Question about Husqvarna Designer I
When i sew the bobbinbinds up underneath plate and stops
Took out assembly and clean still does not work
    Problem Solver:
  • 6 Answers
What are you doing when this happens, embroidery or sewing? Also are you creating a nest, or does the bobbin not move freely?
Check to see that the bobbin is not over wound. The thread should not touch the sides of the bobbin case. This can happen if the bobbin adjustment, the white dial adjacent to the bobbin winder, has been turned and the bobbin winder kicks off too late.
Posted on Jan 04, 2009
Took my machine apart to clean & oil. Now having concern about how to put hook assembly back together. I have a manual but photo doesn't show enough detail!
This video is about removing the items in the bobbin area to clear thread tangles, but the instructions may help you figure out how to put them back together.
30 Removing Tangled Thread from the Hook Race FREE
Jan 26, 2016 | Sewing Machines
How do I rebuild the upper tension mechanism for a singer sewing machine model 507?
It's far too complicated to explain on here. You need to get a service manual for your model, or find one with a similar dial. Make sure the manual covers tension dials. Getting the spring wound correctly can be a challenge. Have you checked to see the if the presser foot lever is pressing against the tension dial from the inside of the machine?
Mar 01, 2015 | Singer Sewing Machines
How do I put my foot controller back together, I took it apart because it will not turn off. My model # 66 - AA307535. Controller # 192257
more than likely, your variable resistor in the foot pedal is shot. cleaning is a low probability repair. replace the pedal assembly.
Oct 19, 2014 | Singer Sewing Machines
Fix sticky--oil--shaft and sewing foot holder assembly
I think you need a different repair man, one who know what he's doing, please find another repair shop,,one that clean & service the machine for you.
Mar 01, 2012 | Sewing Machines
I have a singer 301 that I took the throat plate off to clean and put it back together with the finger in the notch like it is suppose to be but it will not sew just locks up what do I need to do
most likely, you have a small piece of thread caught between the hook assembly and the bobbin case base. you can try to unlock the machine by holding the position finger with your left hand and turn the handwheel backwards. If it unlocks, use a can of canned air to blow it out.
Jun 09, 2009 | Bernina Artista 180
Installing the hook and bobbin assembly.
The plastic bobbin case should sit on top of the raceway, it should slot in quite easily, once the bobbin case is in put the small metal clip at the top over to hold it in place.
May 27, 2009 | Singer Sewing Machines
White thread stitches appear dirty grey
Is this the top thread or your bobbin thread? The technician should have pulled out the tension disk assembly and cleaned it, not just spray more lubricant/cleaner on it. Is this a Bernina certified shop?! Take it back and get him to do it again right, it sounds like carbon/dirt build up in the disks. Have him pull the assembly apart and make sure it's not something else wrong with the disks themselves like oxidization etc.
If it's your bobbin thread.. your bobbin case is just dirty and the spring needs to be cleaned.
The thread doesn't really touch any other parts of the machine, hopefully your technician isn't using grease as this just causes more headaches for attracting more lint and then dirt.
Apr 17, 2009 | Bernina Virtuosa 160
Shuttle alignment and assembly
The shuttle/race/bobbin system shouldn't really be taken apart by the average user. Unfortunately, your chances of ever getting it back together properly so the machine will sew (this is the timing of the machine) are very slim. You'll need to take it to a sewing machine technician. I would recommend an authorized Pfaff tech as they'll be sure to have the proper tools to do this correctly - won't be inexpensive but will be worth it. Most "neighborhood sewing machine repair folks" don't have experience on computer machines. Resetting timing on a computer machine isn't the same as the old mechanicals and requires some expertise.
May 02, 2008 | PfaFF Creative 7570
Sewing Machines Logo
139 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
