Question about Frigidaire FGQ332ES Gas Dryer
Frigidaire model # fdg648gfso does not heat all the time
Sometimes we have to run the dryer three times to get a load dry. I dont know where to begin. I always feel heat from the dryer and the lint trap is always changed. And it vents well to the outside.
  • timandmelani Jan 02, 2009
    By "it vents well to the outside" I mean there are no obstructions in the exhaust hose to the outside of the house and the dryer is virtually clean and free of lint.
  • Danny Clark
    Danny Clark May 11, 2010
    What exactly do you mean by "it vents well to the outside"?
  • 291 Answers
SOURCE: Frigidaire dryer heats but clothes not drying
A1 Pull the dryer out away from the wall. Unhook the vent from the dryer completely. Do not put anything over the dryer exhaust on the back of the dryer. Do a normal load with the vent unhooked. If it dries better or ok like this then the problem is in the dryer venting. Like a blocked vent pipe or a smashed or restricted vent hose.
Posted on Nov 23, 2008
rickzilla
  • 706 Answers
SOURCE: Frigidaire dryer, lots of lint getting past screen.
Here is a link to an exploded view and parts list for your dryer. http://www.pcappliancerepair.com/model-display.php
If you are certain that the filter is not compromised or damaged and is properly seated into the housing , you may have a problem with the housing itself whereby lint is getting into the blower thru a break in that housing.. I would examine that area for damage.. and make sure when you reinsert the filter, it is seated all the way down.. Hope this helps you... BTW: over time, it is not unusual for lint to build up in the duct since some of that lint is smaller than the filter media and will work its way thru.. If you are getting that degree of lint build up very quickly then you may have a problem as mentioned above..
Regards,
Rick
Posted on Dec 04, 2008
Sea Breeze
  • 4655 Answers
SOURCE: Frigidaire electric dryer; model # FDEB34RGS1- gets TOO hot!
I could not find the model number you listed. I also would be very concerned about over heating until we can find and locate the problem. Look inside the door and compare number with the on listed here at Fixya. Thanks, Sea Breeze
Posted on Mar 25, 2009
  • 21 Answers
SOURCE: Frigidaire model # FG01442ESO, is not drying.
I would replace the gas valves on the dryer. They are located just before the igniter on the dryer. Make sure you unplug the unit and turn off the gas before doing this repair. Good luck
Posted on Aug 24, 2009
TheMobilian
  • 8220 Answers
SOURCE: I have a Frigidaire model # FG01442ESO, gas drier not drying
Them coils is overheating Take a look
Posted on Aug 29, 2009
I want to know how hot my dryer gets. I do not have temp. controls on my model
Good Morning Tabitha,
I see that you are looking to see how hot your Frigidaire dryer, model# FER311FS, actually gets, due to you not having temperature controls on your particular model. Being that you have just the timed dry cycle, it provides up to 100 minutes of drying time at high heat for regular and permanent press items. When drying permanent press items, turn the cycle selector to 40-50 minutes. This is the average time needed to dry most loads of permanent press items. The load tumbles without heat during the last 10 minutes of the Timed Dry cycle. Use this setting to refresh clothing, pillows or blankets or to dust draperies. Heat-sensitive items such as plastics, foam rubber or similarly textured rubber-like materials or items containing feathers or down should be dried only with this setting. Hope this is helpful.
-Best Regards-
Mar 17, 2014 | Frigidaire FER311FS Electric Dryer
My dryer model # ler331dso is getting hot on the top of the dryer but you have to run the dryer like three times to get the clothes dry? What is the problem? The lint filter and hoses are not clogged up....
The dryer might not be the problem at all. The electrical breaker might be on the way out:
The 120 motor's side is fine but the heat load side has taken a beating from the 5 thou watt 240 volt element.
Apr 30, 2011 | Frigidaire GLER642A Electric Dryer
Taking 4 hours to dry clothes
It should never take beyond the normal prescribed time on the dryer timer to dry a load of clothes. Unless, you are overloading the dryer or not sorting your clothes correctly.
If your dryer is heating, but you are experiencing longer dry times and poor drying efficiency, the following link can give you some items to check before you assume there is a malfunction with your dryer:
http://www.fixya.com/support/r3578821-dryer_takes_too_long_to_dry
The number one cause of dryer heat related problems is poor exhaust ventilation. If not vented properly, a dryer will not dry efficiently, will take longer than required to dry, and will cause the heating circuits to overheat to the point of failure. The dryer will actually seem hotter as the heating circuits begin to overheat. This is also the source of many fire hazards if not resolved. Read through the link provided and review some of the potential causes.
If you have any questions, please post back and let me know. Please include your MODEL NUMBER (if it is different from the one you listed this question under), so I can determine how your dryer is configured. I hope you find this information is helpful.
NOTE: If you thoroughly check everything and still have problems let me know. The problem could be related to a thermostat beginning to fail.
Feb 18, 2010 | Frigidaire GLER642A Electric Dryer
Dryer heating is sporadic, sometimes can dry in 45 minutes, other times 4 hours for same type loads?
Not sure what make or model you have but it sounds like you have a bad element. It's hanging loose and the ends are touching from time to time causing what you have described.
Please rate solution
Aug 28, 2009 | Frigidaire Dryers
No heat - long time to dry clothes.
Hi, Is this an electric dryer? The model# shows that is it. If it is gas, you need to change the coils on the top of the gas valve. This is a very common problem with the newer gas dryers. We have them for $27.95. Our # is 1 866 798-4375 Make sure and check the venting to the ouside and make sre that it is clean and has no kinks.
If I can assist you further, please let me know.
Thanks
Vic
May 15, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Dryer #69501 taking long time to dry.
All you need for proper dry times are good airflow and correct heat. As long as you're satisfied with the airflow, pull the venting off the back of the dryer and with a glass bulb thermometer, measure the exhaust temps at the back of the dryer, for most models, the high heat setting should reach roughly 160F +/- 10% before cycling the heat off....check this at the beginning of the cycle, and again after it has been running for 20-30 minutes. If that checks ok, just remember the industry standard for a normal size load of clothing is 60 minutes. If not, please let me know with a re-post, and please include a full model number (should begin either 417 or 110).
Apr 19, 2009 | Kenmore Dryers
Matag NeptuneDryer MD5500AWW - intermittent heat - not drying
this is joyce
It is as you guessed your sensor. it is usually located in door but some models are in back of machine on inside, go online download document papers go to maytag.com put in model# and then download your model # and it will show you where your sensor is located, it should be simple to replace. I had the same problem with my dryer.
I am glad you said you checked the dryer lines because if these get clogged up they will cause the dryer not to dry the clothes correctley. very smart....if you need me to help let me know.
thanks,
joyce
Feb 03, 2009 | Maytag Neptune MAH5500B Front Load Washer
repl/coil/and check for kinks in exhaust hose
Jan 01, 2009 | Dryers
Electric Dryer Heating problem
Remove the rear vent and run a load on time dry for 45 minutes.
If it dries, repair your exhaust vent.
If not, replace your heating element.
Nov 18, 2008 | GE DBXR453EV Dryer
Frigidaire FGQ332ES Gas Dryer Logo
141 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
