Question about Husqvarna Designer I
The bobbin binds up underneath plate and stops
The bobbin binds up and i have to cut the material in order to get it out
  • Anonymous Jan 04, 2009
    same issue, but i have a scandinavia 200. i think it might have something to do with thread tension, but not sure. help!
  • marcat43 Jan 07, 2009
    i FOUND OUT WHAT WAS WRONG THE BAR THAT MOVES OVER WITH THE CUTTER BLADE TO CUT THREAD IS BROKEN THANKS FOR THE INPUT .........MARCAT43
    Problem Solver:
  • 6 Answers
Hello, I have a Designer 1 and an SE.
You did not say what you are doing when this happens.
When this happens to me, it is usually because the feed dogs are unable to advance the fabric. If I am mending and using the zigzag and get a lump in the mend, the fabric hangs and if I keep sewing, I will get a huge nest.
I have found that listening to the machine can tell you when something is not right and you can stop it before you get a huge nest.
Here is what I would do-
1. Un thread the machine and re thread. Make sure you are in the take up hook. The silver metal hook that goes up and down and advances the thread.
2. Check that the bobbin is not wound too much. This can be adjusted by turning the white button adjacent to the bobbin winder.
Posted on Jan 04, 2009
I think I need a new bobbn case as the thread keeps binding up under the plate
Make sure your needle is threaded correctly and that the needle is not old or blunt.
make sure that the thread and needle size are compatible with the material you are using.Or check with manufacturer.
Apr 21, 2014 | Simplicity Quilter's Classic SW240...
Thread nesting below plate with material pulled down inside also.
you might check your upper and lower knives. If they have a chip out of them or are dull some material just will not feed
Apr 06, 2014 | Brother 1034D Serger Sewing Machine
Thread is not straight underneath
change the needle
rethread the machine on top--make sure the presser foot is lift to the highest
position
rethread the bobbin also make sure it's inserted correctly into the bobbin
case
clean under the needle plate & in the bobbin area for lint or loose threads
Jun 01, 2012 | Sewing Machines
The first few stitches are just fine but then the machine seems to seize up and stops. When I try to remove the fabric I can barely lift it and then I must cut through a veritable bird's nest of threads on...
You may have a jam under the needle plate. Take it off and have a look.
It is often a simple case of one of the threads not passing through the tension discs correctly. Try re-threading upper and lower, making sure the presser foot is up at the time.
Are you sewing a fine material? Sometimes fine fabric gets pushed down through the universal needle plate hole which is slightly elongated. If this is the case you need a straight stitch needle plate. You cannot do zig zig or anything other than straight stitch with this plate.
If re-threading does not do it and you do have a soft fabric, try popping some freezer paper or similar under the first few centimeters of sewing before buying another needle plate, it might work.
Jan 25, 2011 | PfaFF Sewing Machines
I have a kenmore model # 1581212180. My top thread is looping and when I change the tension then I get where the thread doesn't even stay in the material. I don't have a manual any longer.
Sounds to me like your bobbin tension is way too tight. Adjusting the top thread tension will not correct this. Either something is binding up the bobbin (thread or lint) do you wind your own bobbins? Perhaps you have a little too much thread on the bobbin and it acts like a break, stopping the bobbin from spinning freely. Check, clean and oil your bobbin shuttle (the thing that spins around the bobbin).
Hope this helps!
Chris
glfi.com
Jan 20, 2011 | Kenmore Sewing Machines
When sewing the bobbin will jam. the top of the material looks fine but when you go to snip the bobbin thread there is multipe strends of thread and the needle jams. nothing moves
Make sure your top tension is adjusted correctly and that the thread binds between the tension plates. That's a common problem when the top tension is too loose.
I can try to help you with sewing machine problems at my forum. http://www.sewingmachineryrepair.com/forums/index.php
Feb 27, 2010 | Singer 3116 Simple
My brother is an xr-46, the upper thread is getting caught in or under my bobbin and is not pulling my bobbin thread up, the upper thread wrapps around and across my bobbin creating a mass of thread that...
This problem occurs when the timing is off. When the needle inserts into the machine and picks up the bobbin thread is too early or to late, the thread will get hung up on the "finger" of the bobbin. First, check the bobbin to see if you may have placed it in backwards. If the bobbin was inserted correctly, and this just started happening, then the machine will have to be serviced.
Feb 11, 2010 | Sewing Machines
Bobbin thread tangling up
are you doing embroidery? if so turn off jump stitch cutting if possible. is the machine threaded correctly (pull needle thread out of machine and thread again with presser foot raised.
check for foreign matter in needle tension assembly. ensure there is sufficient needle thread tension.
the thread you see caught up underneath the fabric will be needle thread and indicates insufficient needle thread tension or something preventing the needle thread from being pulled up into the fabric (maybe a damaged bobbin case, or bobbin case position finger, or damaged needle plate hole).
goodluck,
scott
Jul 27, 2009 | Baby Lock Ellure
Needle hits the plate that is over the bobbin.
If possible hoop the item. I have found that any item that has any thickness causes the presser foot to be pushed forward and the needle hits it and breaks. If you can press the item to lessen the thickness this may help. I spoke to Singer (I am a Singer dealer) and they did not have any help for this other than to recommend that the owner cut out the back of the foot. I don't think that would be a solution as it would be difficult to cut out the back of the foot and still have smooth edges, also it would cause the foot to be weak and possible break or bend. Good Luck
Feb 25, 2009 | Singer CE-200 Quantum Futura Computerized...
Embroidery hoop gets stuck to the plate and needle breaks
This has happened to me as well. What I usually do is:-
* remove bobbin case and clean out any lint, also under the needle plate, then replace needle plate , bobbin case and the little front cover. replace the bobbin , checking that you have the thread going the correct way.
* replace the needle with a new one of the correct size for the weight of your fabric and the weight of your thread
*remove and rethread the top thread
* check that the stabilizer is of sufficient weight for the density of the design. (You may need to float an extra piece of stabilizer underneath the hoop)
* check also that it is bobbin-fill in your bobbin (it is easy to get it mixed up)
* when stitching out lace, sometimes it helps to hoop the solvy double.
Jan 07, 2009 | Husqvarna Designer I
Sewing Machines Logo
146 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
