect
... won't drain or spin. For more front load washing machineinformation and repai. ... If the cycle has completed and water is still left in the machine select "Drain and Spin" to remove anywater remaining in the washer. This can be caused .... I have aKenmore HE2 plus front load washer. I can't seem to get it ...
Kenmore HE2 Plus 3.6 cu. ft. Front-Load Super Capacity ...
www.kenmore.com > Laundry > Washers > Front-load Washers
KenmoreFront-Load Super Capacity Washing Machine (4753) .... super wet, and to spin the empty drum after each load to hear if anything was caught in that gap. .... 1st of all: You cannot use any other detergent than HE rated detergent - PERIOD. ... will create too many suds and clog up the machine, and the clothes won't be clean.
Jan 15, 2016 | Kenmore Washing Machines
Kenmore super capacity washer3.5 not working lights flashes and stops
This is usually a sign that the drain pump filter needs to be dumped or an object has jambed the pump mechanism.
Jan 30, 2013 | Kenmore 3.5 cu. ft. Front Load Electric...
Kenmore elite he3 washer F02 error during wash cycle
You need to check for a blockage, F02 code indicates -- Drain blocked, kinked, drain filter plugged, or drain pipe exits too far above the washer.
Dec 22, 2012 | Kenmore HE3 Steam 7.2 cu. ft. Super...
Kenmore washer 3.5 super capacity. Machine spins
It sounds like your tub bearing is bad or going bad. It could be the adjustment on your spin cycle. Does your unit allow you to adjust this. Also are you overloading. Can you send me the brand and model of your unit and I help you more.
JimmyC
Oct 05, 2009 | Kenmore 3.5 cu. ft. Front Load Electric...
Are you happy with the Kenmore 800 4.0 cu.ft. top load washer?
For large capacity, a front loader would be your best bet. An HE2 by Kenmore should be sufficient. If a toploader is overloaded, it's more likely to do damage. Also a Whirlpool Duet would work. Whirlpool makes Kenmore, so shop for the best price, (they are the same inside)
Apr 15, 2009 | Kenmore 24032\24036 Top Load Washer
Stops at spin cycle
Open the lid to the washer and let it down gently. You should hear a click when the lid closes. If you don't hear it, the lid switch might be faulty and this will prevent the washer from going into spin. Not an expensive repair.
http://tclaundryrepair.com/
Feb 20, 2009 | Electrolux Kenmore 3.5 cu. ft. I.E.C....
Pounding noise after wash and final spin
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
    if this helps please give a fix ya vote
  • Jul 14, 2008 | Kenmore 3.2 cu. ft. Plus Top Load Washer
    Washing Machines Logo
    590 people viewed this question
    Fordexpert
    Archaeology
    Archaeology
    2mikecurtis
