Question about Air Hogs Havoc Heli Helicopters
Havoc wont fly
My havoc will not lift off the ground
  • 1 more comment
  • Anonymous May 16, 2009
    the main rotor on mine will not spin. All help is wanted.
  • the_green_ca May 11, 2010
    Are the blades spinning? If not check to make sure they are free of any type of debris such as thread, hair and string.  Make sure you are slowly pushing the throttle up. if this does not work send it back to the company to replace.
  • sbcooper May 11, 2010
    rotar blades will not turn but slips now and then.
My airhog wont go up in air
Posted on Dec 26, 2010
  • turtlehead54 Dec 26, 2010
    my airhog wont lift off ground
Try spining the blades.
Posted on May 16, 2009
My green air hog helicopter is spinning on the ground, it won't lift and fly, how do I fix it?
There is a problem on the motor gear, check the underside where you could see a big gear that should spin when you try to lift the helicopter. Check both big gears if they rotate/spins.
Usually the problem is the small gear on the motor shaft that is not aligned to that big gear. Check on it and adjust the small gear of the motor.
Hope that copter flies high.
Thanks for asking FixYa!
Aug 09, 2011 | Air Hogs Havoc Heli Helicopters
My helicopter has no lift even when fully chargered. The props are spinning but it just stays on the ground.
i got a new model havoc heli and the trim buttons did not help at all... in the end I took a motor/prop off of an air hog styrofoam plane I had that was identical to the havoc heli tail rotor and swapped em out.. Problem solved... there was some sort of error with the tail rotor
Mar 22, 2011 | Air Hogs Spinmaster Air Hogs Havoc...
The helicopter is always crashing when I play with it
Remember MOST of these helicopters are made for INDOOR use because they are very susceptible to ANY type of gust of wind so if your trying it outdoors dont blame yourself to much kiddo. An listen these things arnt as easy as they make it out to be to fly. It DOES take quite a bit of practice and a good understanding of aeronautics. I suggest you do some research on how a heliocopter actually flies its vastly different from an airplane although the principle of lift is the same the way they separatly achive lift is very interesting. The greatest thing about these types of toys is the opportunity they provide to educate yourself through learning how to fly them and equally important how to repair them! Have fun and keep it up you will get better!
Nov 19, 2010 | Air Hogs Glow In Dark Havoc Stinger Rc ...
My helicopter wont fly the main propellers on top of the helicopter stopped working
either stripped the main gear inside the heli or the main blades where they slide on the shaft. you should be able to buy a replacement set of blades. try that and see if it'll fly.
Apr 01, 2010 | Air Hogs Havoc Heli Helicopters
Havoc heli does not get more than 2 inches off the ground
hovoc heli doesn't what to fly more than two inches and than falls over,
Dec 05, 2009 | Air Hogs Havoc Heli Helicopters
Wont fly
on the box it should say a letter for channel a b or c and on the control their is a button that has a b and c set this to the same one on the box and the problem should be solved
Jan 24, 2009 | Air Hogs Glow In Dark Havoc Stinger Rc ...
Wont fly
I have an Air Hogs havoc cyclone stunt plane. I am not sure if your plane has this, but on my plane's remote there left and right steering trim buttons. Play around with these until your plane flies correctly.
Dec 30, 2008 | Air Hogs Glow In Dark Havoc Stinger Rc ...
Havoc heli frequency
You only need one frequency to be able to fly it. So it's working fine.
Dec 27, 2008 | Air Hogs Havoc Heli Helicopters
Air Hogs Havoc Heli Helicopters Logo
1,016 people viewed this question
Top Air Hogs Toys Experts
freddyfox
Stephan Reichert
Stephan Reichert
Are you an Air Hogs Toy Expert? Answer questions, earn points and help others
