Question about Dell Dimension 4600 PC Desktop
Roxio Media Manager continues to try to install
It's using 100% CPU (particularly agent.exe), disrupting or freezing everything. I've disabled Windows Installer and somehow it continues to flash, telling me it's trying to install the media manager. I've tried to dump everything Roxio from my computer. I've tried to download a Windows fix but it tells me it can't because the install program is already busy installing something else. Help!
  • susanloverid Jan 02, 2009
    After 2 weeks of headaches, I tried some things last night that seemed to work though I'm not sure how. But I'm going to print and save your answer because the Roxio ghost may return. Thank you so much for your quick concern and help!
  • 53 Answers
After reading your problem I came across some interesting references about roxio and agent.exe.
Seems agent.exe is used by many programs to update themselves over the internet, and it was giving a lot of people headaches by using 70% or more of their CPU, like yourself.
So, I wanted to send you a few quick thoughts on how to hopefully fix your situation.
First, there were complaints about stuff trying to install itself on and on, and it was because there were command lines in the STARTUP MENU calling upon them to install every time windows starts.
So to try to fix this if its happening in your case........
Go to start>run>and type in msconfig and click ok.
Now click startup and uncheck these items.
'ISUSPM Start Up'
Adobe Reader Speed Launcher
Quick Time Task
PERSISTENCE (igfxpers)
Then click apply, then ok and restart your computer.
When windows starts, you will see a window saying that changes were made to the configuration utility. When you see it, click on the little white box saying not to show this any more.
And if you really miss not having something you unchecked, you can always go back there and recheck it!
Maybe now you will have the chance to purge all things Roxio from your system.
Best of luck!!
Posted on Jan 02, 2009
Touch screen keeps freezing
Does the screen also freeze if you are using a mouse instead of touching the screen? If the freezing still occurs, then the problem is NOT the touchscreen. If it works OK with the mouse then you may need to have the touchscreen repaired. If freezing occurs even with the mouse the cause may be one of several. Right-click on the Windows taskbar and select Task Manager. The task Manager box tells you if your processor is working very hard (any reading that continues to hover near 100% indicates some program or process is overworking your system. Task Manager also shows a list of processes and how much cpu % each process is using. Another possibility is that to run everything you want may require more RAM memory. In general, 4GB or RAM is enough, but if you're running a lot of programs/apps at the same time then you may wish to boost your total amount of RAM to 8GB or more.
Sep 25, 2014 | Lenovo IdeaPad Computers & Internet
I have a computer [AMD athlon(tm)]xp 1800+ 1.50 GHz]. My problem is when I switch on the system,the OS will open and i don't open any application then if i see in 'Task Manager - performance' there the...
Type "msconfig" on search bar there will be bar "startup apps" click that and click on disable all and restart your system...hope it works... Regards: imran
Sep 19, 2014 | Computers & Internet
I a 16 user L230. my problem is that the terminals freezes. At logon, they are fine but they start to freeze after about 20mins after i switch the system on. its not particular stations athat freezes but...
The terminals never actually freeze as they are getting desktop sessions from the host. What can happen is the desktop session can lock up and thus any corresponding user input doesn't happen due to the session being locked up. Next time this happens, see if the server/host is responsive. Assuming it is, launch Performance Monitor(Provided as part of the Windows OS) by going to Start ' Run ' Perfmon. Monitor your CPU performance. See what's taking all the CPU resources. It's not uncommon to see unncessary programs running, i.e. jusched.exe (Java Scheduler update), qttask.exe (Quick Time updater), etc. All these programs and other unnecessary programs run at startup and run for EVERY single user so in your case, the jusched.exe runs 16 times and can take valuable system resources. Disable these by going to Start ' Run ' msconfig, press enter, the farthest tab on the right labled STARTUP is where you can disable these programs. After deselecting the ones you don't need, reboot the host and tell the dialog box to NEVER tell you again so that it doesn't alarm you're users that you've messed with the startup config. Lastly, don't overlook that fact that you need 1GB NIC and backbone to the server, each device can take up to 15MB/s of network bandwidth.
Jul 05, 2011 | NComputing L230 Network Terminal
There is a program called Roxie Media manager that keeps trying to install itself when i turn on my computer. Windows installer keeps trying to install it no-matter how many times I try to cancel it. ...
Well you can Install the "windows installer cleanup utility" run it and delete the entry for Roxio, please follow the below link -
Just run the software after downloading . follow the below link to direct download -
Post further comments for more help or information.......
Good Luck!!
Dec 16, 2009 | Computers & Internet
Roxio media manager trys to install on my desktop
If you have the Roxio installation CD:
Insert the Roxio CD into the drive and allow it to complete.
-- or --
UN-install it and then re-install it.
[Control Panel]
[Add or Remove programs]
Locate the Roxio Media Manager and click the [Change/Remove] button and "remove" it.
It is gone.
If you want to install it (yes you do) the insert the CD and install.
Sep 28, 2009 | Dell Dimension 4600 PC Desktop
Roxio Media Manager Keeps Trying to Install
the Roxio Media Manager is belong to the system, and this part the program is in need to run part of the system...
Jun 17, 2009 | Dell Dimension 4600 PC Desktop
Roxio Easy Media Creator 7.5 Platinum and Vista
What have you tried to install the software. I have found that many software CD's or DVD's need to simply be opened by right-clicking on the drive's icon and selecting the 'Explore' option. When the disc icons are shown, select the Setup.exe or Autorun.exe and the software will install. If after installing the software doesn't run, try running it in compatibillity mode for Windows XP.
Feb 01, 2009 | Roxio Easy Media Creator 7.5 Platinum
Explorer.exe uses all available CPU
Norton anti-virus is a resource HOG. Disable it from running at start-up. It may be trying to download updates as the pc is booting. Use AVG anti virus, it is free and works very well.
Dec 28, 2008 | Microsoft Windows XP Professional
Roxio media manager install
If you go to start menu and run, type in msconfig.
Go to the startup tab and uncheck the items you don't want loading up - roxwatch9.exe is one (whether or not there's a separate entry for media manager I can't recall).
Reboot, tell the nag screen please go away and don't bother me again.
Apr 24, 2008 | Dell Inspiron E1505 Notebook
Dell Dimension 4600 PC Desktop Logo
1,249 people viewed this question
Alun Cox
