Question about KLH ASW10-120 Subwoofer
My klh subwoofer has R&L connections to speaker and R&L connections to amplifier, but my new amp has a RCA cable connection plug-in. Any way I can use the old subwoofer with the new system?
    Problem Solver:
  • 9 Answers
Yes, you use a subwoofer cable and hook it into the mono rca jack in the back of the sub. or you can use a Y splitter 1 female to 2 males. or if your amp has 2 sub outputs (L&R) then use both. I do believe it's said that if you use the high level input, it's better. I forgot why...
Oh yeah. the difference between the 2 is a high level input allows the currant from the amp to pass through the sub, thus allowing the continuation of wattage to your other speakers.
Low level input is only taking a audio signal from the amp. No power is being sen through the connection.
Posted on Mar 21, 2009
Klh powered subwoofer model ASW10-120B... when you plug in to power... it makes a loud buzzing/humming noise
I would check the caps on the power supply. They are rather large electrolytic capacitors that will look like they burst and/or leaking. When these die, the caps ground and the sub will make a loud buzzing sound. If you are handy with a soldering iron you can replace them yourself. Replace them with the same voltage or a little bigger and same with the size.
If the cap. says 16v 4700pF on it, for example, a 20v 5300pF or a 16v 6200mF cap. will work for this application.
Jan 05, 2016 | Audio Players & Recorders
How to install KLH asw10-20 to a 7.2 receiver
Yes, the 10-120 can use a L & R low level subwoofer input. You can get a short 6" RCA splitter adapter from Radio Shack for a under $10. (1 female input, 2 male outputs) Alternately, just plug the subwoofer output on your receiver to just the low level R channel on the KLH sub.
Jan 20, 2015 | KLH Audio Players & Recorders
Klh powered sub woofer
Low level inputs are designed to take signals directly from an amplifier's "sub out" connections. That way the KLH amplifier will use those signals to produce sound and the volume can be balanced between the main amplifier and the sub amplifier using the sub's volume controls. Depending on your amplifier and sub, that is the best way to connect them. However, be careful running the RCA cables since the low levels are more subject to interference. Keep the runs as short as possible and use high quality shielded cables for the interconnects.
Aug 26, 2014 | Audio Players & Recorders
What wire do I plug in for the subwoofer cause I I have read cables but there's 2 and I only have 1 connection for the sub on the back of the stereo
This subwoofer is probably powered directly from the amplifier and doesn't have an internal amp. The connections are probably the same type as for any other speakers. And, there are probably additional connections for the rest of the speakers. The connection on your amp is likely an RCA phono plug connector that sends low level signals to a powered subwoofer. To connect a passive subwoofer, one without a built-in amp, the main speaker outputs connect to the subwoofer and are then sent to the regular speakers connected to additional terminals on the subwoofer. You may need an owner's manual for the subwoofer to determine how it should be connected.
Aug 23, 2014 | Audio Players & Recorders
How do i connect subwoofer (canton movie 125 mx) to amplifier(onkyo txnr609)? there is one subwoofer output on the amplifier with either L & R(mono) high level input or L & R(mono) low level input...
Connect front the sub out (single) on the amp to one of the rca inputs on the sub, This will work reasonably well but to make the most from the sub buy a 2 rca to 1 rca cable and use it to connect both rca inputs on the sub to the single output on the amp
Mar 10, 2012 | Canton Movie 125 MX Speaker
When I hook up the speakers in the back to the left and right side for the in and out, do I connect the front or rear speakers. do the speakers connect to the subwoofer first then to my receiver or the...
I was trying to find an owner's manual or picture of the rear panel of the sub, but had no luck. The subwoofer is a powered type - or "active" speaker. This means it has a built in amplifier. These active subs usually provide for one or both "low level" and "high level" inputs. Low level signals are usually carried by shielded coaxial cables and have RCA type plugs on the end. The low level is also called "line level". This is an un-amplified signal that might be heard on cheap earphones - but that's about it. It is similar to the output of a tape deck, DVD or phonograph. These signals require an amplifier to be heard. If you have a sub woofer output on your receiver or amplifier, you could run a patch cable between the low level input on the subwoofer and the subwoofer output of the amp or receiver. You receiver or amp may call this output "low frequency effects" or similar. The front and rear speakers would then connect directly to the receiver or amp's corresponding connections.
If you lack low level outputs on the amp or subwoofer, you'll need to run speaker wires from the amplifier or receiver's front left and right speaker output terminals to the subwoofer's high level input terminals. High level signals are speaker connections or amplified signals. These are typically connections that accept bare wire connections. The front speakers would then connect to the subwoofer's front left and right speaker output terminals. The rear speakers connect to the amplifier.
I hope this helps - and good luck!
Nov 24, 2010 | Cerwin Vega AVS-632 System
I have a KLH bassbite II sub, not sure how to connect it to my receiver. Can you help? There are 4 wire amp inputs and 4 speaker wire outputs which I am assuming are right and left channels. There are...
Forget the 4 wire inputs on the sub as you have pointed out. use the low mono input only.this can be plugged into any audio out connections at the amplifier.so it is one rca/low wire from sub to amplifier then plug in power cord and adjust volume as desired.
Mar 06, 2010 | Audio Players & Recorders
Receiver cannot recognize subwoofer
As I implied earlier, take a clue from the physical style of connectors for both parts of the subwoofer function in the old and new receivers:
RCA connections are for Line Level signal between components only.
The input (bare wire) at the speaker is for AMPLIFIED signal.
You can't just modify one to fit the other and expect magic to happen. Be glad you didn't do it the other way around and modify an amplified (speaker level) outout into a Line Level input. You likely would have smoked that component.
Your subwoofer is a passive speaker, that is, like any other speaker it needs an amplifier. Many subs are self-powered (amp built-in) and they would mate well with the RCA sub output of the receiver.
Get yourself an Active (self-amplified) Subwoofer and run UN-MODIFIED RCA cables to it, according to its instructions, from the Sub Out of the receiver. Or get an amplifier between your receiver and the sub you have.
Feb 21, 2010 | Pioneer VSX-D607S Receiver
Subwoofer wont play
Check your rca cables they might be loose or not connected to the amp or the radio. Sometimes those rca cable outlets get worn out by being bumped, moved, hooking up and pulling out connectors. Plug in your rca cords and wiggle them on the amp while radio is on and see if the music cuts in and out
Nov 20, 2008 | Pioneer GM-5100T Car Audio Amplifier
KLH ASW10-120 Subwoofer Logo
393 people viewed this question
Top KLH Audio Players & Recorders Experts
 Grubhead
Grubhead
Vito Vacirca Jr.
Are you a KLH Audio Player and Recorder Expert? Answer questions, earn points and help others
