Question about Fisher Science & Laboratory
Fischer Scientific AB15 -- Unable to calibrate or take any readings.
It will only read 20.00 or -2.00 on the pH setting. Occasionally it will read other values that appear correct, but only for a split second before jumping wildly and then resolving to -2 or 20. Following procedures to run calibration are unsuccessful. Using electrode 13-620-531. Will take temperature accurately. I would hate to track down a new electrode if there is a simple solution I'm overlooking. (I tested the meter by capping the electrode input and checking the voltage, which was accurately 0). Any help would be greatly appreciated.
    New Friend:
The electrode you have is a combination electrode with an integral calomel reference half-cell and built-in temperature probe. Since the temperature reading is good, the temperature probe is okay. It isn't part of the pH circuits anyway. (Your meter uses the temperature to calculate a temperature correction of pH.) Something else is going on with the electrode proper. Its funny behavior suggests to me that it has dried out internally.
pH electrodes don't last forever. How old is this one? If it's an old one, it's probably time to replace it. If it's new and doesn't work, it may be under warranty.
If you shop for a new electrode, get a gel-filled one. And go for one with a silver/silver chloride reference instead of a mercury one -- especially if you are using it on food or other samples that may be consumed. Another consideration about calomel electrodes: they take hours to recover from relatively small temperature changes. Ag/AgCl references aren't as sluggish.
Finally, take care when storing the electrode. It should be stored under humid conditions to keep it from drying out. The best way is to put a small piece of cotton or glass wool soaked with distilled or deionized water inside the plastic end cap. For shorter-term storage, e.g., overnight, you could immerse the tip in pH 7 buffer.
Posted on Nov 22, 2017
leecom72
  • 4806 Answers
SOURCE: Monitor Calibration of HP Pavilion dv5000
ok my friend, right-click on the desktop and select the properties tab then go to display settings/settings and adjust your resolution to 1024x768 click apply and save, you should now have a decent display
Posted on Nov 15, 2008
  • 42 Answers
SOURCE: my viking electric oven does not have accurate temperature
how bad is the temp off?
Posted on Dec 21, 2008
kachbibi1
  • 979 Answers
SOURCE: Maytag oven needs temp calibration
Take your temp knob off and look in the center of the stem and you should find a small set screw. Using a small precision screwdriver, turn the screw until you see the light come on. (You won't have to turn it far.) Turn it a little at a time, maybe a 1/16 of a turn. Leave your thermometer in the oven with the door closed and at or near the temp probe that is in the oven. This way, you are getting a true reading.
Posted on Feb 15, 2009
SOURCE: Travel pilot E2 - unable to calibrate, either auto or manual.
you must have the speedpulse conected with out it conected it will not callabrate
Posted on Aug 10, 2009
  • 16 Answers
SOURCE: can the Model HEM 780N3 be calibrated?? Mine
Cannot be calibrated.
Posted on Jan 12, 2010
Need the resistance VS temperature table for the 15-077-8 probe
http://www.omega.com/techref/pdf/z252-254.pdf
google it RTD to temp
this will not tell you if probe is reading correctly, display is just converter and calculator, probe is the one that measures and supplies result. If you have 3458A you have access to lab equipment and should ask someone how to calibrate this
Aug 08, 2016 | Fisher Scientific 15-077-8 - Scientific...
OVEN TEMP AT LEAST 75 DEGREES COLDER THAN IT IS SET AT .CAN I ADJUST THIS FRIGIDAIRE GAS RANGE GALLERY SERIES SELF CLEAN ,CONVECTION OVEN .
I appreciate your post, Ronald!
From the information you have provided you would like to calibrate the oven temperature on your Frigidaire range. I was unable to locate any instructions on how to perform a calibration on your oven. I would recommend consulting with a professional technician for proper calibration of your range. I hope this information is helpful. -Matt
Jan 01, 2015 | Frigidaire Kitchen Ranges
Haw do i calibrate metller toledo mp220 ph metter
1ST YOUR GONNA NEED BUFFERS:
All pH meters require calibration standards to ensure that the readings are traceable to a standard. Always choose a pH 7 buffer plus at least one other pH value close to your expected measurement range. Using solutions of known pH value allow you to adjust the system to read accurate measurements. Calibration should be performed before each reading or each set of readings.
After that this model has auto buffer select and it will tell You what buffer you put it in , also will ask if you want to correct it as well
Dec 05, 2014 | Measuring Tools & Sensors
Unable to cancel min. wind chill reading wnen current display reads NA; thus 5C still shows from a day in April!
There is a reset button on each sensor unit and there is a reset on the base display. The NA means that the signal is not being sensed from the remote. If you use the reset button on the base you will lose all the historical data. The problem may be related to strong interference from something else nearby, You can bring the sensor inside to see if the base picks it up. IF it does not it may need to be replaced. I have dealt with Oregon Scientific before and they are very good with their support. http://www.oregonscientificstore.com/WMR86A-Oregon-Scientific-Backyard-Pro-Wireless-Weather-Station.product
Jun 27, 2014 | Oregon Scientific WMR86A Backyard Pro...
I need help in pairing my Uniden DECT 3035+1 handsets to my Optus wireless home ph handset
Have a look at this video.
Uniden Phone Reset, Restore, and Deregistration - YouTube
? 3:09
https://www.youtube.com/watch?v=9B0DwYmk-e0
Nov 9, 2011 - Uploaded by votauno
I used it to finally fix problems with my Uniden phone. Read more ... Press and hold delete on the base while ...
Make sure you have the phone lead into the correct socket. I doubt very much you can pair another phone with a cordless set of a different make.
Please remove the bit with your phone number in it. This site get 7 million visitors a year. Many may wish to phone you for a chat :>)
Your Huwai instructions are here. Don't you know any 14 year old lads? They are usually a whiz at this stuff.
Andrew - Fixya Moderator
http://fastlabs.co.za/sites/default/files/Huawei%20F685%20User%20Guide%20EN%20V100R001_01.pdf
Jul 27, 2017 | Lands Phones
Do we need to calibrate the pH meter every time we measure an acidic solution or alkaline solution?
No I have a hanna phep for my koy pond I never calibrate it just clean it in fresh water every use shake it in water
Feb 28, 2011 | Hanna pHep pH Meter with Solutions
Mar 01, 2008 | Blaupunkt DX-V GPS Receiver
Science & Laboratory Logo
995 people viewed this question
Top Fisher Science & Laboratory Experts
Fred Murdock
Fred Murdock
ray gallant
Tom Chichester
Are you a Fisher Science and Laboratory Expert? Answer questions, earn points and help others
