Question about IBM ThinkPad T22 2647 Notebook
ThinkPad T60 Desktop Not Restored After Hibernation/Standby
My desktop icons and taskbar do not appear after I go into standby or hibernation. When I restart the computer after I go to standby or hibernation, the laptop asks me to unlock with my password (or fingerprint recognition). After recognizing my fingerprint, it goes to the Thinkpad background screen, but that's it....no icons or taskbar. I can't get control-alt-delete to work. So I have to press the power button to turn off the entire laptop, then cold boot the machine to get everything working again.
  • Anonymous Jan 10, 2009
    My wife's T60 has the same problem, except hers doesn't have a fingerprint reader.
  • linzk717 Apr 10, 2009
    I have a T400 and have the same problem.
    Problem Solver:
  • 13 Answers
There is something that runs most of the interface between the user and the computer it is called explorer.exe to get the task manager open, you can try pressing CTRL+Shift+Delete another alternative is to do an OS reinstallation.
To get explorer.exe
1) press Ctrl+Alt+Delete; in unsuccessful try Ctrl+****+Delete
2) if task manager opens click on 'New Task..." (if task manager does not open, consider reinstalling your OS or simply don't go into standby/hibernate)
3) Once you get the New Task dialog box, type explorer.exe or C:/Windows/explorer.exe
Posted on Jan 01, 2009
Standby/Hibernate
Have you tried or are able to use system restore to go back to a earlier date before this issue?
May 28, 2012 | HP Computers & Internet
Need to get standby to work on windows xp pro
The only standby I can find in my reference manual is named 'Hibernation' which can be turned On or off as you wish. The instructions are to go to Power Options Properties click the Hibernation Tag and then make your selection to turn it on or off. Let me know how you make out. Geoff
Jan 12, 2012 | Computers & Internet
My computer is booting then after short time it return to standby mode then the fan of processor rotate at very high speed and signal is remove from monitor
Seems like the PC has Hibernation mode turned on. After 1 hour windows will put the PC and hardrives to sleep to conserve power. If you want to disable it, here how:
  1. Open Control Panel.
  2. Double-click the Power Options icon.
  3. Within the Power Options Properties window, click the Hibernate tab.
  4. Uncheck the "Enable hibernation" checkbox to disable the feature, or check the box to enable it. This window also displays the total space required for hibernation.
Sep 19, 2011 | Dell OptiPlex 330 Desktop Desktop Computer...
System standby and system hibernation is greyed out in the acer epower mgmt screen and standby is also greyed out when i click on turn off computer. Any idea how to get these functions back
if it is windows xp right click on a blank part of the desktop go to properties go to screensaver tab then to power tab at bottom.....at the botom of power options set standby also go to hibernation tab and enable hibernation this should make them available after reboot
Jul 07, 2010 | Acer Aspire 5050-3242 Notebook
Standby grayed out
OK, try going to Control Panel, then Performance and Maintenance, then Power Options (if the Control Panel layout is by categories). Go through the tabs until you find an Enable Hibernation check box, then check the box and click OK. This should make both Standby and Hibernate work (to use Hibernate, mouse over Standby while holding down either Shift key), if it does not then your system does not support the Hibernate function. Good luck to you!
Nov 27, 2009 | Dell OptiPlex SX270 PC Desktop
Can't turn hibernation off...help
if you right click on the desktop and go to properties you will find the hibernation option in the power settings.
Jul 20, 2009 | Microsoft Computers & Internet
No active standby button, hybernate facility not found.
In the control panel, go to performance and maintenance then click power options. Or, right click the desktop and select the screen saver tab, then click the power button. If the hibernate tab is missing, either your hardware does not support standby/hibernation mode, or it is disabled in the BIOS. If the hibernate tab is available, click Enable hibernation to do you know what.
May 07, 2009 | Computers & Internet
ToshibaHotkey
go to control panel,power options,
change your power settings
stop Hibernation,
" choose what to do when I hit the power button" etc....
Hibernation causes problems with startups
Don't use hibernation, use standby,sleep
or turn it off completly
should cure the problem
Regards
Richard.
Apr 19, 2009 | Toshiba Satellite 1415-S173 Notebook
PC won't wake up after Hibernate, Standby or Restart
You need to take off your hibernation.
In control panel display then screensaver.Then click power at the bottom of that screen.
You'll see a setting for system standby you can set that to never.At the top click on hibernate remove the check in enable hibernation.
Click apply restart and your system should work.
Jan 12, 2009 | IBM ThinkPad R40 2722 Notebook
Restart from hibernation
go to the system tray and click once on the "Safely Remove Hardware Icon"
click on your dvd/cdrw to stop it. when it says it's safe, go ahead and remove the drive.
reboot
reinstall the drive and windows should automatically pick it up
also. go to --
Start -> Control Panel -> Power Options ->
Under Power Schemes set all the options under the ac power header to NEVER
unless you want it to hibernate, go to the hibernation tab and uncheck the enable hibernation box
go to the Advanced tab and under power buttons --
Close Lid = StandBy
Press Power Button = Shut Off
Press Sleep Button = StandBy
Oh and while you are there make sure the
always show icon in taskbar is checked, so you can keep an eye on your power
click apply and click ok and reboot
let me know if this works for ya
Dec 26, 2008 | IBM ThinkPad R40 2722 Notebook
IBM ThinkPad T22 2647 Notebook Logo
564 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
