Ariston Technologies Ariston AWD12 Front Load All-in-One Washer / Dryer
Problem for Ariston Technologies Ariston AWD12 Front Load All-in-One...
I have an Ariston Magherita
By gail_godwin on Jan 01, 2009
I have an Ariston Magherita 2000 it stops and the dial keeps going around when it gets to the spin. If I then put it back on spin it will not drain the water out. If I empty the machine and then put a couple of clothes back in and then put it on spin it will spin the clothes.
Also the dryer does not work
Same Problem
May 09, 2009
-   I have the same problem as crazygirl8, but on any cycle. Cleaned up the filter, found 2 coins, but problem persists.-   pgissel58
Apr 21, 2009
-   I have the same problem but had to clear it everytime I turns it on and apart from the first time no blockages were found, and now even that doesn't seem to work... It starts clicking away at the beginning rather than spin cycle though... W Wong -   crazygirl 8
Best Solution
posted on Jan 20, 2009
Very Helpful)
herrginger
Rank: Apprentice
Rating: 100%, 1 votes
Yo!
unplug machine from power.
pull the front panel off of the machine its at the bottom, kind of snaps off bottom first then top eases out, anyway becareful as it is pretty fragile plastic.
On right hand side unscrew filter cap - prepare for lots of water that really stinks to pour out. Cap can be a fiddle but does release after unscrewing anti clock wise.
Put fingers in and clear out any blockages you can see, mine was a 1 pence peice and a hair tie. Put back together and it should be ok.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Feb 07, 2009
Somewhat Helpful)
masc30
Rank: Guide
Rating: 84%, 4 votes
I have an Ariston Margherita AL128 and the same problem happened. After skimming through the manual, it occurred to me that it could be the pump that's causing not to drain or spin anymore. Dislodge the white covering infront (just located at the bottom). Once opened, unscrew the black button at the right hand side. Once open, check for blockages like coins, loose items, even lint. This worked for me and saved me $$$!!!! Now my Ariston is back to its superb performance. Do read the manual once in a while, it does help! I lost mine but was able to download a copy from the net.
Was this helpful?
Yes
No
Popular Solutions for Ariston Technologies Ariston
Questions and Unsolved Problems for Ariston Technologies Ariston
Do you recommend Ariston Technologies Ariston AWD12 Front Load All-in-One Washer / Dryer?
Answer
Answer
when i put the washing in,set the dial then the on button it fills slightly then turns twice and... (More)
Answer
Hi, Wondered if anyone could help? The dial on my margerhita keeps going round by itself-I've tried... (More)
Answer
RCB trips a few seconds after switching machine on. Have disconnected motor, pump motor and heater... (More)
Answer
How do I use the dryer only option on the Ariston AWD120 dryer model?
Answer
the door open button is broken from behind it. the complete control fascia needs changing. where can... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Washing Machine Experts
Top Washer & Dryer Repairmen
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
